A possible way to produce thrust from ZPE?
  • Context: Graduate
  • Thread starter Thread starter alpha_wolf
    Thrust
The discussion revolves around the potential for producing thrust from zero-point energy (ZPE) using a specific geometric configuration of plates. Participants explore the implications of vacuum fluctuations and their effects on force generation, as well as the validity of research related to ZPE.
  • One participant proposes a V-shaped assembly of plates that could generate a net force due to vacuum fluctuations, suggesting that the forces may not cancel out completely.
  • Another participant expresses doubt about the initial geometry, indicating that forces might cancel out and suggests exploring alternative geometries.
  • A participant questions whether the total energy of vacuum fluctuations in the universe is exactly zero or if there is a slight non-zero contribution, proposing that this could allow for energy extraction and amplification.
  • Some participants reference external sources and research, questioning the credibility of certain organizations and their claims regarding ZPE.
  • Concerns are raised about the seriousness of research conducted by specific groups, with calls for scrutiny of their credibility and the nature of their findings.
Participants express differing views on the geometry's effectiveness in producing thrust and the nature of vacuum fluctuations. There is no consensus on the validity of the proposed methods or the credibility of referenced research.
Participants highlight the need for further exploration of geometries and the implications of vacuum fluctuations, indicating that assumptions about energy contributions and the nature of ZPE remain unresolved.
alpha_wolf
Take two plates of a suitable material, and attach them at one end at a 90 degree angle, such that they form a V shaped assembly. The plates will block some of the vacuum flactuation frequencies inside the V, so a Casimir-like force will appear on the two plates. But since the plates are at an angle, I suspect that the forces should not be exactly opposite each other, and should therefore not cancel out. If this is correct, that would produce a small amount of net force, probably in the direction of the V's "mouth".
I think this should be easily testable by using sound waves as a model... Have any such tests been made? Have anyone done calculations on this geometry? Any other comments/thoughts on the matter?
I did some more thinking on this. It would seem that for the described geometry, all forces excerted on the system by the vacuum flactuations would cancel out. But perhaps a different geometry could be designed, where that does not occur...
Is the total energy of the vacuum fluctuations in the universe exactly zero? Or does there exist a slight non-zero energy contribution TO the universe? If so, then it should be possible to model the effect, then experimentally tap into the energy and amplify it. I suspect that resonance will play a big part in the design of a vacuum-fluctuation machine.
The answer is... zero [give or take a quantum fluctuation]. See
http://www.sciam.com/askexpert_question.cfm?articleID=00045486-6600-1C71-9EB7809EC588F2D7&catID=3
Are these people conducting serious research?
http://www.calphysics.org/aboutcipa.html
ZPE:
http://www.calphysics.org/zpe.html
Perhaps you might get a copy of a paperback book called "Does Time Exist?" by Henri Salles (2002 by 1st Books Library). What Henri has sorted out on his own seems to be a good match for what B. Haisch has been doing for some time. I have no clue if these two know each other.
ZPE:
The authors of the Scientific American article are respected authorities who write textbooks and articles in mainstream science. I will pay more attention to the 'California Institute of Physics and Astronomy' [CIPA] when they publish a 'paper' that is more fact than fiction. You would be well advised to check the credibility of your sources before citing them.
  • · Replies 20 ·
12K
  • · Replies 62 ·
13K
  • · Replies 46 ·
  • · Replies 0 ·
  • · Replies 178 ·
11K
