Who knows how to make a simple sine wave oscillator?
The discussion focuses on creating a simple sine wave oscillator using basic electronic components: diodes (normal and zener), capacitors, inductors, and resistors. Participants emphasize the challenge of constructing such an oscillator without transistors and highlight the necessity of an energy source, such as a battery, to initiate oscillation. The conversation underscores the importance of clarifying whether the desired output is a temporary or persistent oscillation for effective guidance.
  • Basic understanding of electronic components: diodes, capacitors, inductors, and resistors
  • Knowledge of oscillation principles in electronics
  • Familiarity with circuit design and energy sources
  • Experience with simple oscillator circuits
  • Research basic sine wave oscillator designs using passive components
  • Explore the role of energy sources in electronic oscillators
  • Learn about the function and application of zener diodes in circuits
  • Investigate methods for achieving persistent oscillation without transistors
Electronics enthusiasts, students working on basic circuit projects, and hobbyists interested in oscillator design using limited components.
Ingyil
Hi.
I want some information about how to make this. But that's not the prob. the prob. is that you can only use: Diodes (Normal & zener), capacitors, inductors & resistors, U can not use complex devices. If U know something, please reply this message.
Thanks.
Ingyil.
Colombia, S.A.
Sounds like homework with restrictions like that.
Google.
If you cannot use transistors then you will have just that much more of a little challenge to figure out.
Cliff
Ingyil
There is not enough info in your question -- the components you mention will sit there doing nothing - you need at least one energy source to start even if it's a battery and you did not say whether it is a temporary or persistent oscillation. Expand if you want an answer. Ray
17K
  • · Replies 19 ·
9K
