Magnetism: Solving Question on Induced E in Windings of Coil
  • Thread starter Thread starter tayi
    Magnetism
The discussion focuses on calculating the induced electromotive force (emf) in a tightly wound circular coil with 81.9 turns and a radius of 0.1 m, subjected to a linearly increasing magnetic field from 0 T to 0.851 T over 0.364 seconds. The relevant equations include emf = -dΦ/dt and emf = -NA dB/dt, where N is the number of turns and A is the area of the coil. The solution involves determining the rate of change of the magnetic field (dB/dt) to find the induced emf in volts.
  • Understanding of Faraday's Law of Electromagnetic Induction
  • Familiarity with the concepts of magnetic flux and its calculation
  • Knowledge of basic calculus, specifically differentiation
  • Ability to apply the formula for the area of a circle (A = πr²)
  • Calculate the area of the coil using A = π(0.1 m)²
  • Determine the rate of change of the magnetic field, dB/dt, from the given values
  • Apply the formula emf = -NA dB/dt to find the induced emf
  • Explore practical applications of induced emf in electrical engineering
Students studying electromagnetism, physics educators, and anyone interested in understanding the principles of induced electromotive force in coils and their applications in electrical circuits.
tayi
Given: A tightly wound circular coil has
81.9 turns , each of radius 0.1 m. The uniform
magnetic field is in a direction perpendicular
to the plane of the coil. The field increases
linearly from 0 T to 0.851 T in a time of
0.364 s .
What E is induced in the windings of the
coil?
Answer in units of V.
emf=Blv
emf(average)=magnetic flux/time
I think this can be solved using magnetic flux, but i don't reallly know how to go about doing it
tayi said:
emf=Blv
Start with your equation
emf = -dΦ/dt where Φ=NBA, thus your equation becomes
emf = -d/dt(NBA)
N and A are constant so emf=-NA dB/dt. So how you would get dB/dt which is the rate of change of the magnetic field per unit time.
