Schroeder on thermodynamical reversibility, entropy and quasi-static equilibrium
The discussion revolves around the concepts of thermodynamical reversibility, entropy, and quasi-static equilibrium as presented in Schroeder's "An Introduction to Thermal Physics." Participants explore the implications of quasi-static processes, particularly in relation to irreversibility and the conditions under which the first law of thermodynamics applies.
  • One participant notes that Schroeder deduces Q = TdS for all quasi-static processes, questioning the assumption that this implies reversibility, as their class indicated.
  • Another participant suggests that a quasi-static process can still be irreversible if heat flows in or out or if entropy is created in other ways, referencing Schroeder's text.
  • A participant provides an example of an irreversible, quasi-static process involving slow heat exchange between two bodies at different temperatures, raising questions about the definition of quasi-static processes.
  • One participant references Buchdahl's work, asserting that every quasi-static process is reversible, but acknowledges that definitions of "quasi-static" may vary among different authors.
  • Another participant expresses interest in Buchdahl's axiomatic approach but is concerned about its focus on classical thermodynamics, suggesting that statistical treatment is also important.
  • There is a suggestion that understanding phenomenological thermodynamics is necessary before delving into statistical thermodynamics.
Participants express differing views on the relationship between quasi-static processes and reversibility, with some asserting that all quasi-static processes are reversible while others argue that this is not universally applicable. The discussion remains unresolved regarding the precise definitions and implications of quasi-static processes.
There are limitations in the definitions of quasi-static processes as presented by different authors, leading to potential contradictions in understanding their relationship with irreversibility and equilibrium.
nonequilibrium
Hello,
In "An Introduction to Thermal Physics" Schroeder goes to deduce that for any quasi-static process: W = -PdV (p.21), and then on page 112, with the help of dE = Q + W (= first law of Td.) and dE = TdS - PdV (= the Td. identity), he deduces that Q = TdS for ALL quasi-static processes (reversibility is not a prerequisite).
In class we saw that Q = TdS implies reversibility, but I assume this is wrong, then, because Q = TdS already follows out of "regular" happening quasi-statically and on p.82 Schroeder notes: "A quasistatic process can still be irreversible, however, if there is also heat flowing in or out or if entropy is being created in some other way."
What is an example, then, of a quasistatic, irreversible process? My professor argumented you could let the free (adiabatic) expansion of a gas (i.e. letting a gas freely expand into vacuum in an isolated container (from e.g. half the container volume), so Q = 0 and dE = 0 and W = 0 [see incl. picture for clarity]) happen quasistatically by building brick wall after brick wall (seperating the gas from the vacuum), pulling away each wall after another, letting the gas expand infinitesimally further each go. According to Schroeder, however, this is clearly not quasistatic since W (= 0) does not equal PdV (clearly not zero). Furthermore, if it were quasistatic, then Q = TdS and since Q = 0, the adiabatic expansion would be reversible.
On wikipedia it gave the following example of an irreversible, quasistatic process:
An example of a quasistatic process that is not reversible is the slow heat exchange between two bodies at two finitely different temperatures, where the heat exchange rate is controlled by an approximately adiabatic partition between the two bodies (Sears and Salinger, 1986) — in this case, no matter how slowly the process takes place, the states of the two bodies are never infinitesimally close to equilibrium, since thermal equilibrium requires that the two bodies be at precisely the same temperature
But I must say I don't quite get it, because earlier on the page it defines quasistatic as "the system will go through a sequence of states that are infinitesimally close to equilibrium (so the system remains in quasistatic equilibrium)", while in the example it argues that it cannot be infinitesimally close to equilibrium... If indeed the example itself is a good one, then what is a better definition of quasistatic? (so you don't get a contradiction...)
So what is the deal? AKA what is an irreversible, quasistatic process (so where Q = TdSsystem yet dSuniverse > 0)
Thank you,
mr. vodka
Science news on Phys.org
I had a look at "H. A. Buchdahl, The concepts of classical thermodynamics, cambridge u p, 1966" which has been re-edited in 2009. It is a very careful book on axiomatic thermodynamics. Buchdahl shows, that every quasi-static process is reversible.
However, I think that different people use different notions of "quasi-static", e.g. in the sense that the system is only locally in equilibrium; for the latter definitions, this may not hold.
Hm, interesting. Would you recommend me to buy the book? An axiomatic treatment of the subject seems VERY appealing, but the thing stopping me is that it purely looks at classical thermodynamics, while I believe the statistical treatment is essential for a grasp of the material.
Could you possibly look how the book defines "quasi-static"? Its result that it automatically implies reversibility, is very interesting.
Personally, I think that you have to understand first phenomenological thermodynamics to appreciate statistical thermodynamics. The book by Buchdahl is nevertheless a textbook and doesn't get lost in formalism. So it is probably a good buy. But maybe you can find it in the library?
Ah yes, it is there, thanks :)
  • · Replies 21 ·
  • · Replies 60 ·
11K
  • · Replies 22 ·
