Reflection or not with two layers with different indices of refraction
The discussion revolves around the concept of reflection and refraction at the boundaries of materials with different indices of refraction, specifically involving a glass surface and a thin film. The original poster seeks to understand the conditions that lead to reflection and non-reflection when light interacts with these layers.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss calculating angles of refraction and critical angles to determine reflection conditions. There is also a focus on understanding the phase differences between reflected waves and how these relate to film thickness.
Some participants have offered insights into the calculations needed for determining reflection and refraction conditions, while others are exploring the definitions of non-reflection and its implications. Multiple interpretations of the problem are being examined, particularly regarding the nature of reflection and refraction in this context.
There is a mention of the original poster's confusion regarding the terminology of "non-reflection" and its potential meanings. The discussion also highlights the need for clarity on the phase changes that occur at the boundaries of different refractive indices.
daisyi
The packet doesn't explain this concept very well, and the book doesn't seem to explain it at all.
A glass surface (n = 1.5) is coated with a film with an index of refraction n=1.3. If light of frequency 6x10^14 cps is incident almost normally on the film, find the minimum thickness that will cause (a) reflection, and (b) non-reflection.
Any tips on the concept or any formulas woluld be very helpful. Thanks!
I think you have to calculate the angle of the first refracted ray entering the film, and then use this ray to calculate if the angle is at the critical angle of the glass.
For the first part, I am assuming the ray comes from air and goes into the film.
[tex]{n_1}{sin\theta_1} = {n_2}{sin\theta_2}[/tex]
now sub in the values and solve for the angle of refraction.
after doing this, you can solve to see what the critical angle of the glass will be:
[tex]sin\theta = \frac {n_1}{n_2}[/tex]
and see if 90 - the angle that you got in the first part is more or less than this critical angle. If it is more, then it vill cause reflection, but if it is leass, it will refract.
Daisyi,
when u say non-reflection, do u mean complete refraction or partial reflection-refraction? (It may not prolly matter here but i just wanted to know because i have not really seen the usage of non-reflection anywhere)
-- AI
thin film interference/anti-reflective coatings
The basic idea is that when light hits a boundary some of it will reflect back. Since you have two boundaries (between air and the film and between the film and the glass) you will have two reflected waves. If those waves are out of phase, they will cancel thus minimizing reflection; on the other hand, if they are in phase, they will constructively interfere and thus maximize the reflection.
So the trick is to figure out the phase difference between the first reflection and the second reflection. That depends on two things:
(1) the thickness of the film. Remember that the second reflection passes through the film twice.
(2) the phase changes at the boundaries. When light reflects from a low n to higher n boundary, the reflection gets a [itex]\pi/2[/itex] phase inversion. (So... will the two reflections have a net phase inversion in your problem?)​
Your job is to figure out the film thickness that will give a [itex]\pi/2[/itex] (destructive) or a [itex]\pi[/itex] (constructive) phase difference between the two reflections. (Hint: a [itex]\pi/2[/itex] phase difference equals half a wavelength. What's the wavelength of the light when inside the film?)
