Thread Closed
Turbine and compressor maps
Share Thread Thread Tools
Apr5-10, 01:26 AM   #1
Hi all, does anyone knows of any good website that teaches you how to read turbine or compressor maps? And possibly teaches you how to select the best turbine / compressor for your particular application?
Thank you!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Apr11-10, 02:27 AM   #2
Turbines and compressors are quite different animals. Compressor curves are normally the predicted discharge pressure, efficiency, temperature, versus flow for one or more operating speeds. The curves are plotted from the surge point to the choke point.
For the compressor application, you need to let the manufacturer know the conditions you want to meet. This will consist of inlet and discharge pressures, inlet temp, gas composition, mass flow rate, driver speed if you have one. For the turbine, the steam inlet pressure and temp, exhaust temp., operating speed, power required, and available flow.
There's a good bit more that goes into the selection of turbines and compressors but this is a start.
Apr11-10, 10:41 AM   #3
Any good turbo machinery text will provide detailed information about all the things are you looking for.
http://www.amazon.com/Turbomachinery...1000464&sr=8-2
Apr11-10, 03:18 PM   #4
Recognitions:
Gold Membership Gold Member
Garrett have a great series of introductions to turbocharging, including map interpretation.
http://www.turbobygarrett.com/turbob...o_tech101.html
Apr11-10, 09:40 PM   #5
You can also read the Turbo Regal website. They have a nice Excel Spreadsheet too.
Thread Closed
Thread Tools
Similar Threads for: Turbine and compressor maps
Thread Forum Replies
Steam Turbine / Tesla Turbine - bladless rotor in steam turbine? Classical Physics 4
Why water turbine have higher efficiency then steam turbine? General Physics 22
Compressor and turbine design Mechanical Engineering 4
Linear Maps/Matrix Maps Engineering, Comp Sci, & Technology Homework 2
Compressor As a Steam Turbine Mechanical Engineering 4
