Angle between two diagonals of a cube.
  • Thread starter d.almont23
  • Tags
    Angle Cube
In summary: But as it is open, I add my view: If the cube has edge length a, then the length of the face diagonal is a.sqrt(2) and the length of the body diagonal is a.sqrt(3). The angle between the diagonals is given by cos(theta) = (a.sqrt(2))^2/(a.sqrt(3))^2 = 2/3, so theta = arccos(2/3) = 48.1896851 degrees.In summary, the angle between the diagonal of the back and left faces of a cube with one vertex on the origin is approximately 48.1896851 degrees. This can be found by using the formula cos(theta) = u*v/
d.almont23
Find the angle between the diagonal of the back and left faces of a cube with one vertex on the origin
A) 60 degrees
B) cos^-1(1/sqrt(6))
C) cos^-1(1/3*sqrt(2))
D) 90 degrees
E) 120 degrees
The two diagonals eminate from the vertex at the origin.
I will write to mean the "norm" of u and u*v to be u "dot" v
I know we have the formula cos(theta) = u*v/( [v]).
But we do not know know any points on the cube so we can't form any vectors...
But since these are the diagonals of a cube they should be the same size . It which case u = v
Then u*v = u^2 and = [v] which impies [v] = u^2. Then cos(theta) = 1 which implies theta = 0 which is definitely not the case...
My other thought is that if these are diagonals on the face of a cube, shouldn't they bisect the 90 degree angles of the cube into 45 degree angles? Then the angle between the two vectors would be 45 + 45 = 90 degrees choice D).
Is this correct?
A) 60 degrees
D) 90 degrees
E) 120 degrees
your dot products don't take into account directions & are not correct,
Just because [itex] |\textbf{u}| = |\textbf{v}| [/itex], you still have to accaount for the angle which is unknown, so[itex] \textbf{u} \bullet \textbf{v} = |\textbf{u}||\textbf{v}| cos(\theta) =|\textbf{u}|^2 cos(\theta) [/itex]
Is this correct?
the question isn't wirtten great to visualise... but i think there's an easier way
so if I'm getting it correctly, try considering the triangle created by joining the ends of the 2 diagonals across the top face
how are the lengths of each side of the traingle related?
otherwise do it the brute force way & write out the vectors explicitlye eg. (1,1,0) and find their magnitudes & dot product then use the results to find the angle
There are 4 diagonals in a cube. Section the cube such that you have 6 equal square based pyramids, formed by the 6 faces and the 4 diagonals. Now consider one of the pyramids. Let ABCD denote the 4 corners of the square base and P denote the apex of the pyramid, which is at the centre of the cube. The angle required is surely given by, say, angle APB. This is trivial to find: let the cube have sides of length say x; drop a perpendicular from P to centre of square base and call this point G; length PG is, trivially, x/2; length GA is half the diagonal of square base (or sqr(2)*x/2). By Pythagoras theorem length PA (=PB) can be found:
PA^2 = PG^2 + GA^2, which yields
PA =sqr(3)*x/2.
Hence we have 3 sides of the triangle PAB. Angle BPA is required and this is found by the cosine rule. The calculation yields:
Cos(angle BPA) = 1/3 or angle BPA = 70.52877937 degrees.
This is the angle between 2 diagonals of a cube.
@Bill Crean: The problem asks the angle between face diagonals. Read the original post.
@d.almont: I suggest to draw a picture. Something like the one I attached. You can place that cube as you like in the coordinate system and can choose unit edge length.
ehild
this one is probably old enough to be considered closed, but just for completeness, consider the dot product method
by taking the difference of the corner point positions of the cube of unit length positioned with a corner at the origin, one vector representing a diagonal is
(1,1,1) = (1,1,1)-(0,0,0)
similarly for another
(1,1,-1) = (1,1,0)-(0,0,1)
both have magnitude sqrt(3)
taking the dot product gives:
3.cos(theta)=1
ehild
good point ehild, my last post was on the diagonals and not face diagonals
as mentioned though this is reopening a pretty old thread
Indeed!
1. What is the angle between two diagonals of a cube?
The angle between two diagonals of a cube is approximately 70.53 degrees.
2. How do you calculate the angle between two diagonals of a cube?
To calculate the angle between two diagonals of a cube, you can use the formula angle = 2 * arctan(a/sqrt(3)), where a is the length of one side of the cube.
3. Why is the angle between two diagonals of a cube important?
The angle between two diagonals of a cube is important because it helps us understand the geometry and symmetry of the cube. It also has applications in fields such as architecture and engineering.
4. Does the angle between two diagonals of a cube change with the size of the cube?
Yes, the angle between two diagonals of a cube varies with the size of the cube. As the length of the cube's side increases, the angle between its diagonals also increases.
5. Can the angle between two diagonals of a cube be greater than 90 degrees?
No, the angle between two diagonals of a cube will always be less than 90 degrees. This is due to the fact that a cube is a regular polyhedron with equal angles and all of its diagonals are equal in length.
  • General Math
