Operator representation of p in x basis.
The discussion focuses on representing the momentum operator \( p \) in a discrete positional basis for the Schrödinger equation of a hydrogen atom. The basis states are defined as |0⟩, |d⟩, |2d⟩, and |3d⟩, where \( d \) is a distance on the order of a Bohr radius. The momentum operator is expressed as \( p = -i\hbar(d/dx) \), which is rewritten in the defined basis, demonstrating that \( p \) can be represented as a linear combination of the basis states with coefficients proportional to the distances \( d \). This method allows for flexibility in representing \( p \) across different discrete bases.
  • Understanding of quantum mechanics, specifically the Schrödinger equation.
  • Familiarity with operator notation and linear algebra.
  • Knowledge of discrete basis states in quantum systems.
  • Basic concepts of momentum and position operators in quantum mechanics.
  • Study the representation of operators in quantum mechanics, focusing on discrete bases.
  • Learn about the implications of the momentum operator in different quantum systems.
  • Explore the mathematical foundations of linear combinations in quantum mechanics.
  • Investigate the role of the Bohr radius in atomic physics and its applications.
Quantum physicists, students of quantum mechanics, and researchers working on atomic models or operator representations in quantum systems.
qubits
For the Schrödinger equation for a hydrogen atom, we need to write out:
p^2/2m for the electron.
If we define our basis states to be a linear discrete array of points, let's say 4 points. 0,d,2d, and 3d, where is some distance, on the order of a Bohr radius. How do I write p as an operator in that positional basis? I kind of have an idea of how to do it, but I don't want to say anything to bias your answers. I'll hear your ideas then tell you what I did.
Basically I want to write this in operator notation where I have defined the basis states.
[tex]\hat{H} = \frac{1}{2m} \hat{p}_{1}^2 - \frac{1}{4 \pi \epsilon_0} \frac{Z e}{\hat{r}_{1} - R}[/tex]
In the x basis, the position operator is represented as x, which acts on a wavefunction ψ(x) to give the position of the particle. In the same way, the momentum operator p is represented as p = -iħ(d/dx), which acts on ψ(x) to give the momentum of the particle.
To represent p in the given basis of 0,d,2d, and 3d, we can use the position operator x to define the basis states as |0⟩, |d⟩, |2d⟩, and |3d⟩. Then, we can write p as an operator in this basis as follows:
p = -iħ(d/dx) = -iħ((d/d0)|0⟩ + (d/dd)|d⟩ + (d/d2d)|2d⟩ + (d/d3d)|3d⟩)
= -iħ(0|0⟩ + (1/d)|d⟩ + (2/d)|2d⟩ + (3/d)|3d⟩)
= -iħ(d/d)∑n=0^3 n|nd⟩
where |nd⟩ represents the basis state at position nd.
This representation of p in the given basis shows that the momentum operator is a linear combination of the position basis states, with coefficients proportional to the distances d. This approach can be extended to any discrete basis of points, allowing for the representation of p in different bases for different systems.
  • · Replies 61 ·
  • · Replies 56 ·
  • · Replies 67 ·
