Pendulum Collision Homework: Mass, Speed Calculation
  • Thread starter Thread starter KaiserBrandon
    Collision Pendulum
The problem involves a stick of mass m and length L that is pivoted at one end and swings down to collide elastically with a ball. The original poster seeks to determine the mass of the ball and its speed after the collision, given that the stick loses half of its angular velocity during the impact.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • The original poster attempts to use conservation of energy to find the angular velocity just before the collision and then applies conservation of energy and linear momentum to derive expressions for the mass and velocity of the ball. Some participants question the use of angular momentum in the analysis, suggesting it could also be relevant to the problem.
Participants are exploring different methods to approach the problem, including energy conservation and momentum conservation. Some have noted potential errors in the original calculations and are discussing the implications of using angular momentum. There is no explicit consensus on the best approach, but multiple interpretations are being considered.
Participants are discussing the implications of the stick's pivot point and the initial conditions of the ball, including its angular momentum relative to the pivot. There is also mention of a potential mistake in the original poster's energy conservation equation regarding the height through which the center of mass falls.
KaiserBrandon
A stick of mass m and length L is pivoted at an end. It is held horizontal and then released. It swings down, and when it is vertical the free end elastically collides with a ball. (assume that the ball is initially held at rest and then released a split second before the stick strikes it.) If the stick loses half of its angular velocity during the collision, what is the mass of the ball? What is the speed of the ball right after the collision?
moment of inertia for the stick: [tex]I=\frac{1}{3}*mL^{2}[/tex].
[tex]L=I\omega[/tex].
[tex]\omega =\frac{v}{r}[/tex]
[tex]K_{rotational}=\frac{1}{2}I\omega^{2}[/tex]
Alright so first I found the angular velocity the instant before it hit the ball by using conservation of energy:
[tex]mgL = \frac{1}{2}(\frac{1}{3}mL^{2})\omega^{2}[/tex]
and found that [tex]\omega=\sqrt{6g/L}[/tex].
then I used E-conservation for before and after the collision:
[tex]\frac{1}{2}I\omega^{2}=\frac{1}{2}I(\omega/2)^{2}+\frac{1}{2}m_{ball}v_{ball}^{2}[/tex]
and substituting I and [tex]\omega[/tex], I reduced this for the mass and velocity of the ball:
[tex]m_{ball}v_{ball}^{2}=\frac{3}{2}mLg[/tex]
Then I used linear momentum conservation here. My reasoning here is that the momentum of the centre of mass of the stick before is equal to the momentum of the centre of mass of the stick afterwards plus the momentum of the ball afterwards.
so before
[tex]v_{cm}=\frac{L}{2}\omega[/tex]
and just divide this by 2 for the velocity after the collision. So using
[tex]mv=mv/2+m_{ball}v_{ball}[/tex]
I found an expression for mv of the ball, which is
[tex]\frac{m}{2}\sqrt{3/2gL}=m_{b}v_{b}[/tex]
isolating v, and substituting it into the [tex]m_{b}v_{b}^{2}[/tex] expression, I got
[tex]m_{b}=\frac{1}{4}m[/tex]
and then putting this into the previous v expression, I get
[tex]v_{b}=2\sqrt{3/2Lg}[/tex]
So does what I did make sense? The only thing I can think of is that by using my method, the ball would have the same end velocity no matter where it struck the stick, as this does not matter in my p-conservation equations. I can't think of a way to use angular momentum, since the ball doesn't really have angular momentum.
When the stick falls, center of mass falls through height L/2.
ok, so in the first E-conservation equation, I replaced mgL with mg(L/2). So I got
[tex]\omega = \sqrt{\frac{3g}{L}}[/tex]
for my new angular velocity. In the end, using the same procedure as before, I got my mass to equal the same, and my ball velocity became:
[tex]v_{b} = \sqrt{3gL}[/tex]
so other than that mistake, I did it right?
I think so.
allright, thank you very much kind sir.
I apologize for bringing up a dead topic, but It just came up in one of my assignments. I followed the same procedure and it makes sense to me and seems consistent, but I am having a hard time understanding why conservation of angular momentum is not used here (shouldn't we need it?). Id appreciate if anyone could help me understand this? It appears to me that we should need conservation of energy, momentum (linear) and momentum (angular)
Note that the ball *does* have angular momentum with respect to the pivot point of the stick. Because the initial angle of its velocity vector is 90° to the radius vector, it's simply its linear momentum multiplied by the radius (L). But you could have gone the completely angular momentum route and arrived at the same result.
I in fact ended up using angular momentum conservation directly with energy conservation (you don't have to solve for the angular velocity (at least not right away) ). This produced a mass of [tex]\frac{m}{9}[/tex], and a speed of [tex]\frac{3\omega l}{2}[/tex]. Where the angular velocity is that given by the OP (corrected one).
18K
