The velocity of electron near speed of light?
The discussion focuses on the behavior of an electron's velocity as it approaches the speed of light when subjected to a constant force. The momentum of the electron is described by the formula p = mv / √(1 - v²/c²), and the relationship between force and momentum is expressed through Newton's second law as dp/dt = F. The solution for the velocity as a function of time is derived as v(t) = Fct / √(F²t² + c²m²), demonstrating that v approaches c as t approaches infinity. Additionally, the distance traveled by the electron over time is given by d(t) = (c/F)√(t²F² + c²m²).
  • Understanding of relativistic momentum and the formula p = mv / √(1 - v²/c²)
  • Familiarity with Newton's second law and its application in differential equations
  • Basic knowledge of calculus, specifically integration and differentiation
  • Experience with mathematical software tools like Maple for solving equations
  • Study the derivation of relativistic momentum and its implications in physics
  • Learn how to solve differential equations related to motion under constant force
  • Explore the use of Maple or similar software for solving complex physics equations
  • Investigate the concept of limits in calculus to understand behavior as variables approach infinity
Physicists, students of advanced mechanics, and anyone interested in the implications of relativistic effects on particle motion.
randybryan
This isn't a homework question, simply one I found in a book that I'm trying to do:
momentum p, of electron at speed v near speed of light increases according to formula
p = [tex]\frac{mv}{\sqrt{1 - \frac{v^{2}}{c^{2}}}}[/tex]
if an electron is subject to constant force F, Newton's second law of describing motion is
[tex]\frac{dp}{dt}[/tex] = [tex]\frac{d}{dt}[/tex] [tex]\frac{mv}{\sqrt{1 - \frac{v^{2}}{c^{2}}}}[/tex] = F
This all makes sense to me. It then says, find v(t) and show that v --> c as t --> infinity. Find the distance traveled by the electron in time t if it starts from rest.
Now I could get an expression for v by using the first formula, but I don't understand how I can show that v -->c as t --> infinity as t isn't in the equation. I haven't even attempted the second part, but I'm assuming some integration is involved
Can anyone help?
What you want to do to find v(t) is to solve the differential equation:
[tex] F = \frac{d}{dt} \left( m v(t) \gamma (t)\right)[/tex]
for v(t).
Now, you can differentiate the product to get
[tex] F = m a(t) \gamma (t) + m v(t) \left( \frac{v(t)a(t)}{c^2}\gamma^3(t)\right)=m a(t) (\gamma + \beta ^2(t)\gamma ^3(t)), ~~~~ \beta=\frac{v(t)}{c}[/tex]
Now, solving this (I used Maple) and imposing the condition v(0)=0, one gets the expression
[tex] v(t)=\frac{Fct}{\sqrt{F^2 t^2 + c^2 m^2}}[/tex]
As you can see, v approaches c a time goes to infinity.
The expression is easily (with some computer) integrated to give you an expression for the distance traveled over time:
[tex] d(t)=\frac{c}{F} \sqrt{t^2F^2+c^2m^2}[/tex]
Can anyone help?
F=m*d/dt(v/sqrt(1-(v/c)^2)
so,
F/m=d/dt(v/sqrt(1-(v/c)^2)
Since F/m is constant, the above becomes a very simple differential equation with the solution:
v=at/sqrt(1+(at/c)^2)
For at<<c, you recover the Newtonian equation v=at
If you integrate one more time, you will get x as a function of a and t. Indeed:
dx/dt=at/sqrt(1+(at/c)^2)
x(t)=c^2/a*(sqrt(1+(at/c)^2)-1)
Again, for at<<c, you recover the Newtonian formula x(t)=at^2/2
  • · Replies 26 ·
  • · Replies 17 ·
  • · Replies 31 ·
  • · Replies 53 ·
  • · Replies 33 ·
  • · Replies 55 ·
