Solve general differential equation: please check my work?
The discussion revolves around solving a first-order linear differential equation of the form y' - 2y = (t^2)(e^2t). Participants are attempting to clarify their understanding of the solution process, particularly regarding the use of integrating factors and integration techniques.
  • The original poster attempts to recall the steps for solving the differential equation, particularly the role of the integrating factor. Some participants suggest integrating both sides after applying the integrating factor, while others question the correctness of the integration steps and the placement of the constant of integration.
Participants are actively engaging with each other's attempts and providing feedback on the integration process. There is a mix of interpretations regarding the integration steps and the final form of the solution, with some guidance offered on the correct application of the integrating factor and the constant of integration.
There is a lack of initial conditions provided, leading to discussions about the nature of the solution as a general solution to the differential equation. Participants are also questioning the implications of the constant of integration in the absence of initial conditions.
darryw
I forgot how to do these and just need a little refreshing on how to solve these
ok so my integrating factor is the value in front of y, right?
so mu(x) = e^int-2
= e^-2t
so then after i multiply whole equation by e^-2t i get:
(e^-2t)y = t^2 (because the e^-2t canceled the e^2t that was in the right hand term).
SO this is where I totally forgot how to proceed! Do i integrate both sides, then I am done? or am i missing a step?
and if i do integrate then do i use u-sub for the term on LHS?
thanks for any help
Remember your LHS always becoms
d/dt( y*integratingn factor)
so now you just integrate both sides.
integ (ye^-2t)' = integ t^2
= ye^-2t = (1/3)t^3
y = (t^3) / (3e^-2t) + c (this is my final solution)
Is this correct? Also, even though I don't have initial cond can i say anything more about what c is?
thanks
= ye^-2t = (1/3)t^3
thanks
The line in red should be
ye-2t+(1/3)t3+C
then
you can divide by e-2t
thanks for the reply..but i don't understand what and why you did that? what does that equal? If zero, then how did (1/3)t^3 become negative?
Terribly sorry, I made a typo, it should be this.
ye-2t=(1/3)t3+C
ok thanks. so only diff was that i need to reference c right after integration before doing anything else to equation, --right?
= ye^-2t = (1/3)t^3
In the line above, the first = shouldn't be there, and you should add the constant of integration in this step.
Each line should be an equation that implies, but is not equal to, the next line. After all, an equation can't be equal to another equation.
To recap,
[tex]d/dt(ye^{-2t} = t^2[/tex]
[tex]\Rightarrow ye^{-2t} = \int t^2 dt = \frac{t^3}{3} + C[/tex]
[tex]\Rightarrow y = e^{2t}(\frac{t^3}{3} + C)}[/tex]
Notice also that the constant is multiplied by e2t.
thanks
thanks for the replies..
so my final solution is:
y = (1/3) (t^3)((e^t)^2) + ce^t^2
is this correct? also, since there were no init cond, is this what's called the general solution to the DE? If i did have IC i would be able to know what c is right?
thanks
thanks
No, not correct. See post #8. Where are you getting et2? And why are you writing e2t as (et)2?
Yes, if you had an initial condition you could solve for C.
should be:
y = (1/3)(e^2t)(t^3) + c(e^2t) (i integrated integrating factor incorrectly)
is this correct? (also since there were no init cond, is this what's called the general solution to the DE? If i did have IC i would be able to know what c is right?
thanks)
darryw said:
should be:
is this correct?
Why are you asking this? Look at post #8.
Yes, this is the general solution. The other question has already been answered.
