Formula for Vertical column +eccentric loading
The discussion focuses on calculating the formula for a vertical C-Channel column subjected to eccentric loading. Key steps include drawing the section of the column and calculating the principal moments of inertia to accurately assess the effects of the eccentric load. Participants emphasize the importance of visual representation to clarify the loading position for effective assistance.
  • Understanding of structural engineering principles
  • Knowledge of C-Channel geometry and properties
  • Familiarity with moments of inertia calculations
  • Ability to interpret loading diagrams
  • Research the calculation of principal moments of inertia for non-symmetric sections
  • Learn about eccentric loading effects on structural columns
  • Study the use of CAD software for drawing structural sections
  • Explore design codes relevant to C-Channel columns under eccentric loads
Structural engineers, civil engineering students, and professionals involved in the design and analysis of columns under eccentric loading conditions.
subbby
hi,
can anyone help me with the formula for a vertical Column (C-Channel) subjected to Eccentric Loading?
Regards,
Subbby
m sorry... COLUMNS ARE VERTICAL...
Since your section is not symmetric you need to start by drawing the section and calculating the principal moments of inertia.
Then you need to present a section showing the position of the loading to anyone trying to help.
