The Secrets of Regeneration: DNA and Re-Growth
  • Thread starter Thread starter wolram
    Dna
The discussion focuses on the mechanisms of regeneration in organisms, particularly how DNA and genetic factors influence the ability to regrow body parts. Participants explore various biological concepts related to regeneration, including the role of Hox genes and the behavior of stem cells, as well as specific examples from organisms like earthworms and fruit flies.
  • Some participants propose that regeneration is controlled by Hox genes, which determine the location and type of body parts in an organism.
  • Warren suggests that stem cells are activated by chemical signals during injury, moving to the site to aid in healing and regeneration.
  • Another participant mentions that earthworms have multiple hearts distributed along their bodies, which may contribute to their ability to survive and regenerate after being cut in half.
  • It is noted that while earthworms can regenerate, the extent of regeneration varies, with the head end typically being more capable of regeneration than the tail end.
  • Some participants express uncertainty about the molecular biology of segment regeneration and seek further information on the topic.
Participants generally agree on the involvement of Hox genes and stem cells in regeneration, but there are differing views on the specifics of regeneration capabilities in different organisms, such as earthworms and fruit flies. The discussion remains unresolved regarding the detailed mechanisms and limitations of regeneration.
Limitations include a lack of consensus on the molecular mechanisms underlying regeneration and the specific roles of various genes and signals involved. Some assumptions about the regenerative capabilities of different species remain unverified.
wolram
Dearly Missed
When cut in half they can regrow the severed part, but how?
is the information that enables this re growth encoded in the
DNA, what mechanism initiates this re growth.
Biology news on Phys.org
I'm no biologist, and all of this is from memory, so it's probably mostly wrong.
AFAIK, body part regeneration is controlled by the Hox genes, which essentially specify where all the body parts should be in an organism. If you take fruit flies and modify their Hox genes, they'll grow legs where their antennae should be, that sort of thing.
The Hox genes are responsible for expressing proteins or hormones that then instruct dividing stem cells in the body to differentiate into a specific kind of tissue. Differentiating cells figure out where they are in the body by essentially sniffing around for these chemical signals to see what's near them.
I also believe I have read that stem cells can be called into action by chemical signals of injury, and actually move through the body to the site of the injury to participate in the healing.
So, I believe the body part continues to grow from these stem cells until the proper location for say, skin is reached. Skin grows there, and the growth goes no further.
- Warren
Warren you are a trove of knowledge and an inspiring example:
inorganic techies and astronomers should all know about fruit flies and Hox genes as well
it is fascinating and it would do them good
Bravo.
I remember another detail.
Another thing that helps the severed worm is that
an earthworm (so my 9th grade science teacher told us)
can have multiple hearts----distributed all along its length
It might start out with 5 hearts and then it gets severed into
a piece with 2 and a piece with 3
so the pieces can keep functioning and can both thrive
and go around eating dirt as nature intended
and, in the course of time, grow longer
the earthworm is somewhat modular in design
its other organs including even its thinking apparatus
are distributed along its length, according to my teacher,
in a similarly modular fashion.
http://www.naturenorth.com/fall/ncrawler/ncrawlF.html
Worms can survive being cut in half! Well, for a little while, at least. It is usually only the head end that will regenerate some segments in the lower end and become a viable worm again. The lower end cannot regenerate a head. However, most often, when cut in half, worms die.
The "brain", "hearts" and other organs are clustered in the head end.
http://www.scaquarium.org/curriculum/iexplore/three_five/units/decompositionI/decomp_background.htm
Earthworms, like seastars, are also capable of regenerating lost body parts. Both the head and the tail of an earthworm can be regenerated, within limits. The extent of regeneration depends on the species, as well as on the position of the "wound" and the size of the worm fragment that remains
I searching to find info on the molecular biology of segment regenration but results have been limited.
  • · Replies 29 ·
13K
