| Thread Closed |
Entropy Confusion |
Share Thread | Thread Tools |
| Apr14-10, 11:38 AM | #18 |
Entropy Confusion
I know this isn't technically the right place to post this, but it's so closely linked to the original point of the thread...
I'm doing a problem sheet on entropy now, and the question is "What is the entropy change of the universe when a block of mass 10kg is dropped from a height of 100m into a lake (which I suppose is at some height H < 100)?" My instinct is that you can treat GPE/KE as if it were heat, and height as if it were temperature (so g takes the role of specific heat capacity) and say that ∆S = ∆GPE/H - ∆GPE/100? |
| Apr14-10, 11:58 AM | #19 |
Recognitions:
You claim that in nonequilibrium systems, one cannot define a P or T, but I (me, my person) have a well-measurable temperature in spite of existing far from equilibrium. |
| Apr14-10, 12:14 PM | #20 |
If they appear inconsistent, then that is purely by my bad explaining, which of course would be my fault.
About your example: do you? I don't know a lot of biology, but in a strict sense I suppose your temperature is not exactly defined and fluctuates throughout your body. But that is not what I was really getting at. I was trying to say that there can be situations where very obviously you can't say what the temperature is and I thought you were thinking of those situations when you said SM fails, because you presumed that when T is non-defined, SM breaks down because it uses dT for example. My point was that indeed, in a physical sense dT makes no sense if T is not well defined, but SM does not have that problem because it defines T as a partial derivate of a quantity that is always well-defined. Does this clear things up? Still in disagreement? I'm not trying to get you convinced about my point so much as to see where you think SM breaks down. EDIT: gadje, about your problem, I wouldn't really know how to solve that. I do know however you can't just make up your own definition by replacing temperature with height and such (if you do, you'd have to show that it is compatible with the general definition). More about your problem: I find it interesting, but I think I'm missing something. Don't forget the formula you're thinking of , dS = dQ/T, is for gasses... |
| Apr14-10, 12:20 PM | #21 |
I think I've got it, actually. It's not what I have up there, upon thinking about it.
| Apr14-10, 12:25 PM | #22 |
What is your solution/method then?
| Apr14-10, 12:32 PM | #23 |
There's an earlier part of the question which talks about the lake being at 10 Celsius and being of a high specific heat. Dropping the block into the lake introduces mgh of energy into it, changing the entropy of the universe by mgh/T = 10*g*100/(10+273).
I think. |
| Apr14-10, 12:38 PM | #24 |
I agree with Mr. Vodka.
You can also consider Maxwell's Demon though experiment and the resolution of the paradox by Landauer to see that Classical Thermodynamics is incomplete. Of course that doesn't mean that statistical mechanics as it is used in practice doesn't have limitation due to the assumptions made there, but it is more fundamental. This is a bit similar to discussing whether quantum mechanics is more fundamental that classical mechanics. One could easily argue along the same lines that Andy does here to argue that Classical Mechanics can be applied to certain areas where quantum mechechanics as we know it cannot, because of issues such as the measurement problem. |
| Apr14-10, 12:53 PM | #25 |
gadje - that is indeed the entropy increase of the environment, (EDIT, first had something else following this) but I wonder if the entropy of the stone decreased. Should you see it as if there is a heat flow from the stone to the water? Maybe not, not sure...
Count Iblis - I wonder, does SM presume you are working with a reservoir as an environment? In the sense that the Tenv and Penv are constant. Anyway, the part of SM I have worked with always presumed this to derive free energy laws and such, but this does seem like one of the restrictions, unless I'm just wrong on the fact that it's an assumption in SM. |
| Apr14-10, 02:18 PM | #26 |
Recognitions:
I am confused as to what is meant by 'classical' thermodynamics, as opposed to thermodynamics. Is there quantum thermodynamics, as a distinct field?
I would be surprised if someone here claimed there is any process in the universe that does not obey the Clausius-Duhem inequality. By contrast, I can list of a long list of things not covered by statistical mechanics. Again, statistical mechanics is in no way more fundamental than thermodynamics. Simplified models do not elucidate the range of theory. As for my original objection (body temperature- the fact that my core body temperature fluctuates is not germane. I'm not sure what you mean by dT in the context of statistical mechanics. My central point is that statistical mechanics is not equipped to handle nonequilibrium systems. Onsager's relations are a linearization, and do not hold in general. By contrast, thermodynamics covers *everything physically allowed*. |
| Apr14-10, 05:25 PM | #27 |
Recognitions:
So, here's a simple challenge: solve this, and I will reconsider my earlier claims. Using SM, solve either Q(t) or T(t) in the OP's question. If SM is truly a more fundamental theory than thermodynamics, this should be trivial. |
| Apr14-10, 05:40 PM | #28 |
In many textbooks, thermodynamics and statistical mechanics are treated in a unified way. There is an introduction in which the fundamental postulate of equal prior probabilities is introduced. Then both thermodynamics and statistical mechanics are developed.
This is done in the book by F. Reif. He distinguishes this from classical thermodynamics; he points out that classical thermodynamics has more postulates than "statistical thermodynamics". Classical thermodynamics is basically early 19th century theory about Heat, temperature, work etc. developed by Carnot. Statistical thermodynamics is the modern version of this developed by Boltzmann, Gibbs etc. |
| Apr14-10, 05:49 PM | #29 |
Recognitions:
Statistical Mechanics: Statistical Thermodynamics: Classical Thermodynamics (or just Thermodynamics, as per Andy's usage): This would help me to better understand what y'all are discussing here. |
| Apr14-10, 05:57 PM | #30 |
Recognitions:
"...Andy does here to argue that Classical Mechanics can be applied to certain areas where quantum mechechanics as we know it cannot" Statistical mechanics is *not* a modern version of thermodynamics. Anyone that seriously tries to argue that knows little about either. Hiding behind a bad textbook is poor form. |
| Apr14-10, 06:10 PM | #31 |
Recognitions:
Statistical Mechanics: (classical or quantum) mechanics of a large number of discrete particles. Classical Thermodynamics: theory of heat and mass transfer Statistical Thermodynamics: A misguided amalgamation of the two. Distinctions: Statistical mechanics is a discretized approach, thermodynamics is a continuum approach. Statistical mechanics postulates 'states' and defines 'equilibrium' and is based on distribution functions and the existence of a partition function. Thermodynamics postulates 'temperature' and 'heat', and has been largely axiomatized (along with continuum mechanics). Thermodynamics also postulates the conservation of energy and second law. Statistical mechanics is a linear theory, thermodynamics is a nonlinear theory. Whether this is good or bad depends on your perspective. Limitations: statistical mechanics cannot calculate time-dependent behavior except in a very limited sense (involving equilibrium concepts). Thermodynamics requires constitutive relations that do not have a basis in physical theory. There's more, I'm sure... |
| Apr14-10, 06:43 PM | #32 |
I have to say that I think the whole SM v CT issue rather like the big endian v little endian argument in Gulliver's Travels.
They are both aspects of the same egg, each useful in their own way. In cases where they overlap they predict the same thing, unlike wave v corpuscular theory of light. Isn't that glorious corroberation? I can't let this pass however. |
| Apr14-10, 07:19 PM | #33 |
Hm, I've come to the realization I probably know too little to have enough insight for decent arguments.
But Andy Resnick, let me ask you one thing. SM has a rigid definition of entropy that in essence allows you to calculate the entropy of any situation (in practice, one might be lacking knowledge/skill to actually do it). But more importantly, and basically my question, how is entropy defined in classical thermodynamics? I was taught that dS = dQ/T viewed from a reversible process, but this definition is incredibly limited, so I assume there is a more general one out there that everybody has neglected to teach me. Could you tell me? EDIT: re-reading my post, it may sound as though I am sniping, but that wasn't meant that way, it was/is an honest question |
| Apr14-10, 09:04 PM | #34 |
Recognitions:
http://www.amazon.com/Perrys-Chemica...1296782&sr=1-1 or this: http://www.amazon.com/Basic-Principl...1296623&sr=8-6 or this: http://www.amazon.com/Introductory-C...1296623&sr=8-1 Attitudes like the one you express here are a reason why Physicists are taken less and less seriously by other technical folks. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Entropy Confusion
| String entropy and black hole entropy | Beyond the Standard Model | 3 | ||
| Entanglement entropy vs Entropy | Quantum Physics | 1 | ||
| minimize entropy of P == maximize entropy of ??? | Set Theory, Logic, Probability, Statistics | 2 | ||
| Is the Entropy of the Universe Zero?:(Entropy as Entanglement) | Quantum Physics | 10 | ||
| Entropy (information entropy) | Advanced Physics Homework | 5 | ||
