Heat transfer and GPM
by ISX
Tags: heat, transfer
ISX
ISX is offline
#1
Apr14-10, 08:40 PM
P: 116
I been debating this and figured you guys would know what the truth is. When you take the thermostat out of a vehicle, the flow is so high because of the thermostat not being a restriction, that the temperature gauge will hardly budge from whatever the lowest degree is, and if it does, it takes a long time. Now is this because it cannot extract heat with such high flow since heat needs time to transfer (meaning the engine might actually be overheated since the coolant is not grabbing any heat from it) or is this because the coolant is taking so much heat away from the engine that it keeps the temperature that low?
Phys.Org News Partner Physics news on Phys.org
Physicists design quantum switches which can be activated by single photons
'Dressed' laser aimed at clouds may be key to inducing rain, lightning
Higher-order nonlinear optical processes observed using the SACLA X-ray free-electron laser
russ_watters
russ_watters is offline
#2
Apr14-10, 09:11 PM
Mentor
P: 22,001
Welcome to PF.
It's because the heat transfer is so good that the coolant is taking heat away so easily it keeps the engine extra cool.
There is a somewhat counterintuitive principle at work here, which is probably why you are asking the question: The relationship between flow and delta-T (or heat removed) is not linear. A doubling of the flow rate does not result in a halving of the delta-T, it results in slightly more than half the delta-T and thus slightly more heat transfer than with the lower flow rate. This is because the approach temperature, the difference betwen the water temperature and the air temperature, is larger when the flow is higher and thus the heat transfer is more effective.
ISX
ISX is offline
#3
Apr14-10, 09:25 PM
P: 116
Ah, thanks for the help!
Register to reply
Related Discussions
rate of heat transfer / specific heat General Physics 2
Is the overall heat transfer coefficient constant for a certain heat exchanger? Advanced Physics Homework 0
heat transfer and latent heat Introductory Physics Homework 5
heat transfer & sound transfer General Physics 0
rate of heat transfer and heat conductors General Physics 3
