Anyone familiar with the fortran language?
  • Thread starter Thread starter Jauhar
    Fortran Language
The discussion revolves around programming in Fortran, specifically focusing on creating a program that reads a 3x3 array of real numbers, calculates the inverse of the matrix, outputs the original matrix, and multiplies two 3x3 matrices. Participants share code snippets, errors encountered, and seek assistance in debugging their Fortran code.
  • Homework-related
  • One participant shares their initial Fortran code and describes the intended functionality, including reading matrices and performing operations.
  • Another participant asks for clarification on the specific error encountered, suggesting it may relate to the variable 'cname'.
  • Some participants propose that the error is due to the format statement and suggest removing unnecessary STOP and RETURN statements.
  • A participant mentions a specific error message regarding an unknown edit descriptor and offers suggestions for correcting the format statement.
  • There are discussions about simplifying the code by using a single subroutine for input and output, but some express confusion about the implications of this change.
  • Participants share different approaches to handling input and output, including suggestions for using PRINT statements as alternatives.
  • One participant expresses frustration with the complexity of the code and their inexperience with Fortran, seeking further clarification on how to structure their program.
  • Another participant emphasizes the importance of proper formatting in Fortran and suggests that the first output should include page control.
Participants generally agree that the errors are related to the format statements and the handling of subroutine arguments. However, there is no consensus on the best approach to simplify the code or resolve the errors, as different participants suggest varying methods.
Participants express uncertainty about specific Fortran syntax and the implications of passing arguments to subroutines. There are unresolved questions about the structure of the program and the correct implementation of matrix operations.
Individuals learning Fortran, those interested in matrix operations, and programmers seeking to debug similar code may find this discussion helpful.
Jauhar
hello all
Im new here but is anyone familiar with the fortran language? I need to make a program to do the following:
a) read a 3x3 array of REAL NUMBERS
b) calculate the inverse of the 3x3 matrix
c) write out the answer and the original Matrix
d) multiply two 3x3 matrices.
this is what i have so far but i keep gettin an error with it.
DIMENSION A(3,3)
DIMENSION B(3,3)
DIMENSION C(3,3)
CALL INPUTS(A)
CALL OUTPUTS(A)
CALL IN(B)
CALL OUT(B)
CALL ANSWERS(A,B,N,C)
STOP
END
SUBROUTINE INPUTS(A)
DIMENSION A(3,3)
DO 100 IROW=1,3
DO 100 ICOL=1,3
WRITE(*,200) IROW, ICOL
READ(*,*) A(IROW,ICOL)
100 CONTINUE
200 FORMAT('Enter elements of Matrix A (',I1,',',I1,') = ')
RETURN
END
SUBROUTINE OUTPUTS(A)
DIMENSION A(3,3)
WRITE(*,*) 'Matrix A will be'
DO 300 IROW=1,3
WRITE(*,400) (A(IROW,ICOL),ICOL=1,3)
300 CONTINUE
400 FORMAT(3F7.1)
RETURN
END
SUBROUTINE IN(B)
DIMENSION B(3,3)
DO 500 IROW=1,3
DO 500 ICOL=1,3
WRITE(*,600) IROW, ICOL
READ(*,*) B(IROW,ICOL)
500 CONTINUE
600 FORMAT('Enter elements of Matrix B (',I1,',',I1,') = ')
RETURN
END
SUBROUTINE OUT(B)
DIMENSION B(3,3)
WRITE(*,*) 'Matrix B will be'
DO 700 IROW=1,3
WRITE(*,800) (B(IROW,ICOL),ICOL=1,3)
700 CONTINUE
800 FORMAT(3F7.1)
RETURN
END
SUBROUTINE ANSWERS(a,b,n,c)
DIMENSION a(n,n),b(n,n),c(n,n)
C(1,1)= A(1,1)*B(1,1)+A(1,2)*B(2,1)+A(1,3)*B(3,1)
C(1,2)= A(1,1)*B(1,2)+A(1,2)*B(2,2)+A(1,3)*B(3,2)
C(1,3)= A(1,1)*B(1,3)+A(1,2)*B(2,3)+A(1,3)*B(3,3)
C(2,1)= A(2,1)*B(1,1)+A(2,2)*B(2,1)+A(2,3)*B(3,1)
C(2,2)= A(2,1)*B(1,2)+A(2,2)*B(2,2)+A(2,3)*B(3,2)
C(2,3)= A(2,1)*B(1,3)+A(2,2)*B(2,3)+A(2,3)*B(3,3)
C(3,1)= A(3,1)*B(1,1)+A(3,2)*B(2,1)+A(3,3)*B(3,1)
C(3,2)= A(3,1)*B(1,2)+A(3,2)*B(2,2)+A(3,3)*B(3,2)
C(3,3)= A(3,1)*B(1,3)+A(3,2)*B(2,3)+A(3,3)*B(3,3)
WRITE(*,*) 'Matrix C is, the multiplication of matrices A & B'
DO 1000 IROW=1,3
WRITE(*,1100) (C(IROW,ICOL),ICOL=1,3)
1000 CONTINUE
1100 FORMAT(3F7.1)
Stop
END
I have been told it could cut down to this but i also get an error with this:( .
DIMENSION B(3,3)
CALL INPUT1(A,'A')
CALL OUTPUT1(A,'A')
CALL INPUT1(B,'B') ! same subroutine, different arguments
CALL OUTPUT1(B,'B') ! same subroutine, different arguments
STOP
END
SUBROUTINE INPUT1(x,cname)
DIMENSION x(3,3)
DO 100 IROW=1,3
DO 100 ICOL=1,3
READ(*,*) x(IROW,ICOL)
100 CONTINUE
200 FORMAT ('Enter elements of Matrix ',cname,' (',I1,',',I1,') = ')
RETURN
END
SUBROUTINE OUTPUT1(x,cname)
DIMENSION x(3,3)
WRITE(*,*) 'Matrix ',cname,' will be'
DO 700 IROW=1,3
WRITE(*,800) (x(IROW,ICOL),ICOL=1,3)
700 CONTINUE
800 FORMAT(3F7.1)
STOP
END
Hope someone can help I am desperate for it :) .. PLease HELP
Computer science news on Phys.org
What is the error you get?
maybe something with the "cname"? I (quickly) copied and pasted and executed in emacs and mine came up with an error about cname.. I'd mess with it more but I have some sleep to catch up on.
Yes the errror is with the cname but i can't figure it out I've kept trying i spent basically the whold day on it :eek: :redface:
Anyways and a newb to it tht could be why what i appreciate the help.
Thanks a lot :approve:
bumpy bump
Where do you specify the variable type of cname?
this is the error i get
error 274 - Unknown edit descriptor 'C', or missing comma
Ive tried everything forgive me if i can't answer all the questions u see I am extremely new to fortran
I think it is an error in format statement.
First off ; get rid of all STOP statements ... those are used only for fatal error traps.
Next : get rid of all RETURN statements .. they are redundant : END is the same as RETURN.
When you compiler gives error report it will tell you line # of error ... use it.
First output for write statement is 1X in the format statement.
This is required for proper page control (first out is page control).
Example:
WRITE(*,'(1X,1P5E10.3)') FOM0,FOM1,FOM2,FOM3,FOM4
Don't use the literal passing, no reason to go this complicated method and it's all wrong anyway, just pass the arguments like in first method.
Invert not too much more complicated than multiply :
[itex] \[<br /> \,[Z] = \frac{1}{{Y_{11} (Y_{22} Y_{33} - Y_{23} Y_{32} ) + Y_{12} (Y_{31} Y_{23} - Y_{21} Y_{33} ) + Y_{13} (Y_{21} Y_{32} - Y_{31} Y_{22} )}} \cdot \left[ {\begin{array}{*{20}c}<br /> {Y_{22} Y_{33} - Y_{23} Y_{32} } \hfill & {Y_{13} Y_{32} - Y_{12} Y_{33} } \hfill & {Y_{12} Y_{23} - Y_{13} Y_{22} } \hfill \\<br /> {Y_{31} Y_{23} - Y_{21} Y_{33} } \hfill & {Y_{11} Y_{33} - Y_{13} Y_{31} } \hfill & {Y_{13} Y_{21} - Y_{23} Y_{11} } \hfill \\<br /> {Y_{21} Y_{32} - Y_{31} Y_{22} } \hfill & {Y_{31} Y_{12} - Y_{32} Y_{11} } \hfill & {Y_{11} Y_{22} - Y_{12} Y_{21} } \hfill \\<br /> \end{array}} \right]<br /> \][/itex]
If you are going to do the invert, make sure to prove the above (maybe i blew a subscript).
Best
I think I'm going to move this to 'Software'
[pushes button]
[pushes button] : confused everyone.
thanks for the help The error is with the Format statement but i still can tsort it out i removed the stop and return statements but it didnt help. :(
Thanks big time for the help. I have no idea what more to do but i will keep messin with it.
200 FORMAT(1X,'Enter elements of Matrix A (',I1,',',I1,') = ',\)
Does that work ? Put the entire line here that has the syntax error. Or here is a quick and dirty way :
PRINT*,'INPUT 9 NUMBERS'
READ*,C(1,1),C(1,2),C(1,3),C(2,1),C(2,2),C(2,3),C(3,1),C(3,2),C(3,3)
FORTRAN manuals really have a derth of examples. In the above method ; separate inputs with commas or spaces.
Best
hello OK that just got rid of the error thanks. Now i got this for the Subrotines Also for the main program the first part what would be the correct way to write it in Because initially i have the variables A and B but now i dont. Sorry about being such a newb :).
SUBROUTINE INPUT1(x)
DIMENSION x(3,3)
DO 100 IROW=1,3
DO 100 ICOL=1,3
100 CONTINUE
END
DIMENSION x(3,3)
DO 700 IROW=1,3
700 CONTINUE
800 FORMAT(3F7.1)
END
Thanks big time for tht
"I have been told it could cut down to this but i also get an error with this:( ."
"Don't use the literal passing, no reason to go this complicated method and it's all wrong anyway, just pass the arguments like in first method."
If you insist on passing by value, you need to declare ! Why are you passing cname ?
And i told you before : the first byte output is page control ... use a 1x first.
SUBROUTINE OUTPUT1(x)
DIMENSION x(3,3)
WRITE(*,*) 'Matrix will be'
DO 700 IROW=1,3
700 CONTINUE
800 FORMAT(1x,3F7.1)
END
First 3 steps look like one program to me, step d another program ? Or maybe it implies you multiply the original matrix by the invert and also print out the result of that (course it is I).
Best
ohh i think i might be getting it but slowly.
Thanks
Keep going is helpful
Best
d) is to multiply 2 3x3 Matrices i don't think by the inverse just simply two matrices A and B to get C. Cant it be done on same program?
also I am getting a run time error now :shy: have u tried compiling it this is beginning to give me a headache i don't think programming is my thing :redface:
Hard for me to compile it as i don't know what you source looks like now, besides, my compiler's on other machine. Don't give up so easy. Let's look at your main program :
CALL INPUTS(A)
CALL OUTPUTS(A)
CALL IN(B)
CALL OUT(B)
Say we want to do the first 3 steps, then :
PRINT*,'Input Matrix to be Inverted'
CALL INPUT(A) ... gets the array data
CALL INVERT(A,B) ... inverts the 3x3 matrix and returns result in B
PRINT*,'Input Matrix is :'
CALL OUTPUT(A) ... outputs the original (input) matrix
PRINT*,'Inverse is :'
CALL OUTPUT(B) ...outputs the inverted matrix ... done ! !
if you want to also multiply two matricies together ... you got to get the matricies from someplace ... so you can input them both like :
PRINT*,'Input first matrix for multiplication'
CALL INPUT(A) ... we can use the same storage to input another array
PRINT*,'Input second matrix'
CALL INPUT(B) ... get another matrix from the operator
CALL MULT(A,B,C) ... multiply em together and return result in C
PRINT*,'First Input Matrix is :'
CALL OUTPUT(A)
PRINT*,'Second Input Matrix is :'
CALL OUTPUT(B)
PRINT*,'Product Matrix is :'
CALL OUTPUT(C)
END
So need subroutines INPUT,OUTPUT,INVERT and MULT only.
Best
hi ok I just tried again
and am using ur advice thanks again for ur time.
But what does this mean "MAIN# - in file aaa.f95 at line 1 [+0044] [recur= 1]"
Thts the runtime error i got. I put the subrotiines and the main prog in there were no errors in compiling.
Its actually being to make sense to me now slowly :). This fortran is quite kool i may need it in my calculations for aero later on.
Don't know what that error is. Do you use a PROGRAM statement ?
First line of your program should be PROGRAM MYPROG or what you want for a name.
Also i assume you got rid of those pass by value calls ?
Best
hi
Yeah i had a program statement its PROGRAM MATRIX. The program strts and gives the first statement "Input Matrix to be Inverted" The the error comes up.
Best
ya i got rid of those calls...
hi hope ur all well...
OK I've tried this program. But i got probs again. when i execute the old proram which i had. It answered my first question which was to: read a 3x3 array of REAL NUMBERS. the program was.
DIMENSION A(3,3)
DIMENSION B(3,3)
CALL INPUTS(A)
CALL OUTPUTS(A)
CALL IN(B)
CALL OUT(B)
END
DIMENSION A(3,3)
DO 100 IROW=1,3
DO 100 ICOL=1,3
100 CONTINUE
end
DIMENSION A(3,3)
DO 300 IROW=1,3
300 CONTINUE
400 FORMAT(3F7.1)
end
SUBROUTINE IN(B)
DIMENSION B(3,3)
DO 500 IROW=1,3
DO 500 ICOL=1,3
500 CONTINUE
end
SUBROUTINE OUT(B)
DIMENSION B(3,3)
DO 700 IROW=1,3
700 CONTINUE
800 FORMAT(3F7.1)
END
this program Asked me for the input and then Gave me an output in matrix form for 2 matrices A and B.
But when i try the new program which flexten kindly helped me with it doesn't get past the first input which is inverse.
so basically how can i get the program to store the matrix which i input in the above program and then make it inverse it. I've tried but it doesn't execute and comeup with run time errors.
Thanks for you help
:eek: :smile: :surprise: :cry: :zzz: :blush: :bugeye: :rolleyes:
I need help writing a fortran subroutine that given a set of N numbers and integer i, determine the ith smallest number. I need the subroutine to be recursive and use the median of medians method to sort the array of input numbers and output the ith smallest number. Can anyone help please?
  • · Replies 17 ·
  • · Replies 20 ·
  • · Replies 17 ·
  • · Replies 17 ·
11K
