Calculating Driving Force on a Conveyor Belt with Baggage Load?
  • Thread starter Thread starter gaobo9109
    Belt Conveyor
The discussion focuses on calculating the driving force required to maintain the motion of a conveyor belt carrying baggage. The conveyor belt operates at a constant speed of 1.5 m/s, with an average baggage load rate of 20 kg per second. The driving force is calculated using the formula F = dm/dt * v, resulting in a force of 30N. The reasoning provided confirms that since the velocity is constant, the change in momentum is directly proportional to the rate of mass flow and the speed of the belt.
  • Understanding of Newton's laws of motion
  • Basic knowledge of momentum and force calculations
  • Familiarity with the concept of mass flow rate
  • Knowledge of conveyor belt mechanics
  • Study the principles of Newton's second law of motion
  • Learn about momentum conservation in mechanical systems
  • Explore the dynamics of conveyor belt systems
  • Investigate the effects of varying load rates on driving force calculations
Mechanical engineers, physics students, and professionals involved in material handling systems will benefit from this discussion, particularly those focused on conveyor belt design and operation.
gaobo9109
A conveyor belt consists of a horizontal endless belt running over driving rollers, moving at a constant speed of 1.5m/s. To keep the belt moving requires a greater driving force than for an empty belt. On average, the rate at which baggage is placed on one end of the belt and lifted off at the other end is 20 kg per second.
For this question, the answer is simply 1.5 x 20 = 30N, but I am not sure of the exact explanation for such working.
My own attempt at the solution is at follow:
Rate of change of mass dm/dt = 20
Change of momentum of one baggage = m(1.5 - 0)
Force needed to this change of momentum = dp/dt = dm/dt x v = 1.5 x 20 = 30N
I am not sure whether my reasoning is correct
I agree with the answer ..
Force = dp/dt , p = mv , then, F= d(mv)/dt = dm/dt *v + dv/dt *m .. since it said that the velocity is constant, then dv/dt = 0 .. that yields to F = dm/dt *v , which is the answer you got .. :)
