Stopping a potter's wheel with a wet rag (angular momentum and friction)
The discussion focuses on calculating the effective coefficient of kinetic friction between a potter's wheel and a wet rag used to stop the wheel. The potter's wheel has a radius of 0.55 m and a moment of inertia of 11.6 kg·m², rotating at 55 revolutions per minute. The solution involves converting rotational speed to radians per second, calculating the necessary acceleration, and applying torque equations. The final effective coefficient of friction is determined to be approximately 0.07656 using the relationship between torque, moment of inertia, and frictional forces.
  • Understanding of rotational dynamics, specifically torque and moment of inertia.
  • Familiarity with the conversion of rotational speed from revolutions per minute to radians per second.
  • Knowledge of the relationship between force, mass, and acceleration in rotational motion.
  • Basic grasp of frictional forces and their role in stopping motion.
  • Study the principles of torque and its applications in rotational motion.
  • Learn about the derivation and application of the moment of inertia for various shapes.
  • Explore the relationship between linear and angular acceleration in physics.
  • Investigate real-world applications of friction in mechanical systems, particularly in stopping mechanisms.
Physics students, mechanical engineers, and anyone interested in the principles of rotational motion and friction in practical applications.
Number47
A potter's wheel having a radius 0.55 m and a moment of inertia 11.6 kg·m2 is rotating freely at 55 rev/min. The potter can stop the wheel in 8.0 s by pressing a wet rag against the rim and exerting a radially inward force of 66 N. Find the effective coefficient of kinetic friction between the wheel and the wet rag.
for a solid wheel I = (1/2)m*R^2
I started off converting 55rpm into 5.76 rad/s. I then divided 5.76rad/s by 8.00s to get the needed acceleration to stop the wheel and got -.72rad/s^2. Next i solved for the mass of the wheel by dividing the moment of inertia by .5*R^2 and got 7.018kg.
I figured by setting the force needed to stop the wheel equal to the force applied by the rag times the coefficient of friction i could divide the applied force on both sides and end up with the COF: m*a = F*u u=(m*a)/F u= (7.018kg*-.72rad/s^2)/66N = .07656
if you're going to use tangential acceleration, you have to multiply the rotational acceleration by the radius
and
you assumed that the potter's wheel could be approximated by I = .5 MR^2 when you didn't need to.
This problem is much more easily solved by using torques.
Recall that torque = moment of inertia x rotational acceleration
t = I a
you found rotational acceleration successfully
Now you need to find the torque from friction
Recall that torque = radius x force x sin (angle between them)
t = r x F x sin 90
Friction = mu x normal force
= u N
so the torque t = r u N
now set torques equal, r u N = I a
and solve for u
you do have to memorize a couple of equations for torques, but once you do a lot of problems become a lot easier to figure out
9K
  • · Replies 188 ·
13K
