What's the boundary between micro and macro?
  • Context: Graduate
  • Thread starter Thread starter ryokan
    Boundary Micro
The discussion revolves around the boundary between microscopic and macroscopic systems in the context of thermodynamics and statistical mechanics. Participants explore the conditions under which a system transitions from being analyzed through kinetic theory to thermodynamic principles, particularly in biological contexts like live cells and their components.
  • One participant suggests that thermodynamics applies to macroscopic systems where statistical mechanics is relevant, questioning the threshold of molecule count for this transition.
  • Another participant notes that thermodynamic equations assume a continuous medium and that the characteristic length must exceed a certain threshold for thermodynamic principles to be valid.
  • A different viewpoint introduces the concept of wavelength, proposing that the transition occurs when the wavelength of an object becomes significant compared to the system size, with larger masses behaving more like macroscopic objects.
  • Some participants inquire about calculating the free characteristic running for live cells, discussing its definition and relevance to thermodynamic behavior.
  • One participant describes a cell as a colloidal solution and discusses the structure of biological membranes, emphasizing the complexity of live cells.
  • Another participant raises a question about the number of particles needed to transition from classical mechanics to statistical mechanics using an ideal gas as an example.
  • Several participants express uncertainty about the specific thresholds and conditions that define the transition between microscopic and macroscopic views.
Participants express various viewpoints on the boundary between micro and macro systems, with no clear consensus on the specific conditions or thresholds that define this transition. Multiple competing views remain, particularly regarding the application of thermodynamics and statistical mechanics in biological contexts.
Limitations include the lack of specific definitions for the thresholds discussed, the dependence on the context of biological systems, and unresolved mathematical steps related to the application of thermodynamic principles.
ryokan
Thermodynamics treats with macroscopic systems, where statistical mechanics make sense. In these systems there is an arrow of time following the second law. On the contrary, temporal reversibility is generally seen at microscopic level.
What is the limit (magnitude order in number of molecules or other) where a physics system must be seen from a thermodynamic viewpoint?
One isolated live cell would be a thermodynamic system: it ages. That also occurs in subcellular systems as mitochondria. But, what's about a discrete sample of cell macromolecules? Make it sense to talk on thermic differences inside a live cell?
¿When a microscopic system should be named macroscopic and to be object of thermodynamics?
Science news on Phys.org
Hey, another spanish over here!. :-p The moment in which official language of this forum will be the spanish is nearby...
Your question is very interesting. Thermodynamics employs some results of the kinetic theory. To be honest, I don't know what is the amount of molecules neccesary in the limit between Thermodynamic and Kinetic Theory. But you should know when we employ thermodynamics equations (like first principle), we are assuming the next hypothesis implicitly:
The continuous medium: inside a thermodynamic system there have to be a minimum amount of molecules. How many?. The neccesary such density function (rho(x,y,z,t)) is continuous and derivable in space and time. This critical amount is reached when thermodynamics variables changes smoothly enough to be yielded in thermodynamics differential equations. This threshold is reached when the infinitesimal volume analyzed has a characteristic length larger than the free characteristic running (recorrido libre característico).
When smaller scales are analyzed, thermodynamics equations are not valid at all, in part because their differential operators have no sense.
Are you waiting for a global theory?. Well, sit down and wait, wait long... :zzz:
I believe the difference occurs when the wavelength of the object is large enough in the system not to be ignored, each object with mass has a particular wavelength
electrons have wavelengths of the order of the atom hence quantum mechanics , but protons having 1000 x mass , have far smaller wavelengths hence nuclear physics .
The mass of a cell by comparison is huge and it's wavelength extremely small so as a whole it behaves as a macro object.
QUOTE]
Sí. :smile:
How could we calculate this free characteristic running for objects such as a live cell?
ryokan How could we calculate this free characteristic running for objects such as a live cell?[/QUOTE said:
I know very little about biology. I can offer you the definition of the free characteristic running like the length run by a molecule without crashing into another.
In a simplistic view, a cell is a colloidal solution isolated by a lipidic membrane. Inside the cell there are also membranes isolating subcellular structures:
Please see the figures of http://www.emc.maricopa.edu/faculty/farabee/BIOBK/BioBookCELL2.html#The%20Cell%20Membrane
Quantitatively, the most abundant intracellular molecule is water.
Membranes are constituted by a fluid phospholipid bilayer where "float" proteins with more or less freedom. In this structure, two types of molecules are important: phospholipids (hydrophobic interaction) and proteins (freedom to move into the bilayer
Of course, a live cell is a very complex system.
I have seen some works (very few) where a mesoscopic approach was used to study lipid bilayers (the basic structure of a biological membrane).
This is an example: http://www.biophysj.org/cgi/reprint/83/6/3357.pdf
In a simple system, such a as a collection of hydrogen molecules, what would be the magnitude order of particle number to pass from a classical mechanics view to a statistical mechanics approach?
I have not any idea about Biology, but I'm going to explain you how is it done with an ideal gas.
Inside an arbitrary volume, there will be certain number of molecules according to the gas density. Then, obtain the average volume filled by only one molecule. The main free path [tex]\lambda[/tex] is the cubic root of this volume.
For [tex]d<<\lambda[/tex] it will be impossible to employ classical thermodynamics due to severe changes in density [tex]\rho[/tex].
Best regards.
Ah! and damn USA basketball team! They have kicked us off out of Olimpic Games!
Brrrr... :mad: :mad: :cry:
Best regards.
Thank you for your answer Clausius2.
:smile:
Los españoles somos la leche, en cuanto nos vemos por el mundo adelante nos dedicamos a armarla buena jeje ...
Digo yo, si a este mensaje sólo respondemos españoles, para qué hablar en inglés ?
Creo que la termodinámica establece la frontera en donde la cuántica empieza a fastidiar un poco.
Saludos
Saludos
Ya, pero lo lee más gente de la que contesta. :rolleyes:
Of course, there is a boundary between the classical mechanics description and the thermoynamic view. I think that for a simple collection of particles, the answer of Clausius2 is enough clear.
Saludos. Me alegro de que haya presencia española en este foro. :smile:
  • · Replies 41 ·
  • · Replies 39 ·
  • · Replies 26 ·
26K
  • · Replies 17 ·
  • · Replies 19 ·
  • · Replies 135 ·
13K
