Thread Closed
[SOLVED] You can't solder in zero-gee
Share Thread Thread Tools
Aug17-04, 11:26 AM   #1
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>\n\nHere\'s the latest research on forming solder joints in the atmosphere of the\nShuttle in zero-gee.\n\nhttp://science.nasa.gov/headlines/y2004/16aug_solder.htm?aol786992\n\nApparently, the attraction of the solder to the surface is not aided by\ngravity, and it won\'t flow. Additionally, the rosin forms a sphere, likely due\nto surface tension, and performs the same dance around the ball of solder that\nyou see if you flick a droplet of water on your fry pan to check if it\'s hot\nenough for pancakes: the droplet is supported by and yet insulated by the vapor\nat the interface, with chaos determining the direction in which it will move.\n\n\nYours,\n\nDoug Goncz ( ftp://users.aol.com/DGoncz/incoming )\nStudent member SAE for one year.\nI love: Dona, Jeff, Kim, Mom, Neelix, Tasha, and Teri, alphabetically.\nI drive: A double-step Thunderbolt with 657% range.\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form">&nbsp;&nbsp;View this Usenet post in original ASCII form </a></div><P></jabberwocky>Here's the latest research on forming solder joints in the atmosphere of the
http://science.nasa.gov/headlines/y2....htm?aol786992
gravity, and it won't flow. Additionally, the rosin forms a sphere, likely due
you see if you flick a droplet of water on your fry pan to check if it's hot
Yours,
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Thread Closed
Thread Tools
Similar Threads for: [SOLVED] You can't solder in zero-gee
Thread Forum Replies
Iron free solder for electronics. Electrical Engineering 23
The right size solder? Electrical Engineering 2
Solder iron Electrical Engineering 7
My house has Lead Solder on One of the Pipes General Discussion 9
what type of oven heats up metal (solder) faster than cured polymer? General Physics 3
