alpha_wolf
- 163
Does anybody here know the refraction index of paper? I couldn't find any info on this... Any kind will do.
The discussion revolves around the refractive index of paper, exploring its measurement challenges, the influence of paper composition, and the availability of information on this topic. Participants consider both theoretical and practical aspects of the refractive index in relation to different types of paper.
Participants express differing views on the transmission of light through white paper and the challenges of measuring its refractive index. There is no consensus on the refractive index value or the best methods for obtaining it.
Participants acknowledge that the composition of paper significantly influences the refractive index, and the discussion highlights the potential variability in values based on different types of paper.
First, that's not quite correct. A standard sheet of white paper, such as the type used in printers, does in fact transmit visible light, and probably other parts of the spectrum as well. Sure, the light is scattered, but nevertheless it is transmitted. Even if the light is being transmitted through the gaps between the fibers, and the fibers are opaque, even the most opaque materials transmit light for a short distance. Further, what's opaque in one wavelength is not necessarily opaue in another.Claude Bile said:One, white paper does not transmit light in any part of the optical spectrum, so measuring such a refractive index would be rather difficult.
Ok, but like I said, any kind would do. I only need an estimate, so even if the value is even remotely accurate only for that particlar kind of paper, it will be enough.Two, the composition of the paper, would have a large influence on what the refractive index would be. Even if you managed to find a value, it would only be valid for a particular composition of paper.
