Magnetic flux generated by a motor coil
The discussion focuses on calculating the magnetic flux generated by a motor coil, specifically with and without an iron core. Key equations mentioned include the magnetic field of a solenoid, represented as B = (μ)NI/H, where μ is the permeability constant, N is the number of turns, I is the current, and H is the height. Additionally, the magnetic flux is defined as flux = BAcos(x), where A is the cross-sectional area. The use of Biot-Savart Law for visualizing the magnetic field surrounding the coils is also addressed.
  • Understanding of magnetic field equations, specifically for solenoids
  • Knowledge of magnetic flux calculations and related formulas
  • Familiarity with Biot-Savart Law for magnetic field visualization
  • Basic concepts of electromagnetism and magnetic permeability
  • Research the application of Biot-Savart Law in calculating magnetic fields
  • Study the effects of iron cores on magnetic flux in motor coils
  • Explore advanced magnetic field visualization techniques
  • Learn about the relationship between current, turns, and magnetic field strength in solenoids
Engineers, physicists, and students involved in electromagnetism, particularly those interested in motor design and magnetic field analysis.
sebitab
Hi,
I am not so good with magnetic equations and I am needing some advice in how to start to calculate the magnetic flux generated by a motor coil.
Finally I want to be able to calculate the magnetic flux generated with and without the iron core of each coil in the motor.
I will appreciate all information, help and links to learn about the matter.
how about the magnetic field of a current carrying solenoid .
B=(mu)NI/H (Mu)=permeability constant N= number of turns
I= current H=height
http://en.wikipedia.org/wiki/Solenoid
flux=BAcos(x)
where A= cross sectional area.
Is this what your getting at .
Thanks for your answer. But if I want to draw the magnetic field surrounding the coils and the collaboration between them canceling or summing force, It is correct if I do this with Bio Savart law?
  • · Replies 43 ·
  • · Replies 16 ·
18K
