Calculating Optimum Distance for Focusing Diverging Light
  • Context: Undergrad
  • Thread starter Thread starter tommyers
    Light
The discussion revolves around calculating the optimum distance between a diverging light source and a biconvex lens for effective focusing of the beam. Participants explore theoretical and practical aspects of lens configuration, collimation, and beam intensity, with a focus on optical efficiency and aberrations.
  • Tom questions how to calculate the optimum distance for focusing a diverging beam with a biconvex lens, suggesting that covering the entire lens surface may enhance efficiency.
  • Some participants propose that expanding the beam to fill the lens's entrance pupil allows for better focusing, though they note that aberrations may affect the outcome.
  • There is a suggestion that collimating the incident beam is important to minimize aberrations, with some participants discussing the potential need for additional lenses to achieve this.
  • Tom expresses concern about the cost of using a collimating lens and seeks alternatives, indicating a divergence angle of 5 degrees for his light source.
  • One participant clarifies that placing the biconvex lens at its focal length from the source can collimate the beam, but acknowledges that additional lenses may be necessary for optimal results.
  • Another participant confirms that using two biconvex lenses can achieve collimation and focusing, while also addressing the implications for beam intensity when focused to a point.
  • There is mention of the lensmaker's equation as a method to calculate focal lengths, though some participants express confusion about its application.
  • A new participant introduces a scenario involving collecting light from a distant source (30 meters away) and seeks advice on collimation for spectroscopy, leading to a discussion on the nature of light at such distances.
Participants exhibit a mix of agreement and disagreement regarding the necessity of collimation and the specific configurations of lenses required. There is no consensus on the best approach to achieve optimal focusing, and various models and assumptions are presented without resolution.
Some participants note the importance of considering aberrations and the need for beam expansion or collimation, while others highlight the limitations of using a single lens. The discussion includes various assumptions about the light source and lens properties that may not be universally applicable.
This discussion may be of interest to individuals involved in optics, lens design, or applications requiring precise light focusing, such as spectroscopy or imaging systems.
tommyers
Hi,
If I have a diverging light source, incident on a biconvex lens used for focusing the beam to a point.
How would one calculate the optimum distance between the lens and the beam source for optimum focusing? May question arises because I would expect the lens to be more efficient at focusing if the diverging beam covered the entire surface area of lens as opposed to a small spot on the lens surface, as would be the case if the source and lens were moved closer together.
Obviously, if the diverging beam spread the entire surface area and more, then optical power would be lost, right?
Any useful equations or links?
Regards,
Tom
Science news on Phys.org
Expanding the beam to 'fill the entrance pupil' (the beam illuminates the whole lens) will allow use of the full numerical aperture of the lens- this will enable the tightest focusing (aberrations/misalignment = YMMV).
You should also collimate the incident beam as best as possible- the reason is (again) abberatons.
Do you mean to use a collimating lens?
My light source has a divergence angle of 5 deg, and I wanted to use a biconvex lens to act as a condenser to focus the beam to a point.
I was hoping not to have to use a collimating lens due to the low cost nature of the application.
Regards,
Tom
Regards,
Tom
Placing the biconvex lens it's focal length away from the source will collimate the beam. If you're lucky enough the resulting beam will have a diameter close to whatever aperture you're trying to fill. Otherwise you will have to get a second lens to make a beam expander/collimator.
Edit:
I just re-read it. Yes you will need another lens for the collimation. Possibly two lenses to get the beam to the right size to fill the focusing lens.
Another option is to just use an aspheric lens which always focuses light at a point but this would be much more expensive.
OK, so I have my diverging source. One biconvex lens will collimate the diverging beam, another biconvex lens will take the collimated beam and focus it at its focal length?
Two asides:
1) If my assumption above is correct, then between the two biconvex lens (where the beam is collimated) I could use a filter which relies on a collimated beam? (whose incidence angle is 0 deg)?
2) How does the intensity of the beam increase when focused to a point?
Regards,
Tom
Two asides:
Regards,
Tom
Your assumption is correct but as Andy mentioned you need to be aware of aberrations unless the beam fills the entire lens (reason why you might want to have a beam expander/collimator using two lenses instead of one).
1) is correct
2) instead of having a beam radius of say a couple of millimetres you will have a diffraction limited beam radius (ignoring aberrations and other optical effects) which will be on the order of nanometres. As such your intensity/unit area (or volume) will increase between a thousand- and a million-fold
Its not a matter of distance between the lens and the beam, it’s the distance between the lens and the desired focal point. If it’s a biconvex lens it can be calculated like this.
Lensmaker's equation
The focal length of a lens in air can be calculated from the lensmaker's equation
1 1 1 (n-1)d
--=(n-1)[-- - -- + -----
f R R nR R
1 2 1 2
where
f Is the distance between the focal point and the lens,
n is the refractive index of the lens,
R is the radius of curvature of the lens surface closest to the light source,
R is the radius of curvature of the lens surface farthest from the light source and,
d is the thickness of the lens (the distance along the lens axis between the two surfaces vertices
I’m going to assume your trying to fathom a laser type situation if so you might find spherical aberration helpful.
I do not understand threadmark's equation / diagram?
It has been jumbled in the browser,Food for research. try bifocals.
Hi friends I am new to PF . I want to collect a distant light spot ( 30 meters away) using a collimator and then through fiber spectrometer I want to analyse it. Please suggest me how I can make the collimator
If you are talking about visible spectroscopy, and the source really is 30 m away, the light at basically already collimated- as far as your lens is concerned, the source is at inifinity. A simple plano convex lens (the larger the diameter, the more light you will collect) used at an f-number matched to the acceptance angle of the fiber is the most simple solution.
  • · Replies 40 ·
  • · Replies 24 ·
