CP^2 , and CP^2 -bar, are not diffeomorphic.
  • Context: Graduate
  • Thread starter Thread starter WWGD
The discussion revolves around the question of whether CP^2 and CP^2-bar (the complex projective plane with reversed orientation) are diffeomorphic. Participants explore various topological and geometric properties, particularly focusing on intersection forms and cobordism groups, to argue their positions.
  • One participant suggests using the intersection form, noting that the intersection form for CP^2 is <1> and for CP^2-bar is <-1>, leading to a contradiction if a diffeomorphism exists.
  • Another participant proposes that if CP^2 admits an orientation-reversing diffeomorphism, it would imply 2-torsion in the cobordism group, which is a contradiction.
  • A different viewpoint raises a question about the validity of using orientation-reversing maps and their effects on homology, suggesting caution in the reasoning.
  • One participant mentions that the cohomology ring of CP^2 is a truncated polynomial ring and connects this to the properties of Kahler manifolds.
  • Another participant references a review discussing the importance of orientation in the context of the Dolbeault complex and its implications for integrality.
Participants express differing views on the methods and implications of their arguments regarding the diffeomorphism between CP^2 and CP^2-bar. No consensus is reached, and multiple competing perspectives remain throughout the discussion.
Some participants express uncertainty about the application of certain mathematical concepts, such as the relationship between homology and orientation-reversing maps, and the transition from topological to differentiable structures.
WWGD
Hi, Topologists/Geometers:
I am trying to show that CP^2 and CP^2-bar (meaning CP^2 with reverse choice of
orientation, are not diffeomorphic.
I am kind of rusty; all I can think of using is the intersection form, but I do not
remember the precise result that we can use to show this. I have checked Rohklin's
theorem and other results in intersection forms, without success.
I would appreciate your suggestions.
Way #1: Remember H^2(CP^2,Z) = Z, call the positive generator a, and the volume form on CP^2 is a positive multiple of a ^ a. Then f*(a)=ca, which implies f*(a^a)=c^2 a^a. Then c^2 can't possibly equal negative one.
Way #2: CP^2 freely generates the oriented cobordism group in dimension 4. If CP^2 admits an orientation reversing diffeomorphism, it's 2-torsion in the cobordism group, contradiction.
Zhentil:
Thanks Again. I wonder if this would also work: ( I will try to be more succint this time.)
We know that the intersection form for CP22 is <1>, and that for CP2^ (defined as CP2 with reversed orientation is <-1>.
This means that surfaces intersect positively , and at single points in CP2, and
surfaces intersect negatively at single points in CP2^.
Now assume there is a diffeomorphism f: CP2 -->CP2^
Then f is either i) orientation-preserving, or ii)orientation-reversing.
If we have:
i) , then the image under f of both homology 2-surfaces will still intersect
positively. If we have
ii), then the image under f of the 2-surfaces will also end up intersecting
positively at one point.
In neither case can the 2-homology surfaces intersect negatively at one point
the way they do in CP2^.
Does that Work.?
You have to be careful (why does an orientation-reversing map reverse signs on homology? it doesn't in general), but in this case, you're translating my way #1 via Poincare duality.
Zhentil: I am a little confused here: are you using some sort of deRham duality to construct a volume form by using the fundamental class.?. Otherwise, how do we go from a fundamental class in H_2(CP2,Z) , to a top form , i.e., a form in
H4(CP2;Z).?. The fundamental class is , AFAIK, a purely
topological object, while a volume form assumes a differentiable structure.
I hope this is not too far off.
The general answer is because CP^2 is Kahler. The more specific reason (and the reason this question is simple to answer) is because the cohomology ring of CP^2 is a truncated polynomial ring on one generator (i.e. a in H^2, a^3 = 0).
Wow, you blew me away there, Zhentil. Are you using Chern classes or something.?
My pithy one semester of algebraic topology cannot deal with that.
If I am too far off, just ignore it.
Based on one semester of algebraic topology, you can prove that the cohomology of CP^2 is Z in the even dimensions and 0 otherwise (by using the cell structure or Mayer-Vietoris). The only other bit of information comes from the fact that the generator of the top cohomology is actually the square of the generator of the middle cohomology. This is where the Kahler comment comes in: if you have a Kahler form, its top power actually gives you a volume form.
I came across this thread the other day and thought you might be
interested in the fact that exactly this point is discussed in the review by Eguchi, Gilkey and Hanson, Physics Reports, vol 66 (1980) 213. On page 320 they discuss the Dolbeault complex and show that the index is only integral if one chooses the correct oriantation.
Thanks, Dolan, I'll look it up.
Sorry, I meant page 330, not 320!
  • · Replies 38 ·
  • · Replies 0 ·
  • · Replies 25 ·
