betz
- 1
I want to determine the volume of air in a scuba tank. Can someone tell me the formula if I know how much water the tank holds?
The discussion revolves around calculating the volume of a scuba tank, particularly focusing on the geometry of the tank which includes a cylindrical body and hemispherical ends. Participants explore various formulas and considerations related to the volume of air contained within the tank, as well as the implications of pressure and gas laws.
Participants express differing views on the appropriate formula for calculating the volume of a scuba tank, with no consensus reached on a single correct approach. There is also disagreement regarding the specifics of tank design and pressure considerations.
Some limitations in the discussion include assumptions about the shape of the tank and the specific conditions under which the gas laws apply. The discussion also reflects varying interpretations of tank specifications and pressure standards.
Hopefully, your scuba tank doesn't contain waterbetz said:I want to determine the volume of air in a scuba tank. Can someone tell me the formula if I know how much water the tank holds?
It's probably worth pointing out that the ideal gas law is actually V = nRT/P, where n is the number of moles of gas present - probably the most important number, if you're interested in how much air is actually available to breathe.red_fox77 said:But better yet, to calculate the volume of air in the tank, use the ideal gas law (close enough for pure O2) V=RT/P. What this tells you is your pressure will depend on the temperature (in K) you are swimming at. R is the ideal gas constant, and the value depends on which units you want to use for V. Search google for 'R ideal gas' for some charts on which value to use.
Will.
Nenad said:A scuba tank has only one hemispherical side, the other side is flat, it even curves inward a bit. The real formula is:
[tex]V = \frac{2}{3}\pi r^3 + \pi r^2h[/tex]
