Thread Closed
Relativistic centripetal force
Share Thread Thread Tools
Apr29-10, 05:22 PM   #154
Sigh,
Let's try a different way. Earlier I mentioned that you can read all the necessary info straight off the line element. Now, if you look at Gron's line element (5.5) :
[tex]ds^2=(1-\frac{r^2\omega^2}{c^2})(cdt)^2+2r^2\omega dt d\theta+(r d \theta)^2+z^2[/tex]
and you compare this against the standard metric:
[tex]ds^2=(1+\frac{2\Phi}{mc^2})(cdt)^2+....[/tex]
You get the potential [tex]\Phi=-1/2mr^2\omega^2[/tex]
This gives you immediately the force:
[tex]\vec{F}=grad(\Phi)=-m\vec{r}\omega^2[/tex]
Apr29-10, 05:32 PM   #155
Hi Starthaus,
I have looked back over your previous posts and I think I have now identified the root of all your misunderstandings and confusion. Dalespam is correctin that all you have done in your blog document is transformed from one coordinate system to another, but what you have NOT done is found the PROPER centripetal acceleration which the quantity everyone else in this thread is talking about.
These are the quotes that identify your confusion:
Quote by starthaus View Post
[tex]\frac {d^2x}{dt'^2}[/tex] is physically a meaningless entity, you are mixing frames. Can you write down the correct definition for [tex]a'[/tex]?
[tex]\frac {d^2x}{dt'^2}[/tex] is not a physically meaningless entity. It is the PROPER centripetal acceleration which is what is measured by an accelerometer and therefore very physically meaningful. Yes, I do mean x without the prime and for the sake of this discussion we will take x to be the direction pointing to the centre of the circle.
Quote by kev View Post
You effectively derive:
[tex]\frac{d^2x}{dt^2} = \gamma^{-2}\frac{d^2x}{dt'^2}[/tex]
in expression (6) of your attachment, although you probably don't realise that.
I would never write such frame-mixing nonsese.
Well you need to learn to frame mix, because PROPER quantities (the quantities all observers agree on and coordinate independent are frame mixed entities.
Relativity 101 especially for Starthaus:
In Minkowski spacetime take two inertial frames S and S' with relative linear velocity.
Let there be a rod in S such that the two ends of the rod x2 and x1 are both at rest in frame S. The quantity x2-x1 is the proper length of the rod. (dx)
A stationary clock in S' moves from x1 to x2 in time t2'-t1' as measured by the clock. The time interval t2'-t1' is the proper time of the clock. (dt')
The PROPER velocity of the clock is dx/dt'.
Proper velocity is a "frame mixed" quantity. If you never write "frame mixed" quantities then it is about time you learnt to use them, as they are very useful and at the heart of all four vectors.
dx/dt is the coordinate velocity of the clock in frame S.
dx'/dt' is the coordinate velocity of the clock in frame S' and equal to zero in this case.
Apr29-10, 05:39 PM   #156
Hi Starthaus,
There is no confusion and no misunderstanding. I have taken you step by step through all your errors in doing the coordinate transformation from IF to RF. This is what I have corrected in your derivation starting from post #3 : you can't apply the Lorentz transforms derived for translation to a rotation problem.
....and this is precisely what I have been telling you all along I am doing. I am showing you how to use the appropiate Lorentz transforms. I have been telling you the same exact thing from post #3.
This is a separate issue, to be discussed only after I corrected all your errors.
You are also incorrect, in the last posts I have provided several methods that produce the proper acceleration or the centripetal force. You only had to look up, at post #154.
:lol: You are jumping frames. Again.
:lol:
Sorry, I had to snip your "lesson" , you are in no position to offer lessons. You wrote so many incorrect things that it prompted me to write a detailed followup of my file on accelerated motion in SR. I have just posted it under "Accelerated Motion in SR part II". You have a lot to learn
Apr29-10, 05:44 PM   #157
I will quote Dalespam:
Quote by DaleSpam View Post
This tells me that you don't know the difference between proper acceleration and coordinate acceleration.
Apr29-10, 05:48 PM   #158
Ad-hominems make very poor scientific arguments :lol:
It is especially bad form when I spent so much time teaching you the appropiate physical formalism and correcting your calculus errors.
Apr29-10, 08:34 PM   #159
Recognitions:
Eqn 9.26 of http://books.google.com/books?id=Muu...gbs_navlinks_s gives the centrifugal force as gamma.gamma.r.w.w. , which seems to be in agreement with DaleSpam.
Apr29-10, 09:03 PM   #160
Quote by atyy View Post
Correct. Rindler uses a different line element (9.26) than Gron. He also uses a completely different definition of the potential (9.13). The line element determines the force as I have shown in post 154, so you'll need to take your pick as to which one to choose.
Apr29-10, 09:37 PM   #161
Recognitions:
Wouldn't one need to use the standard form for a stationary metric rather than a static one?
Apr29-10, 10:08 PM   #162
Mentor
No, line elements (5.3) from Gron and Hervik and (9.26) from Rindler are exactly the same.
Apr29-10, 10:08 PM   #163
Yes, this is what both authors use. Rindler rearranges his metric in a strange way, in order to line up with his definition (9.13).
Apr30-10, 12:40 AM   #164
Do you understand proper acceleration is independent of choice of cooordinate system?
If Rindler states the proper centripetal acceleration is [itex]\gamma^2R\omega^2[/itex] then the proper centripetal acceleration is [itex]\gamma^2R\omega^2[/itex] in any coordinate system including the one used by Gron, in agreement with Dalespam, myself, Jorrie, Pervect etc.
Apr30-10, 07:44 AM   #165
Mentor
So, from Gron (p. 89), using the convention that spacelike intervals squared are positive, in a rotating reference frame with cylindrical coordinates given by:
[tex](t,r,\theta,z)[/tex]
The line element is:
[tex]ds^2 = -\gamma^{-2} c^2 dt^2 + dr^2 + 2 r^2 \omega dt d\theta + r^2 d\theta^2 + dz^2[/tex]
where
[tex]\gamma = (1 - r^2 \omega^2/c^2)^{-1/2}[/tex]
And the metric tensor is:
[tex]\mathbf g =
\left(
\begin{array}{cccc}
-\gamma ^{-2} c^2 & 0 & r^2 \omega & 0 \\
0 & 1 & 0 & 0 \\
r^2 \omega & 0 & r^2 & 0 \\
0 & 0 & 0 & 1
\end{array}
\right)
[/tex]
NB [itex]\gamma[/itex] is given by Gron as part of the line element and metric for the rotating frame in equations 5.3-5.5, and is only equal to 1 for the special case of [itex]\omega=0[/itex].
Finally, some of the Christoffel symbols in the rotating reference frame are non-zero (Gron p. 149). Specifically:
[tex]\Gamma^{r}_{tt}=-\omega^2r[/tex]
[tex]\Gamma^{r}_{\theta \theta}=-r[/tex]
[tex]\Gamma^{r}_{\theta t}=\Gamma^{r}_{t \theta}=-\omega r[/tex]
[tex]\Gamma^{\theta}_{rt}=\Gamma^{\theta}_{tr}=\omega/r[/tex]
[tex]\Gamma^{\theta}_{\theta r}=\Gamma^{\theta}_{r \theta}=1/r[/tex]
Now, the worldline of a particle starting on the x axis at t=0 and undergoing uniform circular motion at angular velocity [itex]\omega[/itex] in the x-y plane in an inertial frame is given by the following expression in the rotating frame:
[tex]\mathbf X = (t,r_0,0,0)[/tex]
From this we can derive the four-velocity in the rotating frame as follows:
[tex]\mathbf U = \frac{d \mathbf X}{d \tau} = i c \frac{d \mathbf X}{ds} = i c \frac{d \mathbf X}{dt} \frac{dt}{ds} = i c \; (1,0,0,0) \; \frac{1}{\sqrt{-\gamma^{-2} c^2}} = (\gamma,0,0,0)[/tex]
The norm of the four-velocity is given by:
[tex]||\mathbf U||^2=U_{\mu} U^{\mu}= g_{\mu\nu} U^{\nu} U^{\mu} = -c^2[/tex]
So this agrees with my previous results so far as expected since the norm is a frame invariant quantity.
Now we can derive the four-acceleration in the rotating frame as follows:
[tex]A^{\mu}=\frac{DU^{\mu}}{d\tau}=\frac{dU^{\mu}}{d\tau}+\Gamma^{\mu}_{\nu \lambda}U^{\nu}U^{\lambda}[/tex]
[tex]\frac{d \mathbf U}{d\tau}= i c\frac{d \mathbf U}{ds}= i c\frac{d \mathbf U}{dt}\frac{dt}{ds}= i c \; (0,0,0,0) \; \frac{dt}{ds}=(0,0,0,0)[/tex]
There is only one non-zero component of:
[tex]\Gamma^{\mu}_{\nu\lambda}U^{\nu}U^{\lambda}=\Gamma^{r}_{tt}U^{t}U^{t}=-\gamma^2 r \omega^2[/tex]
So, substituting back in we obtain the four-acceleration in the rotating frame:
[tex]\mathbf A = (0,-\gamma^2 r \omega^2,0,0)[/tex]
The norm of the four-acceleration, which is equal to the magnitude of the proper acceleration, is given by:
[tex]||\mathbf A||^2=A_{\mu} A^{\mu}= g_{\mu\nu} A^{\nu} A^{\mu} = \gamma^4 r^2 \omega^4[/tex]
So this also agrees with my previous results as expected since the norm is a frame invariant quantity.
In summary, if you use four-vectors it does not matter which frame you do the calculations in, they will all agree on the norms. The magnitude of the proper acceleration, which is equal to the norm of the four-acceleration, is a frame-invariant quantity, and it is given by the above expression. The quantity starthaus derived is a frame-variant coordinate acceleration, not the frame-invariant proper acceleration.
Apr30-10, 09:39 AM   #166
You are repeating the same error as before: proper acceleration is equal to four-acceleration for [tex]\gamma[/tex]=1.
Post #154 shows that your claim is not true. One can read the potential straight off the line element and calculate the force through a simple derivative.
Anyway, this is going nowhere , so it is time for me to give up. I wrote another attachment that corrects all of kev misconceptions about proper acceleration.
Apr30-10, 10:32 AM   #167
Mentor
The mistake is yours, the magnitude of the proper acceleration is equal to the norm of the four-acceleration in all reference frames and regardless of gamma. This should be obvious since the norm of the four-acceleration is a frame invariant scalar. You simply don't know what proper acceleration is. Also, the use of gamma in the metric is Gron's convention, not mine. You cannot seek to rely on Gron as an authority on the metric in the rotating system and then reject his metric in the rotating system.
In post 154 you once again calculated the coordinate acceleration and erroneously called it proper acceleration. All post 154 shows is that you don't know the difference between the two.
Apr30-10, 11:11 AM   #168
Wrong, I calculated the force directly off the line element. This is standard procedure, you can see it in any book.
Anyway, this is going nowhere, let's agree to disagree.
Apr30-10, 11:45 AM   #169
Mentor
Yes, it is a standard procedure for calculating the coordinate acceleration, not the proper acceleration. That is the part that you just don't seem to understand.
Note that the line element depends on the choice of coordinates as does the force you calculated. The proper acceleration does not. So the force you calculated cannot possibly be the proper acceleration.
May11-10, 03:26 PM   #170
where
[tex]\mathbf g =
\left(
\begin{array}{cccc}
0 & 1 & 0 & 0 \\
0 & 0 & 0 & 1
\end{array}
\right)
[/tex]
The result is incorrect, a correct application of covariant derivatives (as shown here) gives the result [tex]a_0=r\omega^2[/tex].
Thread Closed
Thread Tools
Similar Threads for: Relativistic centripetal force
Thread Forum Replies
Centripetal force ? General Physics 25
Centripetal force Introductory Physics Homework 2
relativistic centripetal force Special & General Relativity 32
ranking net force/ centripetal force problem Introductory Physics Homework 1
sth about centripetal force. pls help!! >< General Physics 18
