The discussion revolves around the coupling of three angular momentum states, specifically how to construct eigenstates of total angular momentum for three particles represented as J = j_1 + j_2 + j_3. Participants express confusion and seek clarification on the methods involved in this process.
- Exploratory
- Technical explanation
- Debate/contested
- One participant expresses confusion about how to couple three angular momentum states and seeks assistance in building eigenstates of total angular momentum.
- Another participant suggests that if one can add two angular momentum states, then adding a third should not pose a problem, proposing a method using tensor products.
- A question is raised about whether it is equivalent to first couple j_1 and j_2, then j_12 with j_3, or to couple j_2 and j_3 first, then j_1 with j_23.
- It is noted that the tensor product is associative, implying that the order of coupling does not affect the final result.
- Further clarification indicates that different coupling sequences may lead to different representations of the total angular momentum states, and the complexity of the algebra increases significantly with more particles.
- One participant references the use of Clebsch-Gordan coefficients and 3-j symbols for coupling three angular momenta, mentioning the work of G. Racah and recommending a specific text on the subject.
Participants generally agree on the methods of coupling angular momentum but express differing views on the implications of the order of coupling and the complexity involved. The discussion remains unresolved regarding the best approach to couple three angular momenta.
The discussion highlights the challenges of managing multiple angular momentum states and the potential for different representations based on the coupling order. There is an acknowledgment of the increasing complexity with additional particles and the reliance on specific mathematical tools.
