Piecewise Function Homework: Find foG & goF
  • Thread starter Thread starter thereddevils
    Function
The problem involves finding the compositions of two piecewise functions, f and g, defined for different domains. The functions are f(x) and g(x), with specific expressions based on the value of x. The task is to determine f o g and g o f.
  • Participants discuss the need to substitute g(x) into f(x) and express concerns about adjusting the domains correctly. There is mention of dividing the analysis into intervals based on the behavior of g(x) and its impact on f(x).
Some participants have provided insights into how to handle the domains of the piecewise functions and suggested dividing the problem into intervals for clarity. There is ongoing exploration of how to approach both compositions, but no consensus has been reached.
Participants note the importance of considering the domains of the functions when performing the compositions, particularly how the outputs of g(x) relate to the inputs of f(x).
thereddevils
Given that f(R)=R , g(R)=R be defined respectively by
[tex]f(x)=\begin{cases} \sin x+2 & \text{if } x>1 \\ \cos x-2 & \text{if } x\leq 1\end{cases}[/tex]
[tex]g(x)=\begin{cases}2x+3& \text{if } x>0 \\ x^2 & \text{if } x\leq 0 \end{cases}[/tex]
Find f o g and g o f
i have no idea to begin except for the obvious substitution of g(x) into the function f(x) . I am not sure how to adjust the domain .
For x>1, wouldn't f(x) = sinx +2 and g(x)=2x +3 ?
You need to be careful of the domains. If [itex]x\le 0[/itex], [itex]g(x)= x^2[/itex] but then [itex]x^2< 1[/itex] if x> -1 and [itex]x^2> 1[/itex] if x< -1.
If x> 0, [itex]g(x)= 2x+ 3[/itex] and, since x is positive, that is always larger than 3 which is larger than 1.
You need to divide into three intervals: for x<-1, [itex]g(x)= x^2> 1[/itex] so [itex]f(g(x))= f(x^2)= sin(x^2)+ 2[/itex]. for [itex]-1\le x\le 0[/itex], [itex]g(x)= x^2\le 1[/itex] so [itex]f(g(x))= f(x^2)= cos(x^2)- 1[/itex]. For x> 0, g(x)= 2x+ 3 and f(g(x))= f(2x+3)= sin(2x+3)+ 2.
Now, you do g(f(x))
Now, you do g(f(x))
thanks !
  • · Replies 23 ·
