Thread Closed
Calculating Work done by the Earth and the work done by the Spring
Share Thread Thread Tools
Apr24-10, 03:11 AM   #1
A mass of 0.091 kg hangs from a vertical spring in the lab room. You pull down on the mass and throw it vertically downward. The speed of the mass just after leaving your hand is 3.80 m/s.
2. Relevant equations
(a) While the mass moves downward a distance of 0.09 m, how much work was done on the mass by the Earth? Include the appropriate sign.
Work done by Earth = ............Joules
(b) At the instant in part (a) when the mass has moved downward a distance of 0.09 m, the speed of the mass has decreased to 2.13 m/s. How much work was done on the mass by the spring? Include the appropriate sign.
Work done by spring = ............Joules
3. The attempt at a solution
To calculate Work I'm using the formula F times displacement
So for (a) I calculated:
0.09m X -9.8m/s/s X 0.091kg = -0.080262J
is that correct?
For part B I have no idea what to do?
Thanks if you can help.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Apr24-10, 04:11 AM   #2
Part B mainly requires for you to calculate the difference in the kinetic energy.
Apr24-10, 08:36 AM   #3
Mentor
Quote by Paul36 View Post
is that correct?
Except for the sign. What determines the sign of the work done is whether the force and displacement are in the same direction or not. If they are, the work done is positive.
What's the net work done on the mass?
Thread Closed
Thread Tools
Similar Threads for: Calculating Work done by the Earth and the work done by the Spring
Thread Forum Replies
Work done to stretch a spring vs Work done by a spring? Classical Physics 11
Work Done on the Mass by a spring in the horizontal plane perpendicu to earth center Classical Physics 1
Work done on the Earth by the Sun Introductory Physics Homework 2
Is earth doing work on the moon? Introductory Physics Homework 3
Calculating Work Advanced Physics Homework 3
