| Thread Closed |
fluid mechanics :fluid in motion |
Share Thread | Thread Tools |
| Apr24-10, 05:07 AM | #1 |
a vertical, 1cm-diameter jet of water impinges upon a bathroom scale such that the latter exhibits a reading of 5 kg. Estimate the volume flow rate of the jet. 2. Relevant equations p=F/A Q(volume flow rate)=U*A(area where the jet of water is applied on) a=pi*rČ F=mg P=(rho*UČ)/2 (if we consider that the pressure applied on the scale by the jet is essentially dynamic pressure) (don't know if this is correct though) 3. The attempt at a solution let's calculate A first A=2.5x10^(-5)*pi then let's change the kg into Newtons: F=5*9.81=49.05N P is F/A therefore: P=49.05/(2.5*10^(-5))=624.523kpa with P=(rho*UČ)/2 if find U=35.341m/s and with Q(volume flow rate)=U*A(area where the jet of water is applied on) I find Q=2.7756 l/s just wanna know if I should include the atmospheric pressure or not |
| Apr25-10, 09:26 AM | #2 |
found it
| Thread Closed |
| Thread Tools | |
Similar Threads for: fluid mechanics :fluid in motion
| Need Hmwk Help ASAP. Fluid mechanics, Fluids in Motion, Pressure | Introductory Physics Homework | 2 | ||
| Need MORE Hmwk help ASAP. Fluid mechanics, Fluids in motion, pressure | Introductory Physics Homework | 8 | ||
| Fluid Mechanics - Equations of motion circular flows | Classical Physics | 9 | ||
| Fluid Mechanics | Introductory Physics Homework | 3 | ||
