kurious
- 633
If the Higgs theory is correct shouldn't it be able to predict the rest masses of all particles?
The discussion revolves around the Higgs theory and its implications for predicting particle masses within the framework of the standard model of particle physics. Participants explore the relationship between the Higgs mechanism, coupling constants, and the acquisition of mass by particles, as well as the limitations of the theory in providing exact mass predictions.
Participants generally do not reach a consensus, as multiple competing views remain regarding the implications of the Higgs mechanism, the nature of coupling constants, and the completeness of the Higgs theory in explaining particle masses.
Limitations include unresolved interpretations of coupling constants, the dependence of mass definitions on energy scales, and the complexity of relating particle speed to mass and coupling constants.
kurious said:If the Higgs theory is correct shouldn't it be able to predict the rest masses of all particles?
What do you mean ? The coupling constants are parameters of the theory used to calculate probabilites (amplitudes). The coupling might evolve with the energy scale. But they are not probabilitieskurious said:Coupling constants are usually associated with probabilities.
kurious said:Since the rest mass of one particle can be equivalent in magnitude to the mass of another faster moving particle which has a smaller rest mass,
can't the coupling constants be related to one particle moving at different speeds?
humanino said:Are you absolutely positive on that Marlon ?
If you look at the evolution of parton densities in the nucleon (DGLAP & ERBL) you should notive that at higher [tex]Q^2[/tex] the densities increase at small [tex]x_{Bjorken} = \frac{Q^2}{2 M \nu}[/tex].
The asymptotic freedom says that the coupling goes to zero with [tex]Q^2[/tex] increasing, not the speed. The coupling constant goes to zero when the quarks are close to each other, or at higher energies. But I am not certain (I have not heard about) relative speed interpretation.
At higher [tex]Q^2[/tex], one probes the structure at smaller distances at observes more and more parton pair fluctuations, which are located at smaller and smaller [tex]x_{Bjorken}[/tex] which is the fraction of momentum carried by the parton. As far as I understand, if the fraction of momentum is smaller, the speed is smaller too. I am not too sure about this. The problem is, their is no satisfying way of defining the mass of the quarks which should depend on [tex]Q^2[/tex] too. So talking about relative speed, I am not too sure.
