Ball Launched from spring gun (max height)
by jti3066
Tags: ball, height, launched, spring
jti3066
jti3066 is offline
#1
Apr24-10, 05:54 PM
P: 46
A ball of mass m is launched at an angle theta from a spring gun of length D. The lower end of the gun, where the spring is attatched, is at ground level. The spring has spring constant k and an unstretched length D. Before launch, the spring is compressed to a length d.
Determine the maximum height h above the ground the ball reaches.
2. Relevant equations
(k(x^2)/2)=mgh
?? x = mgcos(theta)
3. The attempt at a solution
Plugging in "x" I get: h=(k(mgcos(theta))^2)/2mg
Is this correct? If not please explain in detail and provide the steps and solution. TIA.
Phys.Org News Partner Science news on Phys.org
Cougars' diverse diet helped them survive the Pleistocene mass extinction
Cyber risks can cause disruption on scale of 2008 crisis, study says
Mantis shrimp stronger than airplanes
Doc Al
Doc Al is offline
#2
Apr24-10, 06:08 PM
Mentor
Doc Al's Avatar
P: 40,905
Quote Quote by jti3066 View Post
(k(x^2)/2)=mgh
Here x is a velocity. You can use conservation of energy to find the additional height reached after the ball leaves the gun, if x is the vertical component of the speed at that point. Note that h will not be the height above the ground.
?? x = mgcos(theta)
You can't set a velocity (x) equal to a force.
Is this correct?
No. Note that you haven't even used the spring constant or the amount the spring was compressed.
Try to solve it in two steps: Find the speed of the ball as it leaves the gun. Then find the height that it reaches after it becomes a projectile.
jti3066
jti3066 is offline
#3
Apr24-10, 06:38 PM
P: 46
Well then I guess I have no idea what i'm doing then...A little more help please
K_i + U_i + S_i = K_f + U_f + S_f
K = .5mv^2
U = mgh
S = .5kx^2
What is the muzzle velocity?
How to find the height that it reaches?
Doc Al
Doc Al is offline
#4
Apr25-10, 09:36 AM
Mentor
Doc Al's Avatar
P: 40,905
K = .5mv^2
U = mgh
S = .5kx^2
To find the muzzle velocity, use conservation of energy as you outlined above. Hint: What's the change in height of the ball as it travels through the gun?
Once the ball leaves the gun it's a projectile. Solve that part like any other projectile motion problem.
jti3066
jti3066 is offline
#5
Apr25-10, 02:42 PM
P: 46
Could someone please solve the problem for me.....BTW this is NOT a homework problem....It is a final test review problem....I learn differently than most.....By looking at the steps involved in solving the problem along with the answer I can use deductive reasoning as to why those methods were used....TIA
Register to reply
Related Discussions
The velocity and height of a rocket launched vertically from the earth. Introductory Physics Homework 0
Find Initial Velocity given angle, distance, height launched from. Introductory Physics Homework 1
Maximum height of launched ball Introductory Physics Homework 2
speed of a ball launched from a spring Introductory Physics Homework 1
Finding the max height of a ball launched as a projectile using work-energy Introductory Physics Homework 3
