What Is the Limit Product Rule and Why Is It Confusing?
The discussion centers on the Limit Product Rule in calculus, specifically the confusion surrounding its proof. The rule states that if \(\lim_{x \to c} f(x) = L\) and \(\lim_{x \to c} g(x) = M\), then \(\lim_{x \to c} f(x)g(x) = LM\). Participants highlight the use of epsilon-delta definitions to establish this limit, with particular emphasis on the selection of appropriate delta values to satisfy multiple conditions simultaneously. The conversation reveals a common struggle with the abstract nature of epsilon-delta proofs and the manipulation of inequalities involved in the proof process.
  • Understanding of limits in calculus
  • Familiarity with epsilon-delta definitions
  • Basic knowledge of algebraic manipulation of inequalities
  • Experience with calculus proofs and theorems
  • Study the epsilon-delta definition of limits in detail
  • Learn about the proofs of the Limit Product Rule and Limit Sum Rule
  • Explore examples of epsilon-delta proofs in calculus
  • Practice manipulating inequalities in calculus contexts
Students of calculus, educators teaching limit concepts, and anyone seeking to deepen their understanding of limit proofs and the Limit Product Rule.
sponsoredwalk
In trying to prove the limit product rule I've found all explanations
to hit on a point where I lose understanding.
1: If [tex]\lim_{x \to c} f(x) \ = \ L \ and \ \lim_{x \to c} g(x) \ = \ M \[/tex]
We define the limit as;
[tex]\ \forall \ \epsilon \ >\ 0 \ \exists \ \delta > 0 \ : \ \forall \ x \ \rightarrow \ 0\ < \ | \ x \ - \ c \ | < \delta \ \Rightarrow \ 0 \ < \ | \ f(x)g(x) \ - \ LM \ | \ < \ \epsilon[/tex]
2: Rewrite [tex]f(x) \ = \ L \ + \ (f(x) \ - \ L) \ and \ g(x) \ = \ M \ + \ (g(x) \ - \ M)[/tex]
3: Rewrite [tex]f(x)g(x) \ - \ LM \ as[/tex]
[tex][L \ + \ (f(x) \ - \ L)] \ [ M \ + \ (g(x) \ - \ M) ] \ - \ LM \ =[/tex]
[tex]LM \ + \ L(g(x) \ - \ M) \ + M(f(x) \ - \ L) \ + \ (f(x) \ - \ L)(g(x) \ - \ M) \ - \ lm[/tex]
[tex]L(g(x) \ - \ M) \ + M(f(x) \ - \ L) \ + \ (f(x) \ - \ L)( g(x) \ - \ M)[/tex]
All this I'm fine with, but next each source I've read confuses me. I'll give the one from Thomas Calculus.
"Since f & g have limits L & M as x-->c, ∃ positive numbers δ_1, δ_2, δ_3, δ_4 such that ∀ x;
[tex]0 \ < \ |x \ - \ c| \ < \delta_1 \Rightarrow \ |f(x) \ - \ L| \ < \ \sqrt{ \frac{ \epsilon }{3} }[/tex]
[tex]0 \ < \ |x \ - \ c| \ < \delta_2 \Rightarrow \ |g(x) \ - \ M| \ < \ \sqrt{ \frac{ \epsilon }{3} }[/tex]
[tex]0 \ < \ |x \ - \ c| \ < \delta_3 \Rightarrow \ |f(x) \ - \ L| \ < \ \sqrt{ \frac{ \epsilon }{3(1 \ + \ |M|} }[/tex]
[tex]0 \ < \ |x \ - \ c| \ < \delta_4 \Rightarrow \ |g(x) \ - \ M| \ < \ \sqrt{ \frac{ \epsilon }{3(1 \ + \ |L|} }[/tex]
What does this even mean and where does it come from?
How you find these numbers, is perhaps a bit unclear to you. However, if you follow the proof through to the end, you will hopefully see what it does.
So apart from all this magic with the epsilons and delta's, do you agree with the statement? When you look at the definition for limit, you probably will. For example, since f(x) has limit L, I can always make |f(x) - L| as small as I want. In symbols,
[tex] \ \forall \ \epsilon' \ >\ 0 \ \exists \ \delta' > 0 \ : \ \forall \ x \ \rightarrow \ 0\ < \ | \ x \ - \ c \ | < \delta' \ \Rightarrow \ 0 \ < \ | \ f(x) \ - \ L \ | \ < \ \epsilon' [/tex] (*)
Now what the proof does, is simply pick two such [itex]\epsilon'[/itex] (namely [itex]\sqrt{\epsilon / 3}[/itex] and [itex]\sqrt{\epsilon / 3(1 + |M|)}[/itex] where [itex]\epsilon, M[/itex] are given numbers, then the existence of the limit ensures that I can find values of delta' for which (*) is true.
The proof then probably goes on to pick the smallest delta of the four, such that all four estimates hold simultaneously.
Then you can plug all those estimates into
[tex] f(x) g(x) - L M = L(g(x) \ - \ M) \ + M(f(x) \ - \ L) \ + \ (f(x) \ - \ L)( g(x) \ - \ M) [/tex]
and show that it is smaller than [itex]\epsilon[/itex].
Hey thanks for the reply, well I did try to follow the proof forwards but not only does that crazy value for epsilon scare the **** out of me but I just get confused. I'l show you where;
I should have written a bit more; the absolute value in the original equation is equivalent to;
[tex]|f(x)g(x) \ - \ LM| \le \ | L(g(x) \ - \ M) \ + M(f(x) \ - \ L) \ + \ (f(x) \ - \ L)( g(x) \ - \ M) |[/tex]
[tex]\le \ | L | \ | (g(x) \ - \ M) | \ + |M| \ | (f(x) \ - \ L) | \ + \ | (f(x) \ - \ L)| |( g(x) \ - \ M) |[/tex]
but then my book goes off writing the following which I have no idea where it came from nor why you'd do it nor how you'd figure out that this is what you do.
[tex]\le ( 1 \ + \ |L| ) |g(x) \ - \ M | \ + \ (1 \ + \ |M| ) |f(x) \ - \ L | \ + \ |f(x) \ - \ L| |g(x) \ - \ M|[/tex]
Then this becomes < [tex]\frac{ \epsilon }{3} \ + \ \frac{ \epsilon }{3} \ +\sqrt{ {\frac{ \epsilon }{3}} } \sqrt{ {\frac{ \epsilon }{3}}[/tex]
And I'm lost
  • · Replies 25 ·
  • · Replies 25 ·
  • · Replies 16 ·
