Calculating the Area Bounded by Two Curves
The discussion revolves around calculating the area bounded by the curves defined by the equations y=|x+1| and y=-(x+1)²+6. Participants are exploring the limits of integration and the points of intersection between these two curves.
  • Participants discuss the limits of integration derived from setting the two equations equal to each other. There are attempts to clarify the correct expressions for the curves and their intersections. Questions arise regarding the use of absolute values and how they affect the integration limits.
The discussion is ongoing, with participants providing various insights into the setup of the problem. Some suggest graphing the functions to better understand their intersections, while others are questioning the validity of certain limits and the interpretation of the curves.
There is mention of potential confusion regarding the points of intersection and the correct identification of the curves represented by the absolute value function. Participants are also addressing the symmetry of the curves about a specific line.
the white sou
find the Area Bounded by the two curves, y=|x+1|, y= - ( x+1)2 + 6
A= Integration of | f (x) - g(x) |
x+1= f(x)
-(x+1)2 + 6= g(x)
getting the limit of integration:
x+1= - (x+1)2 + 6
x2 + 3x - 4=0
(X+4) ( x-1)
so x=-4, and x=1
now when dividing the absolute valuey= x+1 ; x<-1
y=-(x+1) ; x>-1Integration is denoted by { ( upper limit , lower limit ) |f(x)|
so the Area= {(-1,-4) |(-x-1) + (x+1)2 -6 | - {(-1,1) |(x+1)+(x+1)2 - 6|what's wrong in this solution, I think that we should use -x-1 to get the limits as well so the area will be (the integration from -4 to -1) - (the integration from -1 to 3)
welcome to pf!
hi the white sou!
…getting the limit of integration:
x+1= - (x+1)2 + 6
x2 + 3x - 4=0
(X+4) ( x-1)
so x=-4, and x=1
No … you need to use |x+1|, not x+1. :wink:
Graph it first.
Looks like you are using -4 as one of your limit however,
at -4
y = 3, y = -3
They don't intersect at -4
(tiny-tim already pointed out)
tiny-tim said:
hi the white sou!
okay |x+1| consists of x+1, -x-1
once we use x+1=-(x+1)2 +6
x= 1, x= -4
and when we are using -x-1= -(x+1)2 + 6
we get x=-2, x=3
now we are having 4 points of intersection
soo how would we get the limits
rootX said:
Graph it first.
at -4
y = 3, y = -3
I already graphed it
for |x+1| there will be two lines intersecting at the point -1 and for the other curve we are having the the head of the curve at (-1,6) and it is opening downword
When you used x+1, you got x= 1, x= -4
When you used -(x+1), you got x=-2, x=3
Does x+1 is right or left line in the curve |x+1|. Label |x+1| with x+1 and -(x+1) and you should be able to identify which two of the above four solutions is valid
An alternative method:
both curves are obviously symmetric about the line x + 1 = 0, ie x = -1,
so the solutions must also be symmetric about x = -1. :wink:
so Area= {(-2,-1) |f(x)-g(x)| - {(-1,1) |f(x)-g(x)|
am i right now?
am i right now?
1)
and when we are using -x-1= -(x+1)^2 + 6
we get x=-2, x=3
Should have been
x= 2, x=-3
okay now I knew my mistakethank you bro :)
