Understanding Magnetic Dipoles: Forces and Equations Explained
  • Context: Graduate
  • Thread starter Thread starter pervect
    Dipoles Magnetic
This discussion focuses on the principles of magnetic dipoles, specifically current loops and spinning electrons. A current loop with area A and current i generates a magnetic dipole moment defined as \(\mu = i A\). Key equations include torque from an external field \(\vec{\mu} \times \vec{B}\), energy in an external field \(-\vec{\mu} \cdot \vec{B}\), and the magnetic field from a dipole at distant points, which varies based on the dipole's orientation and distance. The net force on a dipole in a constant magnetic field is zero, while in a varying magnetic field, it is represented by \(\nabla (\vec{\mu} \cdot \vec{B})\).
  • Understanding of magnetic dipole moment and its calculation
  • Familiarity with vector calculus, particularly gradients
  • Knowledge of magnetic fields and their properties
  • Basic principles of electromagnetism, including forces on charged particles
  • Study the derivation of the magnetic dipole moment for different geometries
  • Explore the implications of torque and energy equations in magnetic fields
  • Learn about the behavior of magnetic dipoles in non-uniform magnetic fields
  • Investigate applications of magnetic dipoles in technologies such as MRI and magnetic sensors
Students and professionals in physics, electrical engineering, and applied sciences, particularly those interested in electromagnetism and magnetic field applications.
pervect
Staff Emeritus
Insights Author
here seems to be some interest in magnetic dipoles, such as spinning electrons, and current loops. So I thought I would start a thread and present some of the relevant equations that describe the forces and fields generated by magnetic dipoles. These equations are very similar to those for electric dipoles, BTW.
A current loop with an area A and carrying a current i has a
magnetic dipole moment of [tex]\mu = i A[/tex]. The dipole moment is sometimes expressed as a vector [tex]\vec{\mu}[/tex] in which case the vector is perpendicular to the area A.
Some useful properties of the diople moment are given below
Torque generated by an external field [tex]\vec{\mu} \times \vec{B}[/tex]
Energy in an external field [tex]-\vec{\mu} \cdot \vec{B}[/tex]
Field from dipole at distant points along axis |B| = [tex]\frac {\mu_0}{2 \pi} \frac {\mu}{r^3}[/tex]
Field from dipole at distant points along bisector |B| = [tex]\frac {\mu_0}{4 \pi} \frac {\mu}{r^3}[/tex]
Field from dipole, vector form [tex]\vec{B} = \frac {\mu_0 \mu}{4 \pi r^3} (2 cos(\theta) \vec{r} + sin(\theta) \vec{\theta})[/tex]
Net force on dipole from a constant magnetic field zero
Net force on a dipole from a varying magnetic field [tex]\nabla (\vec{\mu} \cdot \vec{B})[/tex]
Note that the force between two dipoles will drop off with the 4th power of the distance - as the field generated by a dipole is proportional to 1/r^3, the gradient of the field is proportional to 1/r^4, and the force will be the dipole moment multiplied by the field gradient.
"Constant" or "varying" usually means w.r.t. time. I think here you mean w.r.t. space, so common usage is "uniform" or "non-uniform".
Yes, that's what I mean. To develop a net force, one needs the field to be different at the two ends of the dipole, which means that the field must be varying in space.
  • · Replies 21 ·
