Why does looking at things from a small hole make it more clear?
  • Context: High School
  • Thread starter Thread starter sameeralord
    Hole
The discussion revolves around the phenomenon of viewing objects through a small hole, such as a pinhole or a microscope, and its effect on image clarity. Participants explore concepts related to optical aberrations, diffraction, and the geometry of light as it interacts with lenses.
  • Some participants suggest that viewing through a small hole reduces aberrations because it limits the light entering the lens to rays that are closer to the optical axis.
  • Others argue that the pinhole acts as a new source of light, which relates to diffraction and interference patterns.
  • One participant notes that the equations for lens focus apply primarily to rays parallel to the axis, indicating that off-axis rays contribute to aberrations.
  • There is mention of various types of aberrations, including chromatic aberration, spherical aberration, coma, astigmatism, and field curvature, with some participants explaining how a small aperture can mitigate these effects.
  • Some participants discuss the relationship between light rays entering the lens at different angles and the resulting image quality, emphasizing that limiting off-axis light can improve focus.
  • Questions are raised about the fundamental causes of aberration, including the geometry of light and the imperfections in lens shape or mounting.
Participants generally agree that using a small aperture can reduce aberrations, but there is no consensus on the precise mechanisms or the relative importance of different factors contributing to image clarity.
Limitations include varying definitions of aberration, the dependence on specific lens geometries, and the potential influence of external factors such as light conditions and lens imperfections.
This discussion may be of interest to individuals studying optics, photography, or anyone curious about the principles of vision and image clarity through lenses.
sameeralord
Hello everyone,
Why do looking at things with one eye closed through a small hole like microscope make the object look clearer. Someone told me it gives less abberation. Then I checked it online and it said different wavelengths converge at different points in a lens. Ok I understand why that would create a blurred image, but I don't understand why looking at objects as the way I describe create less abberation. Thanks :smile:
Science news on Phys.org
The hole behaves like a new source, this has to do with diffraction
And effectively everything before that is a miss match of destructive and constructive interference patterns.
Not sure about the microscope, but if you mean a small hole just in say a piece of card, or a hole made with your finger
That's correct.
The equations you learned for lenses and focus only apply to rays parallel to and near the axis, as you get further off axis the lens (including the one in your eye) can't focus them all to the same point.
There are 4-5 main aberations but they all get worse as you go to larger apertures, and some of them as the size of the aperture ^2 or ^3
That's correct.
Thanks a lot for your reply :smile: I don't know much about lenses. When I checked the definition of abberation, I thought it meant different colours of light don't converge at the same point in a lens. So how does creating a pin hole make different colours of light converge at the same point. How is this creating less abberation? Thanks a lot for your time :smile:
Edit: Oh wait do you mean, that when there is a pinhole, the light rays would be coming parallel, so their is more convergence at one point?
When you look at an object "normally," rays from the object enter your eye and its lens through the entire area of the eye's pupil, and the lens focuses the rays onto the retina. Because of aberrations in the lens, the focus isn't perfect.
The pinhole reduces the area of the lens that is actually used, which reduces the amount of aberration. This is a general principle. It also applies to cameras: when you reduce the aperture (for a given lens), you generally improve the sharpness of the picture, until the aperture becomes so small that diffraction becomes noticeable.
Notice also that you can usually see better outdoors in bright sunlight than indoors or in the shade, because the pupil of your eye shrinks in bright light.
That's just chromatic aberation, there is also
Spherical aberration
Coma
Astigmatism
Field curvature
A small aperture helps with chromatic aberation because with a small pupil the light all enters the lens at a small angle to the curved surface (on axis - the lens surface is flat to the light) so the light 'sees' a smaller prism effect and is dispersed less.
Thanks Jtbell :smile: it certainly helped. Ok so is the answer for this question,
Edit: Also what creates aberration in the first place. Is it the diffraction of light as it travels in the air that makes hit the axis at an angle?
1.when there is a pinhole, the light rays would be coming parallel, so their is more convergence at one point?
2. Less light rays less abberation
I think it is both but both of you have emphasized the second one. Is it simply that more light rays you have higher the chance of abberation. Is it simply that not much physics in this. Thanks :smile:
For chromatic aberration it's that light hitting the surface of the lens at an angle sees it as a prism and gets diverged.
For most of the other aberrations it's that, for a spherical lens, light hitting the lens parallel to the axis doesn't com to a focus in the same place as it gets further from the axis.
Even for a parabola, light entering the lens at different angles doesn't all com to a focus in the same place.
It's simply a matter of geometry, by limiting the amount of off-axis ligth that can go through the lens you are blocking the rays that will form the worst images, and so improving the image you get.
Then in the real world there are also the effects of lenses not being perfectly shaped, or being mounted slightly tilted or off center.
Oh I get it. Thanks mgb_phys :smile: It was all about distance from the axis. Thanks again :smile:
Unfortunately the wiki page isn't very clear.
But most optics books will have pictures of the different aberrations.
You can generally reduce most of them given enough lens element (each extra bit of glass gives you a couple of extra parameters to adjust) and if you are allowed to use fancy (expensive!) aspherical or high-index lenses. Thats why the lens for a Hassleblad or a Leica costs more than the one on your cell phone.
But the small aperture of the lens on your cell phone is how a 1cent bit of moulded plastic is able to give any sort of image at all!
  • · Replies 67 ·
  • · Replies 58 ·
9K
  • · Replies 19 ·
21K
  • · Replies 20 ·
  • · Replies 17 ·
  • · Replies 26 ·
