What would be my boundary conditions? Heat Equation
The discussion focuses on determining the boundary conditions for a one-dimensional heat equation involving a rod of length 4 with a thermal conductivity of 1. At the end of the rod located at x=4, heat radiates at twice the temperature difference between the rod's end and the surrounding air temperature of 23°C, leading to the boundary condition -u_{x}(4,t) = 2(u(4,t) - 23). The participant also suggests a second boundary condition, proposing that the temperature at x=4 can be expressed as u(4,t) = u(4,0) - t * u_{t}(4,t), indicating a relationship between initial temperature and the rate of temperature loss over time.
  • Understanding of one-dimensional heat equations
  • Familiarity with boundary value problems in partial differential equations
  • Knowledge of thermal conductivity and heat transfer principles
  • Basic calculus, particularly differentiation with respect to time and space
  • Study the derivation and application of boundary conditions in heat equations
  • Learn about the method of separation of variables for solving heat equations
  • Explore the implications of thermal conductivity in heat transfer scenarios
  • Investigate the physical significance of initial and boundary conditions in PDEs
Mathematicians, physicists, and engineers working on heat transfer problems, particularly those involved in thermal analysis and boundary value problem solutions in one-dimensional systems.
punkstart
1. I have a rod of length 4,cross section 1 and thermal conductivity 1.Nothing is mentioned about the end at the origin x=0, but at the opposite end x=4, the rod is radiating heat energy at twice the difference between the temperature of that end and the air temperature of 23 celsius. Find the boundary conditions at this x=4 end of the rod to be used in the one dimensional heat equation.
2. Heat flows out of rod at -[tex]\lambda A u_{x}(a,t)[/tex]
3. with my substitutions i get -[tex]u_{x}(4,t)=2(u(4,t)-23)[/tex]
So that my first boundary condition is the above. But i think " they " want another boundary condition here at x=4,but what ? I was thinking something like [tex]u(4,t)=u(4,0)-tu_{t}(4,t)[/tex] in other words temperature now = initial temperature - time*rate of temperature loss. i am not very experienced with these problems,can someone please point me in the right direction ?
so based on the boundary condition the you can calculate the heat moving out the end of the rod
[tex]Q = 2(u(4,t) - 23))[/tex]
Assuming the heat flow is reasonably continuous which is a good assumption you should be able to relate the heat flow to the thermal gradient at the end of the rod [tex]u_x(4,t), using the thermal conductivity[/tex]
