Register to reply
If dy/dt = ky and k is a nonzero constant, y could be
by lude1
Tags: constant, dy or dt, nonzero
Share this thread:
lude1
#1
May2-10, 12:48 AM
P: 34
If dy/dt = ky and k is a nonzero constant, than y could be
a. 2e^kty
b. 2e^kt
c. e^kt + 3
d. kty + 5
e. .5ky^2 + .5
Correct answer is b. 2e^kt
2. Relevant equations
3. The attempt at a solution
I don't really know what I should be doing. I have a feeling I have to work backwards, therefore do the integral of ky? But if that is the case, I have no idea how e^kt is created through that integral. 2e^kt reminded me of Ce^kt, but that doesn't have anything to do with this problem either.
Phys.Org News Partner Science news on Phys.org
Hoverbike drone project for air transport takes off
Earlier Stone Age artifacts found in Northern Cape of South Africa
Study reveals new characteristics of complex oxide surfaces
Squeezebox
#2
May2-10, 12:54 AM
P: 58
Look at the derivative of e^kt and see how that relates to e^kt.
rock.freak667
#3
May2-10, 12:56 AM
HW Helper
P: 6,207
The 'correct' thing to do would be
dy/dt = ky
∫ dy/y = ∫ k dt
But since you have a multiple choice, you could quickly differentiate each one if you wanted to.
lude1
#4
May2-10, 01:07 AM
P: 34
Hm.. this is what I got when I did ∫ dy/y = ∫ k dt
lny = kt
y = e^kt
Where does the 2 come from? I guessed it would have to be from a square, but when you do the integral of a number (since k is a nonzero constant) you multiply the constant with a variable with an exponent of 1, not 2.
rock.freak667
#5
May2-10, 01:12 AM
HW Helper
P: 6,207
Quote Quote by lude1 View Post
lny = kt
y = e^kt
you'd get
ln y = kt+A such that y=ekt+A=Bekt where B is a constant. So B can be any number, such as '2'.
lude1
#6
May2-10, 01:14 AM
P: 34
Ah, I forgot about that. Thanks!
HallsofIvy
#7
May2-10, 08:16 AM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 39,322
a. 2e^kty
If this means y=-2e^(kty) then its derivative is dy/dt= 2ke^(kty)(ky+ kt(dy/dt)).
dy/dt(1- 2kt e^(kty)= 2k^y e^(kty). No, that differential equation is not satisfied.
b. 2e^kt
If y= 2e^(kt), then dy/dt= 2(ke^(kt))= k(2e^(kt))= ky and satisfies the equation.
(I am assuming the parentheses combine these as you wanted- that you did not intend 2(e^k)t.)
c. e^kt + 3
If y= e^(kt)+ 3, then y'= ke^(kt) which is not ky= k(e^(kt)+ 3)
d. kty + 5
If y= kty+ 5, then dy/dt= ky+ kt dy/dt so dy/dt(1- kt)= ky and dy/dt= (k/(1-kt) y. That does not satisfy the given equation.
e. .5ky^2 + .5
If y= .5y^2+ .5, then dy/dt= 1.0 y dy/dt so dy/dt(1- y)= 0. Either dy/dt= 0 or y= 1. That does not satisfy the given equation.
Register to reply
Related Discussions
Nonzero photon mass High Energy, Nuclear, Particle Physics 31
Matrices Proof> C=A-B, if Ax=Bx where x is nonzero, show C is singular Precalculus Mathematics Homework 1
Vacuum solution with nonzero cosmological constant Special & General Relativity 8
Every nonzero f(x) in F[x] has a unique monic associate in F[x] Calculus & Beyond Homework 1
Oscillator with an inductance with nonzero resistance Electrical Engineering 2
