| Thread Closed |
maximums and minimums |
Share Thread | Thread Tools |
| May2-10, 03:11 AM | #1 |
y3=6xy-x3-1 , find dy/dx . Prove that the maximm value of y occurs when x3=8+2sqrt(114) and the minimum value when x3=8-2sqrt(114) 2. Relevant equations 3. The attempt at a solution I found dy/dx to be (2y-x2)/(y2-2x) Then from here , dy/dx=0 for turning points and it happens when y=1/2 x2 Substitute this back to the original equation and find x from there using the quadratic formula [tex]x^3=\frac{16\pm\sqrt{16^2-4(1)(8)}}{2}[/tex] which simplifies to [tex]x^3=8\pm \sqrt{56}[/tex] First off , the x coordinate of my turning points is wrong but where is that mistake ? Also , How do i test whether this is a max or min ? Second order differentiation doesn't help .. |
| May2-10, 09:51 AM | #2 |
Hi thereddevils!
![]() (have a square-root: √ )The one in the book has √456 instead of √56 … perhaps someone pressed the wrong button?
| May2-10, 10:30 AM | #3 |
I am a bit reluctant to do the second order differentiation as there are 'y's in the dy/dx equation . When i put dy/dx=0 , y= 1/2 x^2 can i substitute this into the dy/dx equation to get rid of the y ? |
| May2-10, 12:30 PM | #4 |
maximums and minimumsd2y/dx2 = ∂/∂x(f(x,y)) + ∂/∂y(f(x,y))dy/dx the second term will be zero, and you put the x = 3√(8 ± etc) and y = 1/2 x2 into the first term.
| May2-10, 10:15 PM | #5 |
Can i differentiate implicitly instead of partial diff ? I tried , [tex]\frac{d^2y}{dx^2}=\frac{(y^2-2x)(2dy/dx-2x)-(2y-x^2)(2y dy/dx-2)}{(y^2-2x)^2}[/tex] when dy/dx=0 , y= 1/2 x^2 d2y/dx2=-8/(x3-8) x= 2.49(max) or 0.80(min) |
| May3-10, 02:18 AM | #6 |
Yes, that's fine (though I haven't checked the last two lines).
| Thread Closed |
| Thread Tools | |
Similar Threads for: maximums and minimums
| Mathematica Question: Finding local maximums | Math & Science Software | 1 | ||
| Mohr's Circle and understanding its maximums and minimums | Classical Physics | 2 | ||
| how to find global/local minimums/maximums. | Calculus | 2 | ||
| maximums and minimums | Calculus & Beyond Homework | 7 | ||
| finding maximumx and minimums | Calculus & Beyond Homework | 5 | ||
