How do I combine series sums into one representation?
  • Thread starter Thread starter Susanne217
    Series Sum Sums
The discussion revolves around combining three series sums into a single representation, specifically focusing on the series \(\sum_{n=2}^{\infty} a_n \cdot z^n - \sum_{n=1}^{\infty} a_n \cdot z^{n+1} + \sum_{n=0}^{\infty} a_n \cdot z^{n+2}\). Participants are exploring how to manipulate these series to achieve a unified form.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Some participants suggest writing out each series in full to collect like powers of \(z\). Others discuss changing summation indices to align the series, questioning how to properly adjust the indices and whether to add or subtract them. There is also a focus on ensuring that the series have the same limits for proper combination.
Participants are actively engaging with the problem, offering various methods for rewriting the series and questioning assumptions about index manipulation. There is no explicit consensus yet, but several productive lines of reasoning are being explored, including the use of dummy variables and the effects of changing summation limits.
Some participants express uncertainty about the rules for combining series and the implications of changing indices. There are indications of gaps in knowledge regarding series manipulation, which are being addressed through collaborative discussion.
Susanne217
I have these three series here
[tex]\sum_{n=2}^{\infty} a_n \cdot z^n - \sum_{n=1}^{\infty} a_n \cdot z^{n+1} + \sum_{n=0}^{\infty} a_n \cdot z^{n+2}[/tex]
what I would like to do is to add the together as one sum representation
From what I can see the commen sum of three is
[tex]\sum_{n=0}^{\infty} (a_{n+2} - a_{n+1} +a_{n})z^n[/tex] is that right?
What I don't remember do I add the index's together or subtract them?
If not please direct to a webpage with rules on howto do the above right :) Cause I have a whole in my knowledge then regarding to above :(
Susanne
In Mathematics there's so much stuff to learn, you don't want to fill your head with rules for every thing.
Why don't you try writing each sum out in full and collect like powers of z, and see what kind of new sum that gives you.
In the second sum, let k= n+1 so that n= k-1. When n= 1, k= 0 so you will have a sum in which k runs from 0 to infinity:
[tex]\sum_{n=1}^\infty a_n a^{n+ 1}= \sum_{k=0}^\infty a_{k-1}z^k[/tex]
And since the "k" or "n" in each sum is a dummy index, you can just replace "k" with "n":
[tex]\sum_{n=0}^\infty a_{n-1}z^n[/tex]
Now you can add "like powers" in the two sums- although, since the first sum starts at n= 2, you have to treat n=0 and n= 1 separately.
Susanne[/QUOTE]
Susanne
[/QUOTE]
I tried I again and I always end up with [tex]\sum_{n=0}^{\infty} (a_{n+2} - a_{n+1} +a_{n})z^{n+1}[/tex] ??
HallsofIvy made a rare mistake above. Let me explain it without intorducing another summation variable. Let's focus on the first summation from n = 2 to infinity. You'll get the same terms in that summation if you let n run from zero to infinity and at the same time you replace n by n + 2. What you are then doing is saying that:
f(2) + f(3) + f(4) + ...=
g(0) + g(1) + g(2)+...
if we define g(n) as f(n+2), so that g(0) = f(2), g(1) = f(3) etc.
As I understand you [tex]a_{n+2}z^{n+2}[/tex]
Yes, that's correct. You can write out the first few terms and convince yourself that you get the same terms.
Any chance you would write the other two sums like the above. Then I could use that to check the rest of my result :)
Susanne
Well, the second summation is of the form:
f(1) + f(2) + f(3) + ...
where f(n) = a_n z^(n+1)
If you want to write
f(1) + f(2) + f(3) + ... as
how do yo have to define g(n) in terms of f(n)?
You should have offered a correction then -- using summation symbols.
What you need to do in general, Susanne217, is to first modify the series so that the power terms are of the same form for each of the series. Do not worry about the limits of the series at this stage. So, let's do that, once again picking on the second series.
[tex]\sum_{n=1}^\infty a_n z^{n+ 1}[/tex]
The series on the left is simply the second series from the original post. From above, the goal here is to express the power term of each of the series in the same form. The canonical form is [itex]z^n[/itex], but here we have terms involving [itex]z^{n+1}[/itex]. So, substitute [itex]k=n+1[/itex], or [itex]n=k-1[/itex]. This substitution may affect other factors in a summand will affect and the sum limits as well. In this case, the factor of [itex]a_n[/itex] becomes [itex]a_{k-1}[/itex] since [itex]n=k-1[/itex] and the lower sum limit changes from [itex]n=1[/itex] to [itex]k=2[/tex] since [itex]k=n+1[/itex]. Thus<br /> <br /> [tex]\sum_{n=1}^\infty a_n z^{n+ 1}= \sum_{k=2}^\infty a_{k-1}z^k[/tex]<br /> <br /> As Halls mentioned, the index is just a dummy variable. There is nothing wrong with changing the <i>k</i> in the series on the right hand side with an <i>n</i>, yielding<br /> <br /> [tex]\sum_{n=1}^\infty a_n z^{n+ 1}= \sum_{n=2}^\infty a_{n-1}z^n[/tex]<br /> The next stage is to form a single series. Now you do have to worry about the summation limits. Different example from above, suppose you are asked to compute<br /> <br /> [tex]S = \sum_{n=0}^{\infty} b_n z^n + \sum_{n=0}^{\infty} c_n z^{n+1}[/tex]<br /> <br /> After the first step this becomes<br /> <br /> [tex]S = \sum_{n=0}^{\infty} b_n z^n + \sum_{n=1}^{\infty} c_{n-1} z^n[/tex]<br /> <br /> Now we have a problem: The two series don't have the same limits. What you need to do is expand some of the series so that do have series with the same limits. Thus<br /> <br /> [tex]S = b_0 + \sum_{n=1}^{\infty} b_n z^n + \sum_{n=1}^{\infty} c_{n-1} z^n[/tex]<br /> <br /> Finally, the series can be combined. Note that this might well mean a few stray terms that are not a part of the series.<br /> <br /> [tex]S = b_0 + \sum_{n=1}^{\infty} (b_n +c_{n-1})z^n[/tex][/itex]
See next post...
Thats so funny cause I get the following result myself
Let [tex]\frac{1}{1-z+z^2} = \sum_{n=0}^{\infty} a_n \cdot z_n[/tex]
where [tex]a_{1} = a_0 = 1 \Leftrightarrow a_{1}-a_{0} = 0[/tex] and [tex]a_2=0[/tex] and [tex]a_{n+3} + a_n = 0[/tex]
By the theorem of Identity
[tex]1 = 1 - z + z^2 \sum a_n \cdot z^n = a_0 + (a_{1}-a_{0})z + a_{2} \cdot z^2 + \sum_{n=3}^{\infty} a_n \cdot z^{n} - \sum_{n=1}^{\infty} a_{n} \cdot z^{n+1} + \sum_{n=0}^{\infty} a_n z^{n+2}[/tex]
If I write out the first sum I get [tex]\sum_{n=3}^{\infty} a_n \cdot z^{n} = a_3 z^3 + a_{4}z^4 + \cdots[/tex]
I write out a couple terms of the second sum [tex]- \sum_{n=1}^{\infty} a_{n} \cdot z^{n+1} = - a_1 \cdot z^{2} - a_2 \cdot z^{3} - \cdots[/tex]
If I make the commen index n = 0
it looks like the index increase at n+3 and at a power of n+2 such that
[tex]a_0 + (a_{1}-a_{0})z + a_{2} \cdot z^2 +\sum_{n=3}^{\infty} + a_n \cdot z^{n} - \sum_{n=1}^{\infty} a_{n} \cdot z^{n+1} + \sum_{n=0}^{\infty} a_n z^{n+2} = \sum_{n=0}^{\infty} (a_{n+3} +a_n)z^{n+2}[/tex]
How is that? Better I hope :)
Sincerely
Susanne
In the equation after the sentence "By the theorem of Identity"
you take out some terms of the summations with seems to be motivated in order to let the summations start with a z^2 term, but then you also take out a2 z^2 from the first summation on theright hand side of that equation. That defeats the purpose of your effort.
Instead, make sure that the three summations all start with z^2. So, don't take out the a2 z^2 term and instead let the first sumatrion of the r.h.s. be from n = 2 to infinity. Then you can shift the n for all the summations so that they all run from, say, zero to infinity (or from n = 2 to infinity, it doesn't matter what you choose). Then all the summations limits are the same and thus the power of z as a function of n will now be the same, so you can combine the three summations into one and take out the z^(n + something) in the summand.
Just understand you correctly Count Iblis,
I am suppose to end up with a sum that looks someward like this?
[tex]\sum( a_{n+3} + a_n ) z^{n+2}[/tex]
because I need it to satisfy the condition [tex]a_{n+3} + a_n = 0[/tex] because [tex]a_{n+3} = -a_{n}[/tex]
Yes, that's right. But note that if you rewrite the series in a more standard way, along the lines D.H and I have been suggesting, you find a recurrence relation the expresses a_n in terms of a(n-1} and a_{n-2} and from that you can then derive that
a_{n+3} = -a_{n}.
a_{n+3} = -a_{n}.
Count,
If I subtract the second sum from the first I get (Which is hopefully correct)
[tex]\sum_{n=1}^{\infty} a_{n-1}z^{n+1}[/tex] if this is correct my next logical step is to add this together with the third sum which produces
[tex]\sum_{n=0}^{\infty} (??)[/tex]
But there is a problem with my calculations count :(
If I add the third sum to the difference between the first two I get
[tex]\sum_{n=0} a_{n-2}z^{n+1}[/tex]
and it sums into on only one term which looks nothing like the intended target... What am I doing wrong? Why isn't it obvious :(
You are doing something wrong. Let me start from this point in your posting#12:
[tex]1 = \left(1 - z + z^2\right) \sum a_n \cdot z^n = a_0 + (a_{1}-a_{0})z + \sum_{n=2}^{\infty} a_n \cdot z^{n} - \sum_{n=1}^{\infty} a_{n} \cdot z^{n+1} + \sum_{n=0}^{\infty} a_n z^{n+2}[/tex]
Where I put the a_2 z^2 term back inside the summation relative to what you did. What you now have are summations that all start with z^2. If you now simply replace n by n-1 in the second summation, then you need to compensate for that by increasing the lower limit from n= 1 to n = 2. So, the summand in the second summation then contains z^n as in the first summation and it starts at the same lower limit for n, but, of course, you now have a_{n-1} in there.
You can then rewrite the last summation in the same way, i.e. change n to n-2 and simultaneously increase the lower limit from n=0 to n = 2.
Okay then by this I simply transformer this into
[tex]1 = \left(1 - z + z^2\right) \sum a_n \cdot z^n = a_0 + (a_{1}-a_{0})z +\sum_{n=2}^{\infty} a_{n}z^{n} - \sum_{n=2}^{\infty} a_{n-1} z^{n+1} + \sum_{n=2}^{\infty} a_{n-2} z^{n+2}[/tex]
But I can follow this being a recurcive relation half way and its suppose to be n+3 because it has three terms?
[tex]= \left(1 - z + z^2\right) \sum a_n \cdot z^n = a_0 + (a_{1}-a_{0})z +\sum_{n=2}^{\infty} a_{n}z^{n} - \sum_{n=2}^{\infty} a_{n-1} z^{n+1} + \sum_{n=2}^{\infty} a_{n-2} z^{n+2}[/tex]
You didn't do that right.
Don't worry about that yet. You will get a different recursive relationship here, and the you will derive the desired one.
Good then I'm only semi stupid...
Anyway please my first step is to squize the two sums 1) and 2) together :)
If I change the index to n = 0 in the third sum I get
[tex]\sum_{n=0}^{\infty} a_n z^{n+2}[/tex]
But the difference sum if I do something simular to series 1) and series 2)
their difference sum is still:
[tex]\sum_{n=0}^{\infty} a_{n+1} z^{n+2}[/tex] and that's a long way off from
a_n+3 + a_n ??
Let's change the index in the third sum,
The goal here is to get a sum that involves [itex]z^n[/itex] rather than [itex]z^{n+2}[/itex]. One way to avoid confusion is to invent a new dummy index variable. So, define m=n+2. With this the sum becomes
[tex]\sum_{m=2}^{\infty} a_{m-2} z^m[/tex]
Now rename that index variable back to n:
[tex]\sum_{n=2}^{\infty} a_{n-2} z^n[/tex]
Now do the same thing to the second sum. When you are done you should have something like
[tex]1 = \left(1 - z + z^2\right) \sum a_n \,z^n = a_0 + (a_{1}-a_{0})z + \sum_{n=2}^{\infty} a_n \,z^n - \sum_{n=2}^{\infty} b_{n} z^n + \sum_{n=2}^{\infty} c_n z^n[/tex]
where the [itex]b_n[/itex] and [itex]c_n[/itex] are expressed in terms of some appropriate element from the set [itex]\{a_n\}[/itex].
I'm one to something now
[tex]a_0 + (a_{1}-a_{0})z + \sum_{n=2}^{\infty} (a_n - b_{n} )z^n = - \sum_{n=2}^{\infty} c_n z^n[/tex]
and for the second sum
[tex]\sum_{n=0}^{\infty} a_n z^{n+1}[/tex]
The goal here is to get a sum that involves [itex]z^n[/itex] rather than [itex]z^{n+1}[/itex]. One way to avoid confusion is to invent a new dummy index variable. So, define m=n+1. With this the sum becomes
[tex]\sum_{m=2}^{\infty} a_{m-1} z^m[/tex]
[tex]\sum_{n=2}^{\infty} a_{n-1} z^n[/tex]
How is that ?? and I'm supose to combine sum 1) and 2) into a_n+3 now?
Don't worry about that yet! First get the sum right. Then worry about that. You are putting the cart before the horse.
Sorry, but what's my next step then? Cause the whole thing doesn't look obvious to me..
The next step is to combine the series into one. You are hung up on this an+3 thing. You will not get the result an+an+3=0 when you form the series, so best to forget about that for now. You will get a different recursive relationship. From that you should be able to derive the result you are expecting to see.
