Calculating Planetary Acceleration in the Solar System | Venus, Mercury Data
The discussion revolves around calculating the acceleration of planets in the solar system, specifically focusing on Venus and Mercury. Participants are provided with mass, distance, and gravitational force data for each planet and are tasked with determining their acceleration, speed, and orbital period.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to apply the equation f=ma to calculate acceleration but questions the validity of their results, suspecting their force value may be too high. Other participants raise questions about the accuracy of the force value used and suggest alternative formulas for calculating acceleration.
Some participants have offered guidance on the formulas to use, with one suggesting the centripetal acceleration formula. There is an ongoing exploration of the values and methods, with no explicit consensus reached on the correct approach yet.
Participants are working under the constraints of provided data and are questioning the accuracy of their initial calculations and assumptions regarding the force values.
aidan
Evening all.
My teacher has given us the mass, distance, and gravitational force of every planet in the solar system. we have to work out every planets acceleration, speed, and orbital period.
I'm having some trouble with the acceleration. This sshould be a very small number right?
I'm using the equation f=ma. (This is for Venus)
f=ma
a=f/m
f=1.12*10^34
m=4.89*10^24
now when i do f/m i get 2,290,388,548. Thats a huge number and I'm sure that Venus can't be accelerating that much.
My answer for Mercury was 0.0246 m/s.
Please help!
Your value for f is way too high. How did you arrive at this number?
I think the formula you want for the acceleration is (v^2)/R where v is velocity and R is the radius of the planets orbit. Hope that helps.
There's nothing wrong with his method, just the starting numbers.
For instance, with your method, he would first have to get the planet's velocity.
given that centripetal force = Mv²/r,
v= [squ] fr/M) =
(using the numbers given)
[squ](1.12 e34 * 1.082e11/4.89e24 = 1.57e 10 m/s
plug this into v²/r gives
(1.57e10)²/1.082e11 = 2286154928
Which is of the same order as the answer he already has.
i got f doing this:
f = G.m1.m2 / r^2
G = 6.67*10^-11
m1 = 1.99*10^30
m2 = 4.89*10^24
r = 1.08*10^11
which equals, = ...5.56*10^22
is this better??
Originally posted by aidan
i got f doing this:
f = G.m1.m2 / r^2
G = 6.67*10^-11
m1 = 1.99*10^30
m2 = 4.89*10^24
r = 1.08*10^11
is this better??
Yes.
  • · Replies 21 ·
11K
