Extending time of energy production
  • Thread starter Thread starter dk1558
    Energy Time
The discussion revolves around methods to extend the duration of energy production from electromagnetic generators. Participants explore various designs, circuit configurations, and mechanical enhancements to sustain voltage output over a longer period, specifically aiming for at least 5 seconds of usable energy at a minimum of 2-3V.
  • Some participants inquire about methods to extend the energy output duration of electromagnetic generators, which currently provide AC 9V for about 1 second before dropping to 0V.
  • There are suggestions to design a circuit that could stabilize the output voltage to at least 2-3V for 5 seconds, with considerations for using components like bridge rectifiers and capacitors.
  • One participant proposes adding a flywheel to the generator shaft to maintain rotational speed longer after the initial force is applied, potentially allowing for extended energy production.
  • Concerns are raised about the complexity of integrating rechargeable batteries into the system, including questions about the required energy type (AC or DC) and the feasibility of charging them effectively.
  • Another participant expresses frustration regarding the posting of the same question across multiple forums, indicating a potential violation of forum rules.
Participants have not reached a consensus on the best method to achieve the desired energy output duration. Multiple competing ideas and approaches are presented, with no clear resolution on which is most effective.
The discussion includes various assumptions about the mechanical and electrical properties of the generators, as well as the limitations of proposed solutions, such as the potential decrease in voltage when using certain components.
This discussion may be of interest to individuals involved in energy generation, electrical engineering, or those exploring innovative designs for energy storage and output stabilization.
dk1558
I was wondering what I should do to extend the time of energy production from generators
I have several electromagnetic generators (size of about 1cm x 3cm x 6cm)
When the button of the generator is pressed with a force of about 50N downwards in about 0.3sec, the coil inside rotates for about 1second and gives off energy of about AC 9V which decreases rapidly in an exponential graph shape to 0V in 1sec.
This energy can be used to light 3LED bulbs for the duration of energy output. The LED lights up brightly, then fades rapidly.
If I have lots of these generators, is there a method to extend the time of energy output to upto 5seconds?
The entire system should still be about 10cm x 20cm x (? height)
I just want to find various ways to extend the length of energy being produced. And if possible the entire system should require only one type of motion. (e.g. The foot pressing down on a pedal which is the system)
And the voltage should still be hopefully above 2~3V output at all times of 5sec
Energy production with electromagnetic generators
I have lots of electromagnetic generators (size of about 1cm x 3cm x 6cm)
Is there any method or design or orientation of the system components to sustain the output energy to at least 2~3V for at least 5secs?
And the force or work done upon the system to work the device should be not too complicated. (e.g. pressing down on a pedal with the foot, pulling on a cord, pressing a button)
I was thinking of making a time delay in the generators being pressed down by adding additional parts under the pedal but I'm not sure in what orientation it would be best
Designing a circuit to even out energy
I have several energy sources like batteries.
When activated, these produce electricity for 1second AC 9V which decreases to 0V in exponential curve.
Is there a circuit that could allow the energy output to be at least 2~3V for at least 5seconds? with as little fluctuation in voltage as possible
I was thinking of placing a bridge rectifier first to make everything DC as soon as electricity is made from each generator (which would decrease the voltage slightly due to resistance) but voltages will no longer be cancelling each other.
Would a diode be better in this case??
Then add capacitors in parallel to even out the voltage even though it would decrease the overall voltage quite considerably.
Then add lots of additional capacitors to increase the discharge time to upto 5secs, which is quite unrealistic.
Another thing I was thinking of was adding some additional components to create a delay in the energy produced by each generator being used up.
also, I thought of placing a rechargable battery in the system, but would it require AC or DC energy and would it be possible to supply energy to the battery for 1sec every time for about 20times and charge up the battery for use later? The recharging system itself seems very tricky to actually make from scratch
I am looking for improvements or even better ideas.
Maybe you can add some sort of flywheel to the generator shaft. This will make it 'harder' to actuate - you will have to push down with more than your current 50 Newtons to get the shaft up to speed. But the shaft will remain spinning longer once you stop pushing.
why are you posting the same question in multiple fora?
3 threads from different PF forums merged.
dk1558, please do not multiple post your question across multiple PF forums. That is against the rules here.
And to answer your question, you should use a buck DC-DC converter to most efficiently down-convert your power sources to make your regulated output voltage:
http://en.wikipedia.org/wiki/Buck_converter
  • · Replies 0 ·
9K
  • · Replies 17 ·
  • · Replies 62 ·
13K
