Re:star crust 10 billon times stronger than steel
  • Thread starter Thread starter bayboy144l
    Steel
The discussion revolves around the concept of neutron stars, particularly focusing on their crust and the feasibility of mining materials from them. Participants explore the nature of neutron star crusts, the implications of their extreme conditions, and the theoretical aspects of material strength in such environments.
  • Some participants suggest that the original question may pertain to neutron stars, which are characterized by a crust that is not solid but rather a result of extreme conditions.
  • It is proposed that neutron stars have an iron crust, but mining such material would be impractical due to the intense gravity that holds it together.
  • Concerns are raised about the stability of materials if removed from the neutron star's gravity, with claims that iron would evaporate and neutrons would decay into other particles once the gravitational force is absent.
  • One participant describes the neutron star crust as being composed of heavy nuclei and electrons, with varying densities, and discusses the implications of electron degeneracy pressure.
  • There is speculation about the stability of strange quark matter compared to nuclear matter, suggesting that it may be more stable under certain conditions.
  • Questions are posed regarding the definition of "strength" in the context of materials that exist without chemical bonds, indicating a potential limitation in synthesizing such strong materials on Earth.
Participants express various viewpoints on the nature of neutron stars and the implications of their crusts, with no consensus reached regarding the feasibility of mining or the properties of materials in such extreme environments.
Participants acknowledge the complexities of neutron star physics, including the dependence on gravitational conditions and the stability of materials, but do not resolve these issues definitively.
bayboy144l
Just out of curiousity, regardless that we can't reach it, can a star like that be mined? would it still retain its strength?
Astronomy news on Phys.org
A star is not made of solid material...it's a huge ball of gas/plasma basically.
I'm guessing the OP is thinking of a neutron star - that's the only thing i can think of with a 'crust'.
But no - it's only a crust because of the conditions on the star, if you removed it - the neutrons would just form into a ball.
Neutron stars are believed to have an iron crust. The reasons are fairly complicated. Mining them would be impractical. If you somehow managed to remove a hunk, it would evaporate once you pulled it away. The intense gravity of the neutron star is all that holds that stuff together.
Even if you were to mine something from a neutron star, when you got it back to Earth (assuming it was a significant amount) it would be way too massive to use for anything.
Could you please explain this in more depth? Why would the iron evaporate and would the neutron material evaporate also?
Essentially it is like a extremely compressed spring and it is the intense gravity that keeps its compressed. Once that gravity is removed, all that energy stored by the compression is released, and it is enough to evaporate the iron.
As far as the neutronium is concerned, neutrons, on there own, are unstable particles with a half life of about 15 min. Again, it is the intense gravity that prevents them from decaying into a proton, electron and an electron-antineutrino. Remove the gravity and the mass will begin to decay.
Very interesting, thanks :smile:
It's kind of sad that we can't synthesize materials that strong another way. Isn't there some kind of ceiling that physics puts on the strength of materials under Earth conditions?
I'm wondering if the word "strong" really should apply since this material exists in an environment where chemical bonds aren't possible.
Good point Russ...
If were talking about the crust of a neutron star then it should typically still be electron degenerate. The outer crust would be heavy nuclei (Fe56 --> Ni62 --> Kr118) and electrons while the inner crust would be neutron rich nuclei with a superfluid of neutrons and electrons but still the pressure would be from electron degeneracy. This crust would be a little over a km deep and the density would range from 1e+9 to 2e+17 kg/m3 (or 1 to 2e+8 tonnes/cm3, the size of a sugar cube). http://var.astro.cz/brno/perseus4_2002_clanek2.pdf" page 2.
In regard of neutron degenerate matter, as already stated, if you take neutron degenerate matter out of the gravity field, it will fly apart, but there is a prediction for some quark stars (or strange stars) that strange quark matter might be stable-
'..When comparing the energy per baryon of Fe56 and nuclear matter with the energy per baryon of 2-flavour (u,d quarks) and 3-flavour (u,d,s quarks) strange matter, theoretically the energy per baryon of strange quark matter may be below 930 MeV, which would render such matter more stable than nuclear matter. Fe56 ~930 MeV, 2-flavour quark matter ~1250 MeV, 3-flavour quark matter ~830 MeV...'
http://arxiv.org/PS_cache/astro-ph/pdf/0407/0407155v2.pdf page 19, fig. 11
  • · Replies 21 ·
  • · Replies 36 ·
  • · Replies 28 ·
