Thread Closed
Magnetic field problem: What are the magnitude and direction of the electric field..
Share Thread Thread Tools
May8-10, 10:19 AM   #1
I am confused about two parts of the question. 1 How are they getting the calculation of dB/dt=0.06 and how do they know the direction of the field is perpendicular to r and couterclockwise?
A magnetic field directed into the page changes with time according to B=(0.03t^2+1.4)T, where t is in seconds. The field has a circular cross section of radius R=2.5cm. What are the magnitude and direction of the electric field at point P1 when t=3.00s and r1=0.02m.
The figure is located on this webpage at the bottom: http://www.phys.ncyu.edu.tw/~ccliu/i...29to31Appl.pdf
It's basically a circle. P2 is on the outside going toward the center. P1 is going up and to the right but is inside the circle. R in going down and right out of the circle.
2. Relevant equations
3. The attempt at a solution
dB/dt=0.06t
E=(0.02m/2)(0.06)(3)(1) =1.8*10^-3 directed perpendicular to r1 and counterclockwise.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
May8-10, 06:55 PM   #2
1) Take the derivative of B with respect to time to get dB/dt.
2) You can derive the direction from Faraday's law. Or you can use the right hand rule, where you align your thumb in the direction opposite of the changing magnetic flux (in order to oppose the changing flux) and your fingers curl in the direction of the E-field.
In this case since area is fixed and the magnetic field is increasing into the page, you point your thumb out of the page and curl your fingers using your right hand.
Thread Closed
Thread Tools
Similar Threads for: Magnetic field problem: What are the magnitude and direction of the electric field..
Thread Forum Replies
Magnitude and Direction of Magnetic Field Introductory Physics Homework 3
Magnitude and Direction of Electric Field Introductory Physics Homework 2
Magnitude & Direction of Magnetic Field Introductory Physics Homework 0
Magnitude and direction of electric field Introductory Physics Homework 0
