Register to reply
Pushing a box up a ramp a certain distance - work
by mybrohshi5
Tags: distance, ramp, work
Share this thread:
mybrohshi5
#1
May8-10, 08:07 PM
P: 365
A horizontal 25 N pushing force acts on a 10 kg crate moving up a ramp. The ramp is inclined at 37 degrees above the horizontal.
How much work is done by this force in moving the crate a distance of 15m along the ramp?
2. Relevant equations
W = Fd
3. The attempt at a solution
This was on a previous test i took and i got it wrong and now looking over it again i cannot seem to figure it out.
I thought i could take the component of the pushing force parallel to the ramp and subtract the component of the weight of the block that is parallel to the ramp then just multiply that by the distance but that didnt work out to well.
here is was i did
The component of the pushing force parallel to the ramp is
25cos(37) = 19.96
the component of the weight parallel to the ramp (and opposite in direction of the component of the pushing force parallel to the ramp) is
mgsin(37)
10(9.8m/s^2)sin(37) = 58.9
so subtract those two
19.9 - 58.9 = - 39N
so W = 39N(15m)
W = 585 J
the correct answer is 300 J
Any help would be great.
Thank you :)
Phys.Org News Partner Science news on Phys.org
Suddenly, the sun is eerily quiet: Where did the sunspots go?
'Moral victories' might spare you from losing again
Mammoth and mastodon behavior was less roam, more stay at home
PhanthomJay
#2
May8-10, 08:27 PM
Sci Advisor
HW Helper
PF Gold
PhanthomJay's Avatar
P: 6,036
You are calculating the work done by the pushing force and gravity (and you left out the minus sign). But the problem asks for the work done by the pushing force only.
mybrohshi5
#3
May8-10, 09:13 PM
P: 365
oh so since its just the work done by the pushing force, i dont even have to factor in the other forces. Got it.
If it would have asked how much work does it take to move the block 15 m then would that mean i would have to factor in the other forces like i did in my first post?
I just feel like i dont know when i would have to consider the forces of the weight of the block being pushed.
mybrohshi5
#4
May10-10, 08:23 PM
P: 365
If this problem would have asked for the total work required to push the block up the ramp 15 m then would i have had to consider in the force of gravity like i did in my first post?
PhanthomJay
#5
May16-10, 09:28 PM
Sci Advisor
HW Helper
PF Gold
P: 6,036
Quote Quote by mybrohshi5 View Post
You'd have to consider the work done by all forces to calculate the total work done on the block. In your example, the block would not move up the ramp if there were no other forces acting besides the pushing force and the block's weight, so there has to be anothner force acting (not given) to move it up.
Register to reply
Related Discussions
Work (done by gravity) - pushing up a ramp Introductory Physics Homework 12
How much work and how much force do we use in pushing a box Introductory Physics Homework 2
Finding the velocity and covered distance of Astronaut pushing asteroid Introductory Physics Homework 7
Pushing Cart Down a Ramp Introductory Physics Homework 1
Distance from ramp Introductory Physics Homework 2
