Questions about phase velocity, and group velocity
The discussion revolves around the concepts of group velocity and phase velocity, particularly in the context of quantum mechanics and de Broglie waves. Participants explore the definitions, implications, and experimental considerations related to these velocities, especially concerning electrons and photons.
  • Some participants assert that group velocity represents the velocity of a particle, while phase velocity is related to the wave's mathematical properties and is typically higher.
  • There is a discussion about the relationship between the speed of light and the velocities of electrons, with some questioning whether the speed of light differs from the group velocity of electrons.
  • Participants express doubts about how to experimentally determine the frequency of an electron and the phase velocity of a photon.
  • Some argue that negative group velocity can occur in certain materials, leading to the peak of a wavepacket exiting before the pulse enters, while others challenge this interpretation.
  • References to de Broglie's experiments are made, highlighting the wave nature of electrons and the complexities involved in measuring their properties.
  • Concerns are raised about the physical significance of phase velocity and its measurement, particularly in relation to photons.
Participants express multiple competing views on the definitions and implications of group and phase velocities. The discussion remains unresolved, with differing interpretations and understandings of the concepts presented.
Some statements rely on specific experimental conditions or theoretical frameworks, which may not be universally applicable. The discussion includes unresolved mathematical steps and varying interpretations of the implications of group and phase velocities.
This discussion may be of interest to students and researchers in quantum mechanics, wave physics, and those exploring the nuances of wave-particle duality.
ntusg
"Group velocity (equal to an electron's speed) should not be confused with phase velocity (equal to the product of the electron's frequency multiplied by its wavelength)."
Above statement is from wikipedia, and I still don't quite understand it.
As one of the postulate of QM, group velocity represent the velocity that a particle is moving.
However, in DeBrogile relationship, after we know the speed of electron c, then we can know the wavelength and frequency by using wavelength=h/mc. and f=c/wavelength. Does the speed c here differs from the group velocity of electrons.
I am quite new to quantum mechanics, and appreciate if anyone help to explain on this topic, thanks:smile:
Group velocity is considered the propagation speed of the wave (if the entity is a wave) or the velocity of the particle (if the entity is a particle) Phase velocity is typically much higher in value and is not considered to have direct physical significance. It tells you how fast the mathematical plane is moving which generates the harmonic fluccuations in the wave pattern.
In a light wave in a pure vacuum the phase velocity equals the group velocity which also equals c - the speed of light. Matter and de Broglie waves associated with matter will have a lower group velocity but a higher than c phase velocity.
I have some doubts about your relation for the frequency of the electron. How would you determine experimentally that frequency?
How is it possible to measure the phase velocity of a photon (light wave)?.
Just remember that the group velocity is also not free from interpretational issues. For example, as has been demonstrated in fast light experiments, it's possible to create a material in which the group velocity for a photon is higher than c, and even negative. Negative group velocity would mean that, say, the peak of the wavepacket exits the material before it enters. This still does not violate causality, so the lesson here is that the group velocity of an object does not correspond to the speed by which the information from this object is sent.
It can't be measured directly of course. It's wavenumber and angular frequency are determined according to the de Broglie relations for the photon of a measured frequency. The phase velocity is then the angular frequency divided by the wavenumber.
For a photon that's all nice. However, the original poster was asking for the case of an electron.
In de Broglie's textbook "Introduction to the Study of Wave Mechanics" he analyzes the results of the first few experiments that were shown to prove his theory of "matter waves". Especially in G. P. Thomson's experiments, a large number of trials with different parameters were made each yielding a unique result. Those results would be very, very difficult to explain if anything other than a wave accompanying the electron were to produce them. He photographed the circular pattern of the wave of single electrons when shot through various ultra-thin wafers of material and could easily bend the pattern by applying a magnetic field.
"" Negative group velocity would mean that, say, the peak of the wavepacket exits the material before it enters.""
It does not mean that.
Waves build up at the front of the photon and move backwards through the photon until
they fade away at the back of the photon.
Positive phase velocity means that the waves build up at the back and move forward through the photon and fade away at the front.
Neither can carry information faster than the photon.
Tbh, I don't quite get what you mean, though note that I made a comment about group velocity, not phase velocity.
What I was referring to is the fact that by tailoring the group refracting index of a material in special ways, one can make the group velocity have any number, including such values that gives rise to speeds higher than c or even negative speeds. The meaning of a negative velocity really is that a particluar chosen point in a pulse packet, for example the peak of the pulse, will exit such a prepared material before the peak of the incoming pulse enters it.
This behavior has been experimentally verified, for example here:
L. J. Wang, A. Kuzmich and A. Dogariu. Gain-assisted superluminal light
propagation. Nature 406, 277 (2000),
where the pulse exited the material 62 ns (19 meters travelled) before it entered. The point is still clear however, that while the peak may travell faster than c, information transfer from such a pulse never exceeds c, because the peak of a wavepacket is not a good definition of the information content.
You are right .You did say group velocity.
The faster than light propagation of a photon in the special material sounds like a trick of words.
As the photon enters the material the peak is at the back?.
As the front of the photon leaves the material the peak is at the front,a different wave
(in the same photon) but now bigger (modified by the material) so it is now the photon peak.
The back of the photon has not entered the material yet but the front is coming out.
So the photon peak at the front leaves before (a different peak ) at the back enters.
The photon must be longer than the thickness of the material.
No problem with that.
The same wave OUT before IN violates causality so cannot be.
FTL is OK by me.
Causality violations are not OK.
How can such small time intervals be measured?.
Was it all just a calculation?.
  • · Replies 41 ·
  • · Replies 32 ·
  • · Replies 17 ·
