Does electron have real physical mass?
The discussion revolves around the concept of whether an electron possesses "real physical mass" at its center, exploring various interpretations of mass in the context of quantum field theory (QFT) and particle physics. Participants examine the nature of mass, its definitions, and implications in both theoretical and practical frameworks.
  • Some participants assert that electrons do have mass, questioning the meaning of "real physical mass" and suggesting that the distinction between wave and particle may be relevant.
  • One participant defines mass as a form of potential or binding energy, while others discuss the concept of "mechanical mass" as a mass devoid of electric or magnetic properties.
  • There is a claim that in QFT, electrons acquire mass through interaction with the Higgs field, leading to discussions about "naked mass" and the influence of virtual particles on the measured mass.
  • Participants express confusion over the terms "infinite mass," "naked mass," and "positive mass," with attempts to clarify their meanings and implications in the context of mass measurement.
  • One participant provides a specific numerical value for the mass of an electron, which is later corrected by another participant, indicating a discrepancy in understanding or representation of the mass value.
Participants do not reach a consensus on the definition of "real physical mass" or the implications of mass in the context of quantum mechanics. Multiple competing views and interpretations remain present throughout the discussion.
There are unresolved questions regarding the definitions and implications of mass in different contexts, including the distinction between energy-based mass and mechanical mass. The discussion also highlights the complexity of mass measurement in quantum field theory and the role of virtual particles.
kichigai
I read that the electron may not have a real physical mass at its center. Is that possible? Does the electron have real physical mass at its center?
An electron certainly has mass. I'm not sure that's what you mean by "real physical mass". When you are at the size of an electron, the distinction between wave and particle (which is what I suspect you mean) is not clear.
Mass is normally considered to be a form of potential energy or binding energy if I understand correctly. But "physical mass" or maybe it's called "mechanical mass" means something like a thing that has no electric or magnetic properties. Just a lump of something. I read about this in a book called: The Enigmatic Electron.
Mass is a physical property expressed through either inertia (resistance to movement) or gravity. Inertial mass is definitely a property of an electron. While electrons are affected by gravitational fields much like everything else, its own field is far too weak to measure directly.
Who authored that book, and what are the author's credentials?
[tex]M_e = 9.11*10^{-27} kg[/tex]
That's not correct. The mass of the electron is 9.1 E -31 kg, not -27.
In QFT, electrons have a mass after interacting with the Higgs-field. Mass can thus be seen as a sort of coupling constant for the "Higgs-interaction"
Once this mass is acquired, we have to take into account renormalization. The physical mass that we measure is not really the QFT-mass after Higgs-interaction. The mass acquired after this interaction is called the naked mass, but the particle is surrounded by an infinite amount of virtual particles that lead to an infinite mass-value. So the naked mass value is also infinite but in a socalled negative way so that the two contributions (naked mass + virtual particles) give a finite positive mass value. This is the real physical mass.
These virtual clouds that surround a "naked" particle are things that come from the QED of Feynman in order to describe the interactions between fermions for example.
regards
marlon
my mistake, soo many constants and masses on my mind.
Malcolm H. MacGregor, UC Berkeley / Lawrence Livermore National Labs now retired.
With respect to the gravity of the earth, this is the mass in its weight form. But I believe that particle physicists tend to use energy values such as: 0.511 MeV for the electron which is why it is easy to understand that mass is said to be potential energy or binding energy. (My use of the terms: potential energy and binding energy, are out of context.)
I find it easier to understand the energy based nature of mass when I think of some object in outer space where there are no obvious gravitational effects and yet the object still has the same form as it did on the surface of the earth. Then I think of the energy that exists within and between the protons, electrons and neutrons within that form.
In this case, are you describing energy based mass or mechanical mass (aka real physical mass)?
marlon
We speak of mass as being an energy value (often called potential or binding energy) and I asked about a "mechanical mass" which can also be called a "real physical mass" and so it seems we are describing the same object, but I want to be sure.
I think I understand that "real physical mass" is the interaction of "naked mass" and "virtual particles" where the virtual particles are within some distance of the naked mass, but I'm not quite understanding the other terms.
I need a bit more help with the terms:
a) infinite mass
b) naked mass
c) positive mass
what_are_electrons said:
a) infinite mass
b) naked mass
c) positive mass
a) i mean that the mass value has to be infinite because of the contributions of the virtual particles. You can think of these particles as having the same role of the index k (from 0 to infinity) when using the sommation sigma-operator. What are you summing up ? Well, All the different interactions in perturbationtheory.
b) this is the mass of the particle without taking into account the virtual particles.
c) euuh, I just mean a finite positive value...
regards
marlon
  • · Replies 124 ·
9K
  • · Replies 24 ·
