Calculating Degree of Unsaturation of C4H8O - Isomerism (Chemistry)
  • Thread starter Thread starter KLscilevothma
    Chemistry Isomerism
The discussion revolves around calculating the degree of unsaturation for the molecular formula C4H8O, exploring its implications for isomerism and structural possibilities. Participants engage in both mathematical reasoning and chemical theory, examining the validity of the formula used and the types of structures that can be derived from it.
  • One participant calculates the degree of unsaturation for C4H8O as 1, suggesting it indicates one double bond, but questions the formula's applicability to compounds with triple bonds or saturated compounds.
  • Another participant expresses skepticism about the philosophical implications of asking "why" in mathematics.
  • A participant explains the reasoning behind assigning values to carbon, hydrogen, and oxygen in the degree of unsaturation calculation, noting that carbon can form multiple bonds.
  • There is a discussion about the possible structures for C4H8O, including ketones, alkanols, ethers, and aldehydes, with one participant claiming there are 15 different possible structures.
  • Participants debate the feasibility of cyclic structures and the implications of valence bond theory on the number of hydrogens in cyclic compounds.
  • One participant mentions the confusion surrounding the structure of ethers and acknowledges a mistake in their earlier representation.
  • Another participant suggests various cyclic compounds and their IUPAC names, indicating a broader exploration of isomerism.
  • There are references to the challenges of organic chemistry and the importance of common names versus IUPAC nomenclature in identifying compounds.
  • Discussion shifts to tetrahydrofuran (THF) and its relevance to inorganic chemistry, with some participants expressing uncertainty about its connection.
Participants express a range of views on the calculation of degree of unsaturation and the implications for structural possibilities. There is no clear consensus on the validity of certain structures or the application of the degree of unsaturation formula, indicating ongoing debate and exploration of ideas.
Participants note limitations in their understanding of organic chemistry and the complexities involved in drawing accurate structures based on the degree of unsaturation. There are unresolved questions regarding the applicability of the formula to different types of compounds and the implications for cyclic structures.
KLscilevothma
To draw all possible structures for C4H8O, the first step we need to do is to calculate the degree of unsaturation of the molecule.
Degree of Unsatuation of C4H8O = (C+O-H)/2 = (2*4+2-8*1)/2 = 1 (meaning it has 1 double bond)
[degree of C=2, H=1 and O=2]
My question is why can the degree of unsatuation be caculated by the above formula, which only works for compounds with double bond(s) or satuated compounds. Also why is the degree of Carbon assigned to be 2, H=1 and O=2 ?
Biology news on Phys.org
I don't think it's possible to say "Why?" in Maths - because then you're in the realm of Mathematical Philosophy, which mathematicians apparently don't care to explain, and non-mathematicians cannot even begin to. :)
Mathematically, i don't really know what to tell you.
Chemistry wise, I don't usually see this equation and terms used much anymore. but to answer your question, the c=2 because the highest bond for it is 2, and O is 2 because it double bonds with carbon. H is almost always 1 because it singally bonds with the rest of the singally bonded carbons.
Originally posted by PeteGt
the c=2 because the highest bond for it is 2, and O is 2 because it double bonds with carbon. H is almost always 1 because it singally bonds with the rest of the singally bonded carbons. [/B]
Carbon can form triple bond with nitrogen (-nitriles) and it can also form triple bond with carbon itself (alkyne)
You are correct but the chemical you have listed is N-Butanone. Thus there are no triple bonds.
It doesn't necessarily belong to N-Butanone. Since C4H8O is only a moleuclar formula, after knowing it has 1 double bond, we know there are 4 possibilities.
1. Ketone (C=0)
2. Alkanol + C=C
3. Ether (-O-C-O-) + C=C
4. Aldehyde (C=OH)
In fact we can draw 15 different possible structures.
I get your point. As the formula (C+O-H)/2 can only be used to calculate how many double bonds it has, therefore there shouldn't be any triple bond.
--- and, how many cyclics?
I forgot to take cyclics into consideration. :wink:
1. Ketone (C=0)
2. Alkanol + C=C
4. Aldehyde (C=OH)
1.) Yeap it's a keytone alright, N-butanone
2.) Alkanol (proper alkene)-Can't be this. With a double bond between any of the carbons yields an H count > 8.
3.) Ether...nope, you have one Oxygen
4.) Aldehyde (watch how you write that, looks like an alcohol group with a double bond to carbon, violation of valence electrons. This is possible since an aldehyde and a ketone are the same thing. Just, an aldehyde occurs on the terminal carbon and has a c-h bond with it, while ketones have a bridging C with a =o and no c-h bonds.
Cyclics? Not possible by general valence bond theory, you would only have 6 or 7 hydrogens but not more.
http://www.angelfire.com/freak2/antiwork/2.bmp
Oops, ether should look like this, - C-O-C- , but not -O-C-O-. Sorry for the confusion.
http://www.angelfire.com/freak2/antiwork/3.bmp
Yes, I think you're right. I tried that just now and couldn't attatch 8 hydrogens to the carbon ring
Yeah, those look right, you're first one with the alkene, watch how you draw that, you've drawn a bond to a hydrogen :-)
But in everything you showed me there is a double bond with a carbon. As to why oxygen had it I dunno.
My field is not organic chemistry unforunately, but i'll toss it around the lab here tomorrow and find more info about that equation.
I'm a physical inorganic chemist.
Pete
Cyclobutanol, methyl-cyclopropyl ether, cyclopropyl methanol --- you can play with the IUPAC names on your own --- tetramethylene oxide (a cyclic ether) --- getting the picture yet?
Let's call it KL Kam's compound then, which doesn't exist.
Cool! In fact I only studied physical chemistry last school year (02-03), plus nomenclature of organic compounds(IUPAC) and part of the chapter about isomerism. I'll study organic chemistry and inorganic chemistry next school year.
C4H8O is an unsatuated compound after using ((C+O-H)/2) to calculate. But when I draw the sturcture you mentioned, it seems that they are correct too.
Why is it so?
http://www.angelfire.com/freak2/antiwork/structure.bmp
By the way, I don't know the struture of tetramethylene oxide, could you please show me?
"Cyclic ether:" swap oxygen for a methylene group in cyclopentane.
Gosh, I need to stay away from organic chemistry. I look at all these compounds and think, damned, how did i miss that one?
Good luck with studying inorganic this year. 400 level Inorganic?
This structuring that we are looking at here by trying to identify isomers of C4H8O. That's why when i can, always identify through common place names. (IUPAC gets to be annoying too) Like caffiene, thank god a can just refer to it as caffiene and now give a lecture about the IUPAC. :-)
THF, tetrahydrofuran, natural products chemistry (corn cobs), still explosions, Grignard rxns --- quite a few inorganic syntheses.
what does THF have to do with inorganic chemsitry?
And what are you saying? :-P
Just seems like that post came from rigth field. lol :-)
Pete
Can't put my hands on references, so, technically, this is hearsay; THF is/was a fairly popular solvent among the metal hydride crowd --- at least a few years back --- times change, and so do lab techniques --- never got into that business personally, and a quick check of Cotton & Wilkinson, Drago, and Greenwood & Earnshaw comes up blank --- mebbe I'm "worng."
