| New Reply |
Who is puzzled by the delayed choice? |
Share Thread | Thread Tools |
| May20-11, 09:08 AM | #18 |
Niels Bohr said:
"If quantum mechanics hasn't profoundly shocked you, you haven't understood it yet." To answer the question posed in the title of this thread, I would add: "If delayed choice quantum eraser shocked you more than the rest of quantum mechanics, you haven't understood the rest of quantum mechanics yet." |
| May21-11, 07:40 AM | #19 |
| May23-11, 03:56 AM | #20 |
| May30-11, 07:27 AM | #21 |
I believe now I finally understood the reason why so many physicists are puzzled by the delayed choice. Let me share it with you.
The origin is in the fact that such experiments are closely related to the so-called "WHICH WAY" experiments. The name of such experiments suggests that they really measure the way along which the particle travels. So, naive physicists are inclined to think that the particle chooses only one path (through only one of the slits) in these experiments, and therefore that there cannot be any interference effect. From that, it is easy to get a paradox and conclude that there must be a change-of-the-past involved. But this, of course, is wrong. The so-called "which way" experiments do NOT really measure the way along which the particle travels. Indeed, these experiments only measure the FINAL particle position at the detector, from which the rest of the particle's "path" is RECONSTRUCTED, rather then really measured. Moreover, this reconstruction is based on a naive classical reasoning about motion of particles, so validity of this reconstruction is very dubious. Actually, it is more than dubious - it is completely unjustified. Indeed, neither of the 7 major interpretations analyzed in post #1 justifies the assertion that these "measured paths" represent the actual paths and that there is nothing traveling along the other paths. Just the opposite, all these interpretations agree that there is a wave function traveling through BOTH slits (even though they disagree on what this wave function actually is), which is ultimately why the interference is possible. To conclude, the "which way" experiments are not really which way experiments. Those who understand it should not be puzzled by the delayed choice experiments. And those who are puzzled by the delayed choice experiments must be thinking (incorrectly, of course) that the "which way" experiments really ARE which way experiments. But they are not. They are just misleadingly called so. |
| Apr22-12, 06:03 PM | #22 |
Number 1 is clearly nonsense. Number 2 has an opinon (is biased). None of them clearly disproves Fred Alan Wolf in his book "Star Wave - Mind, Consciousness, and Quantum Physics" where he talks about the quasar light being bent by gravity, and given two paths. It seems we have three opinions of physicists: (1) the past does not get changed, (2) it does get changed, and (3) there is no past to change, so forget what you saw [you idiot]. Do any of you have any data showing the number of physicists who prescribe to each of the 7 interpretations?
| Apr22-12, 09:26 PM | #23 |
but, as you said, if we have a wavefunction passing through two slits we should have an interference pattern. Therefore, how is that possible that when we put a measuring device (wheter it is possible or not to effectively measure the which way information) this interference will not show up? |
| Apr23-12, 02:19 AM | #24 |
More technically, the system traveling through the slits becomes entangled with the device, so the traveling system cannot longer be described by a coherent wave function. Instead, it is described by a mixed density matrix, which lacks information about relative phases and hence does not exhibit interference. |
| Apr23-12, 07:41 PM | #25 |
| Apr24-12, 03:32 AM | #26 |
| Apr24-12, 06:51 PM | #27 |
| Apr24-12, 11:25 PM | #28 |
What I don't understand is why anyone sees anything that involves changing the past in DCQE. Exactly what is supposed to be getting "changed"? All I see is an experiment where if you correlate outputs using a different apparatus, you get different types of correlations. What has that got to do with the past?
To me, what DCQE tells us is that we were wrong to imagine that a pattern that was not a two-slit interference pattern does not contain anywhere in it two-slit interference. The DCQE shows us that even in a pattern that we don't see the two-slit interference still has two-slit interference in it, but the two-slit interference is not apparent because it has been offset, losing coherence, by whatever details of the apparatus are allowing "which way" information. Change the apparatus, change the information you have available. What else is new? To see that the two-slit interference is actually there, but not apparent, we simply need to erase the which-way information and do the appropriate correlations. Poof-- a non-interference pattern is seen to actually be two two-slit patterns that are offset to cover the tracks of the two-slit interferences. So we have two completely different ways of interpreting a non-two-slit-interference pattern-- we can say there was no interference there because "which way" information exists, or we can say that there was two-slit interference there but the presence of which-way information requires that the multiple sources of two-slit interferences must destructively interfere to be consistent with the which-way information. When we can take two equivalent approaches, we must recognize that nature leaves the issue indeterminate. There is no such thing as the "actual" interference that occurs, it all depends on how we conceptualize the interference. This is routine in all kinds of physics, not just quantum mechanics-- when there are many ways to skin a cat, we should not imagine the cat is "actually" skinned in any one particular way. So this all seems to me much like standard complementarity in quantum mechanics-- there is only so much information available, so to know one thing forces us to lose track of something else. Here, to know "which way" forces us to lose the information in the two-slit interferences, or we can erase the "which way" and recover the two-slit interference information. It's the same if we erase knowledge of position and thereby recover knowledge of momentum. Moreove, the "delayed" aspect, and the "changing the past", seem like complete red herrings to me-- all we are doing with respect to time is making different measurements that we are going to correlate, what difference does it make when those measurements were made? The information appears at the moment when the correlations are made, and no information about the correlations even exists prior to comparing the data, regardless of when the data was taken. And the idea that this somehow violates relativity seems to me to be the worst error of all-- it's just the opposite, relativity tells us above all that physics is not global, it is local, and so we should never imagine that a correlation between two datasets exists anywhere except in places where both those datasets are present. |
| Apr25-12, 02:46 AM | #29 |
| Apr25-12, 02:47 AM | #30 |
| Apr25-12, 03:08 PM | #31 |
Yes, I think we very much agree, our ways of describing it are merely affected by our various perspectives and perhaps different ways of saying it might resonate with different readers, or stimulate different objections to our stance. I'm sure you cringe just as much as I do when you read a lot of what is said about DCQE (like photons that were originally determined to go through only one slit being told by some choice in a later experiment to go back in time and split and go through both slits instead, or some other such highly forced and awkward interpretation), so I think this was a good thread for you to start!
I also think you made a good point in the OP in regard to the interpretations. It seems like people go to great lengths to settle on one or other self-consistent interpretation, but all of a sudden when DCQE comes up, they toss out their favored interpretation and immediately resort to pseudo-classical kinds of language that would never even stand up to their own favored interpretation! Or, we get popularized articles that feel no need to adopt any standard interpretation, because those "weren't meant for DCQE" or some such thing. This abandoning of interpretations will always lead to paradoxical sounding results, the same thing happens with that darned cat! |
| Apr25-12, 07:44 PM | #32 |
| Apr25-12, 08:08 PM | #33 |
I know nothing about the Bohmian interpretation except what you posted. So it seems there is still a wave through each slit which both have to collapse, but only one particle materializes. Can you explain why that happens only when people are looking for particles? |
| Apr25-12, 11:26 PM | #34 |
And, to complete the analogy, we can recover the two-slit pattern by "erasing" the which-way information, by inserting a polarizer at 45 degrees to both of the polarizers in the slits, before the photons reach the detecting wall. Now some of the interference that was always there but wasn't showing up on the wall is allowed to show up on the wall, and the two-slit pattern appears, even though there are polarizers in the slits that, with a different setup, would provide "which way" information. This is true even if the 45 degree polarizers are a light year from the slits, and were put in place long after the light passed through the slits. The morals of the story: 1) the apparatus as a whole determines the outcome, not pieces of the apparatus, and it makes no difference at what time the elements of the apparatus were placed there, and 2) what interference does or does not happen is a function of our analysis, not the apparatuses. Any description that gets the answer right is just as valid a way to talk about what "really happened" as any other. |
| New Reply |
| Thread Tools | |
Similar Threads for: Who is puzzled by the delayed choice?
| Delayed Choice Revisited | Quantum Physics | 0 | ||
| Delayed Choice exp and Cause-Effect | Quantum Physics | 12 | ||
| delayed choice experiment | Quantum Physics | 6 | ||
| Delayed Choice Quantum Eraser | Quantum Physics | 66 | ||
| Delayed Choice | Quantum Physics | 0 | ||
