| Thread Closed |
On Dark Energy. |
Share Thread | Thread Tools |
| Sep6-04, 06:01 PM | #52 |
On Dark Energy.Outside of a basic understanding of optics, I don't have the math skills to explain my ideas about lensing in ways that are understandable to physicists or mathemeticians, which is probably why Nereid seemed puzzled by my insistence that the GR concept of "gravitational lensing" is inaccurate in light of the quantized structure of space-time envisioned by LQG. You may remember that for some time, I have been exploring whether vacuum energy might be polarized (oriented by local fields): http://www.physicsforums.com/showthread.php?t=37724 http://www.physicsforums.com/showthread.php?t=28868 After you read Puthoff's paper, you will know why I've been pursuing this. One question still bugging me is this: Can mass create such extreme distortion of the units of space-time that the virtual pairs that define ZPE do not have room to arise (like the small gap between the plates of the Casimir Effect experimental equipment). I may eventually have to reconcile the concept that "space-time" belongs in the Einsteinian GR, and that the fine structure of space-time in a quantum extension of GR will more properly be expressed as vacuum energy. Puthoff models the space-time distortion caused by mass as polarization of the vacuum field (ZPE) and equates the variable polarization as a change in refractive index. He then explains "gravitational lensing" in terms of the optical properties of the lensing media. That seemed to offend you terribly when I did it, Chronos, judging from the tone of the quote above. I wonder if you think his paper stinks, too? At least, you get math with his "theoretical cow pie". http://www.arxiv.org/abs/gr-qc/9909037 |
| Sep6-04, 08:24 PM | #53 |
Thanks Garth; this has been troubling me since I first read your SCC paper!So you pays your money and you places your bets: 1) concordance cosmology (full of non-baryonic dark matter - collisionless, interacts via gravity only) 2) MOND (does wonders with galaxy rotation curves and dwarf galaxies; fails for clusters, doesn't incorporate Relativity) 3) SCC, or 'free-coasting' universes (no such thing as non-baryonic dark matter; not even hints on what form all the dark baryonic matter might be in). Garth, doesn't it bug you intensely that you haven't got a handle on what form the 'missing' baryonic matter is in? I mean, just about every possibility has been constrained - in many cases quite severely - and the sums keep coming up way short.
| Sep6-04, 09:04 PM | #54 |
[...] However, current lack of understanding of the explosion physics and the radiation transport of SNe Ia encumbers any investigation of evolutionary changes. Any change in the peak luminosity of SNe Ia must be inferred from indirect observations, such as light-curve shape, colors, and spectral evolution. At the moment, many of the distant SNe do not have the required data set for a detailed investigation of these parameters. The near-uniform light-curve and spectral evolution of SNe Ia can be used as accurate cosmic clocks to demonstrate the time dilation as predicted from expanding world models. The test has been performed through both photometry and spectroscopy, and is fully consistent with the predictions. The supernova (SN) results can be reconciled only with cosmological models that provide some form of acceleration. The simplest such models either include the cosmological constant or refer to a decaying particle field ("quintessence")." One may dislike 'epicycles', but short of saying 'gee, I haven't a clue about what the good observational data are telling us', what alternatives to 'dark energy' and 'dark matter' are there? (at the risk of boring everyone totally senseless, I personally don't think the distant SNe data are good enough yet, nor all potential 'non-cosmological' causes fully understood; I'm glad that Leibundgut at least partially agrees). I'm also not as relaxed as Chronos seems to be about the freely coasting models and 'primordial abundances'; there's no new physics, so Gehlaut et al, let's have precise predictions on nuclide abundances (not just 'metallicities', nor even 'elemental')! One small thing: "Standard Model" - I know this is used by particle physics folk to describe QCD, the zoo of particles, the hypothesised Higgs, ... is it also commonly used to describe the [tex]\Lambda[/tex]CDM cosmologies? |
| Sep6-04, 09:31 PM | #55 |
Best address it by good work, not moaning. First (she said, sounding once again like a broken record), most of the top quality data is in the public domain; anyone can get it and do their own analyses. Second, I'll issue an open challenge on the 'cosmological observations are all theory dependent, change the theory and those observations change too' claim: while the *papers* reporting the observations may be written with certain theories built into the analyses, can you show that the underlying *data* have such built in? This PF thread, about the CMBR, has a link to a 1999 Tegmark paper on analysing the BOOMERANG, WMAP, and Planck data, to remove foregrounds (it was written before all three even started); unless I misunderstood the paper, the *data* from these three could comprise both the 'cosmological signal' (free of any theory) as well as the 'foregrounds'; how a researcher chooses to analyse the data - wrt a particular cosmological model - is up to her! The challenge: what (cosmologically relevant) observational data has been collected with 'cosmological theories' built-in? |
| Sep6-04, 09:46 PM | #56 |
- GR works - GR predicts the bending of light by mass - we observe something that looks exactly like what GR predicts (many tests done to support this) - the mass (amount, distribution) estimated by assuming GR is large, this amount of mass is larger than what we would expect from the M/L ratios of luminous objects (e.g. galaxies). - However, the 'non-luminous mass' estimated from straight application of GR is ~OOM the 'total mass' estimated from not one but TWO independent sets of observations (X-ray and velocity dispersion). So the choices are: 1) throw out GR (the only mass that's 'really there' is that we can estimate from the distribution of light); 2) keep GR (the mass that we estimate from the images and GR is much higher than that we infer from the light). |
| Sep7-04, 06:44 AM | #57 |
Thank you Neried for some much valued constructive criticism of SCC!
But let me ask you, doesn't it bug you that you haven't got a handle on what form the DM is in? I know there is a whole zoo of possibilities but each seems to have its own problems, just this last week New Scientist reports that neutrinos are now out of the picture. : (NS 4 Sep 04 pg 39 "Weighing the invisible") As for Bruno's Leibundgut comments "Compared with Friedmann models of the universe, the distant SNe are too faint even for a freely coasting, "empty" universe, barring other influences that could dim the events." He was referring to an empty Friedmann universe, the Freely Coasting universe requires a new gravitational paradigm, it is not empty and so his analysis is not appropriate. "Change the theory and the observations/deductions change too". The RAS lecture was given by Prof. J.P. Ostriker (IoA) entited "Concordance Cosmology" on May 14th at the RAS Monthly meeting. It was very good but I couldn't help reflect on the invisibility of those three pillars I mentioned. Of course I agree that your pillars are sound, just that there are other ways of explaining them viz: SCC and the freely coasting universe. In the Standard model the theory that all our cosmological observations are dependent on is GR! I distinguish between the raw data (red shift, angular size, apparent magnitude etc.) and observation, which is deduced from the data (recession, curvature etc.) For example, the fact that the CMB WMAP data indicate flatness is taken to mean that the cosmological density parameter is unity, but this only applies if the GR cosmological equations hold. They do not in alternative theories such as BD or SCC I thank you again for a decent discussion and criticism of my ideas - Garth. |
| Sep7-04, 08:59 AM | #58 |
http://www.calphysics.org/index.html GR breaks down at very small scales (where ZPE lives) and I believe that this failure is the source of the misapprehension about the "missing mass" on very large scales. If the CIPA folks are right, we do not need dark matter, dark energy, Higgs Bosons, WIMPS, etc. to explain the gravitational behavior of the Universe, simply the interaction of matter with vacuum energy. If I understand ZPE properly, its energy potential is 120 OOM larger than the observed Casimir Effect, so plenty of energy could be developed from just a small amount of polarization. The reason we don't see ZPE in the macro world is that it is all pervasive and exists at the lowest energy possible. There is no "contrast" in the ground state. |
| Sep7-04, 12:47 PM | #59 |
| Sep7-04, 01:15 PM | #60 |
http://citebase.eprints.org/cgi-bin/...2Dph%2F0302273 |
| Sep7-04, 01:44 PM | #61 |
| Sep7-04, 02:17 PM | #62 |
Gravity probe B may yet produce a surprising result that tells us more about dark energy/ dark matter.But if it does not then general relativity will be harder to knock
in future. |
| Sep7-04, 03:53 PM | #63 |
Could there ever be enough money, space, or electrical power to construct and operate an accelerator to probe those energies?Correction! I should have searched out Milgrom's papers first of all. He speculates here that MOND could be a modification of inertia due to a vacuum effect. It's an older paper, so he doesn't refer to the EM ZPE work being done by CIPA. MOND would be a perfect experimental test bed for CIPA. http://citebase.eprints.org/cgi-bin/...tro-ph/9805346 Yes it is. Please read the quote in my last post to Garth above. I lifted it off the CIPA site after wondering about the cosmological effect of SUCH a large energy potential. Note that CIPA concentrates on the EM Zero-Point Energy field because it shows the most promise for manipulation in terms of Breakthrough Propulsion. NASA is picking up the tab. |
| Sep7-04, 04:52 PM | #64 |
![]() {maybe marcus can give us a tune, 'you say "tomato", I say "ZPE"; you say "potato", I say "dark matter"'!} |
| Sep7-04, 05:35 PM | #65 |
OK, I can see you just a teensy bit uncomfortable with inertia and gravity arising from masses interaction with ZPE fields. Poke around here a bit, though, and see what you think:http://www.calphysics.org/index.html You may view mass-ZPE-interaction as an epicycle. I see it to be just the opposite - an elegant solution to a couple of GR's biggest problems. It is economical of entities (reduces rather than creates necessary entities) and it is testable. Occam would demand that we give it a shot. Rotation curves of spiral galxies can provide experimental evidence. MOND appears to work, and ZPE field-induced differential inertia may be why. The slick thing is that all the elements needed are already out there - 1) matter in 2) a bound system existing in 3) space-time suffused by 4) quantum fields. No need for obedient, prescient dark matter clumping up in just such densities and distributions to keep our precious GR accurate. Another potential test - can ZPE explain the mass/luminosity ratio of X-ray clusters? MOND has a problem with this class of objects. I predict that the first researcher to create a testable model of ZPE inertia as the cause of differental rotation in spiral galaxies will have to buy a new dinner jacket and learn a few words of Swedish.
| Sep7-04, 05:55 PM | #66 |
![]() Re neutrinos: I have thought for some time that they can't be more than a minor player (unless there's a whole unknown new spectrum of types as yet unobserved). |
| Sep7-04, 06:47 PM | #67 |
As I said in an earlier post apart from having an obvious interest in SCC, what I, and others **, are concerned about is the "over" confidence placed in the standard paradigm. I would have thought alternatives would have been of more interest in the name of good scientific practice. But the key point is that some these alternatives are testable in experiments such as GPB. Even then Kenneth Nordtvedt has said that the GPB experiment was worth doing when it was first planned in the 1960s, but that today the result is a foregone conclusion. ** see http://www.cosmologystatement.org/ |
| Sep7-04, 09:31 PM | #68 |
I am not a physicist by training, but my avocation of observational astronomy and astrophotography led me to relate problems in astronomy and cosmology to the fields that I am familiar with, particularly optics. I have for a very long time followed the work of Halton Arp, Geof and Margaret Burbidge and others in the popular press, and as soon as the Internet became available here in the Hinterlands, I followed them there as well. One in-depth correspondence with Mr. Halton "Chip" Arp (arising from a letter I wrote in reference to an article by one of his detractors) gave me an enduring respect for the man. I already knew that he is a disciplined observational astronomer. The correspondence cemented the fact that I was dealing with a real gentleman. It also showed me that I was dealing with a man who understood the significance of proposing paradigm-altering concepts in a field that is firmly committed to nearly 100 years of conventionality. He is quite philosophical about that. A gentleman, as I said. I have had similar interactions with two equivalent intellects in other fields - Cecil Rhodes who was Professor Emeritus of English Literature at the University of Maine (and a Rhodes Scholar). He tried to ride herd over a bunch of us Engineering students with high SATs, and he actually turned me to the Dark Side of the Force, and was a pivotal force in my switch from Chemical Engineering to English Literature, with a concentration on the Romantic Period. The other man was Erling Skorpen, Dean of Philosophy, who let me into his grad-student and senior-only Meta-ethics course after a "brief" 3-hour "lunchtime" Q&A that I was led to believe would last less than 15 minutes. He had a 3pm class and begged off with a commitment that we would re-engage. I was a sophomore, and had never taken a basic philosophy course. I never had to take one after either, and maintained a double major - in English Lit and Ph. All these men are gentlemen in the truest sense of the word. As the son of a mill-worker living in a very poor town, their treatment of me was greatly appreciated. I felt the same way dealing with Halton Arp. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: On Dark Energy.
| Dark Matter/Dark Energy Question | Cosmology | 4 | ||
| superb overview of contemporary research/observations in dark matter, dark energy | Cosmology | 0 | ||
| Review of Dark Matter and Dark Energy by M. Kamionkowski | Cosmology | 5 | ||
| dark matter, dark energy & gravity | Cosmology | 45 | ||
| dark energy = dark matter*speed of light squared? | General Astronomy | 14 | ||
